Question about Port Incorporated 2007-2010 Honda CR-V Receiver 4XN0
Change transmission fluid pressure sensor switch circuit honda crv
Engine Check was on and "D" drive blinking then I went to the dealer to have them diagnosed my vehicle diagnosed and they found out P0843 (transmission fluid pressure switch) that need to replace, I want to replace it my self to save money, but I don't where is it located that switch, can you help me out where the switch is? Thanks
    New Friend:
  • 28 Answers
Http://www.crvownersclub.com/forums/19-maintenance-service/14878-how-3rd-gen-cr-v-3rd-gear-pressure-switch-replacement.html
Posted on Nov 19, 2013
Got p0748 p0108 code on my 04 honda odyssey. Car sat for about one year. Replaced fuel pump yesterday and it started right up. Can I get info on locations of where sensors are?
PO 748
service the transmission .....check solenoids
- Dirty transmission fluid - Low transmission fluid level - Faulty line pressure solenoid valve 'A' - Line pressure solenoid valve 'A' harness is open or shorted - Line pressure solenoid valve 'A' circuit poor electrical connection
Read more: http://www.autocodes.com/p0748.html
P0108
is the code for a problem with the MAP electrical circuit sensor having too high voltage input to the Engine Control Unit (ECU). This means that the voltage input to the ECU is too high and that it is not in the correct range for proper engine operation to work with inputs from the Mass Air Flow Sensor (MAF) and Throttle Position Switch (TPS). P0108 OBD II Trouble Code Manifold Air Pressure MAP Barometric Pressure...
odyssey map sensor is on the throttle body
Map sensor
Nov 10, 2016 | Honda Cars & Trucks
Diagnostic code: P0843 what is it?
P0843 Open in 2nd Clutch Transmission Fluid Pressure Switch Circuit, or 2nd Clutch Transmission
Fluid Pressure Switch Stuck OFF
Dec 14, 2013 | 2004 Honda Civic
I have a 2004 Jeep Wrangler 4 cyl. The CEL came on. Had no power for a little bit. Went to autozone and it pulled code P0870. Any suggestions.
po 870 refers to transmission fluid pressure- check fluid level of trans while parked with engine running and the jeep level.- if level is ok- might be time to have filter and fluid changed
Sep 15, 2011 | 2004 Jeep Wrangler
Honda crv drive indicator light blinks
Hi, basically this is the equivalent of the engine light except it indicates that something may not be right with the transmission. It could be something as simple as a malfunction in a sensor.
Have you checked the fluid? Have you ever changed it? Did you use only Honda recommended fluid? It may simply need to be topped off. Is there any indication of a leak? Is the fluid red or brown? If it isn't red then change it. Drain and refill it at least twice or up to four times for a thorough change. Less than half of the old fluid drains out with each change so it is necessary to drain an refill a number of times to get out most of the old fluid. After doing this check the fluid after using the vehicle for a day or two to see if it needs topping off.
Take it to a place like Autozone or Advance Auto Parts and have them put a code reader on it if changing the fluid or topping it off does not solve the problem. If you have a leak get it fixed.
May 24, 2011 | 2004 Honda CR-V
I have a Honda CRV - The drive light blinks when the weather gets warm
Hi, the light indicates that something may not be right with the transmission which could be something as simple as a malfunction in a sensor.
Use only Honda recommended fluid available at the dealer or at Carquest Auto Parts stores
May 15, 2011 | 2003 Honda CR-V
D" blinking is showing on
The PCM senses an abnormality in the powertrain system. Get the code checked, probably a pressure switch though.
The flashing D is a warning signal that there is a transmission problem. Sorry. Below is Honda recommendation for fluid changing.
Also, you coould check this Honda Auto Trans Flush Procedure - Official
Hope helps.
Apr 20, 2011 | Honda CR-V Cars & Trucks
The Drive light flashes and the car loses power and sometimes won't start.
It is either your Vehicle Speed Sensor (easy to change) or your Automatic Transmission Computer (capacitors burn out on these boards, there is a fix for this too, the picture is at the bottom of this page). You need to diagnose by removing the lower right plastic kick panel on the passenger side. There you will find a blue plug. With the car OFF stick a paper clip, wire or stuff the plug with foil to make electrical connection so that the two terminals are touching. Then, turn the ignition to ON (not enough to start it though, just power it up). When you do this, count the blinks in the "D Light" or count your blinking Check Engine Light. Both are different but can refer to different things wrong with your car. A long blink is the first number and the short blinks that follow are the second number.
So imagine this as being 14 : ___ _ _ _ _
Below is a decoding chart:
The first section will be the check engine light codes, the next one is the Transmission Control Unit Codes read from the D Light;
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
TCU Codes:
CODE LIST:
1-Lock-up solenoid 'A' circuit open or shorted.
2-Lock-up solenoid 'B' circuit open or shorted.
3-Throttle Position Sensor circuit open or shorted.
4-Vehicle Speed Sensor open or shorted - No signal from speedometer.
5-Shift Lever Position Switch circuit shorted.
6-Shift Lever Position Switch circuit open.
7-Shift Solenoid 'A' circuit open or shorted.
8-Shift Solenoid 'B' circuit open or shorted.
9-Counter shaft or transmission speed pulse generator open or shorted.
10-Coolant Temperature Sensor open or shorted.
11-Engine RPM (Ignition coil signal) open or shorted.
12-(No code 12 used)
13-Main shaft speed pulse generator open or shorted.
14-Linear (line pressure control) solenoid open or shorted.
15-Kick down switch circuit shorted.
Feb 14, 2010 | 1992 Honda Accord
When I engage my crv into drive the D on the dashboard that is lit up green is blinking, what's up with that?!
It is the transmission version of a check engine light. Have a mechanic run the codes. Chances are the fluid may need changed, although that is not the only possible issue. If it is still working ok there is still time to have the issue resolved.
Dec 22, 2009 | 2003 Honda CR-V
Honda 97 crv engine turns off while driving, and hard to
, pull a plug wire and ground it to the engine body and check for spark. if spark then
check your fuel system pressure, fuel pump
Aug 28, 2009 | 1997 Honda CR-V
Port Incorporated 2007-2010 Honda CR-V Receiver 4XN0 Logo
267 people viewed this question
Top Port Incorporated Car Audio & Video Experts
xxxxxx xxx
Are you a Port Incorporated Car Audio and Video Expert? Answer questions, earn points and help others
