Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
Fagor Manuals f1 and f3
Fagor compact plus
You could have a defective gas control valve or a bad thermocouple. Also check the venturi tubes again. sometimes cob webs collect in them and it may be difficult to see unless you remove them and check.
Good luck,
Marty
May 05, 2014 | Water Heaters
Can get heating but no hot water
There is not enough informaton to help you, Is this an electric or gas heater. What model.
Jan 26, 2014 | Water Heaters
Ge geospring hot water heater fault code F1
Copy following links before calling GE with model and serial number for local trained service technician.
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
Don't buy expensive water heaters that do not have service manuals available.
Gene
h
Nov 18, 2013 | Geospring Hybrid 50 Gallon Heat Pump...
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
Have protherm 100ec boiler british gas has replaced almost every part boiler will fire temp gauge rises to about 55 flame increase in strenght for about 10sec then boiler cuts out also they keep trying...
Any other symptoms? Is the fault apparent only when drawing hot water? Does the boiler re-light later? Alarm messages? F1? F3 for example?
It may well need a powerflush, but it's best to find out before spending big money with BG.....wish I could get away with charging that much for a flush!!!
FYV
Jan 27, 2013 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
22 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
