Question about HP Deskjet 6940 InkJet Printer
How do you clean your printer head nozzles on a HP 3520
  • 317 Answers
SOURCE: HP 648c Printing Problem
Here's a great link for troubleshooting you need to do for your printer: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00226&lc=en&cc=us&dlc=en&product=60402&rule=28651&lang=en
Posted on Aug 07, 2007
hvpatel
  • 152 Answers
SOURCE: hp deskjet 3520
goto www.updrivers.com
Posted on Feb 28, 2008
  • 11 Answers
SOURCE: flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Posted on Mar 04, 2009
omerboo
  • 424 Answers
SOURCE: Driver for HP Deskjet 3520
Alternative driver download link: HP Deskjet 3520 Color Inkjet Printer Driver
Posted on Feb 02, 2010
  • 241 Answers
SOURCE: How do I clean the inkjet nozzles? The print is
You can clean the printhead on the cartridges with a qtip. Wet the qtip with water and wipe it on the cartridges printhead. Also take another clean qtip and wet it down and clean the contacts in the printer, where the cartridge printhead contects with the printer.
Posted on May 29, 2010
Printing vertical green lines on photos
The troubleshooting section for banding below was taken from the user manual found at this web link:
https://files.support.epson.com/pdf/wf3520/wf3520ug.pdf
White or Dark Lines in Printout
If you notice white or dark lines in your prints (also called banding), try these solutions before you reprint:
• Run a nozzle check to see if any of the print head nozzles are clogged. Then clean the print head, if necessary.
• Make sure the paper type setting matches the type of paper you loaded.
• Make sure you loaded the printable side of the paper correctly for your product.
• Turn off any high speed settings in your product software.
• Align the print head.
• You may need to replace the ink cartridges.
Hope this helps...
Dec 21, 2014 | Epson WorkForce WF-3520 All-in-One Inkjet...
Clean printhead and breather hoses hp 3520
try to reset the the black printhead , and clean the it
Mar 23, 2013 | HP DeskJet 3520 InkJet Printer
Hp Designjet 430 new black cartridge printing blank page
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Oct 22, 2012 | HP DesignJet 430 InkJet Printer
Wont print blue
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked cyan print head nozzles.
Oct 17, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Lexmark x2600 not printing
Oct 02, 2012 | HP LaserJet 1020 Printer
My HP Deskjet F4488 printer's cartridge is not working . It slides only
Sep 15, 2012 | HP DeskJet Office Equipment & Supplies
HP photosmart will not process printing, just puts out blank paper
Sep 08, 2012 | HP PhotoSmart C4180 All-in-One Color...
Hp 8500 printer stuck in continuous cleaning and alignment loop after replacing cartridge
Printer wont do the alignment process if we replaced the cartridges, might be removed/re inserted the printer heads, then ply it process the alignment, if the print head nozzles are clogged, alignment process wont completes..
>Remove the print heads clean the nozzles with tissue paper gently at nozzles.
>borwse this link & see how to clean the print head,link:http://www.youtube.com/watch?v=ZAwYIbjswV0&feature=related
>Install the printer heads do the alignment..
> if not completed check which printer head clogged, replace the print head.
Oct 04, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
HP Deskjet 6940 InkJet Printer Logo
43 people viewed this question
Ben Johnson
