Question about Garden
Model 98444 how to check pump oil level? - Garden
2 Suggested Answers
  • 93 Answers
SOURCE: HOW TO CHECK OIL LEVEL IN AIR COM PUMP
you need to have this done bye an air con specalist correct amount of oil is put in when the system is gassed up if yours is working ok leave alone
Posted on Dec 07, 2009
2002 Chevrolet Malibu oil light on & valves clattering
Check the oil level on the dip stick and make it correct. This engine should have a low oil shut down feature. Possible oil pump failure. With oil at correct level, restart engine. If the oil light does not go out with engine running, shut down immediately. Severe Internal rotating component bearing damage has already occurred. look for loose oil filter or hole in oil pan.
Mar 03, 2017 | 2002 Chevrolet Malibu
Oil level on mark when engine is cold, way high when running
Are you pulling the dip stick out with the engine running to check the oil level? You are only suppose the check the level when the engine is off. Oil level is high and in accurate while engine is running due to the oil pump pumping oil around the engine. :p
Apr 07, 2014 | 1992 Honda Accord
I have a Nissan frontier 2001,and i spend to much gas,i did check the oil level and the oil smell to gas
I do not know the model whether is Petrol or Diesel. Any one of the two is the fuel gets into oil due to problem with the fuel pump either diaphragm or diesel pump oil seal. Ask an expert to check it.
Nov 22, 2013 | Cars & Trucks
I just purchased a 98444 Pacific Hydrostar Power Washer. I was checking out the oil level in the pump and it appears to be bone dry. The manual calls for 75w/90 non- detergent oil but does not tell me the...
The oil cap should have a dip stick if not it should take maube a quart but add a little at a time untill u see some oil. But do not fill it all the way to the top
Sep 21, 2013 | Garden
Why does my low oil pressure light comes on when making left and right turns
Oil level is probably low. When you turn, your oil splashes to the right or left and your pump is not able to pick up the proper amount of oil to pump. If the level is proper, you might have the wrong grade of oil. Check your owners manual for proper weight for the driving sonditions you are in.
Oct 20, 2011 | Cars & Trucks
Red oil light stays on at high rpm.reads 139 at idle
Check the sending unit for the oil then check the oil pump. I bet on the oil pump being bad.
Feb 20, 2011 | 2005 Buick LeSabre
My oil light comes on when I apply my break, makes a noise and then turns off.
Is the oil at the proper level in the engine? If not, add some oil. If this engine is a 3.8 litre with the external oil pump, you may need to replace the oil pump. Have someone check the oil pressure if the level checks out to be okay. Braking often causes fluid levels to slosh and you may be briefly starving the oil pump pickup, causing the light to come on.
Jan 07, 2011 | 1995 Buick LeSabre
Check oil level warning comes on. Oil level is OK. This warning is intermittent.
first thing is check the oil pressure not by the instrument panel if ok then panel is out if not its the sensor or oil pump Try this replace the temperature sender with the new green model and oil light will disappear no more three annoying beeps.
Dec 24, 2009 | 2000 Audi TT
How do you check oil level on a u20 ir compressor do you check sight glass while machine is running or while in off mode?
Hi
No mate, you check it when the pump is not running.
Don't over fill it or it will pump oil into the tank.
That's bad news if you want to paint.
The middle of the sight glass is the correct level.
Don't let the oil get too low either.
The pump lubricates by a dipper on the bottom of the conrods. Too low an oil level starves the top end of oil and causes premature wear.
Regards Andrew Porrelli
Dec 07, 2009 | Ingersoll Rand - Rand Type - 30...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
