Question about Kenmore 63942 Dryer
Kenmore heavy duty clothes dryer will not heat
Kenmore model # 96281800 heavy duty electric dryer will not heat. Evrything seems to work other than it does not heat and the timer does not shut the unit off.
  • 18 more comments
  • Anonymous Mar 29, 2008
    kenmore series 80 dryer runs fine but no heat.
  • Anonymous Apr 05, 2008
    my dryer is not heating
  • Anonymous Apr 07, 2008
    My dryer will not heat.
  • junkstrike Apr 07, 2008
    The dryer is not heating, everything else is fine.
    Everything seems to work other than it does not heat.
  • UpstreamDave Apr 12, 2008
    everything else works - no heat
  • Anonymous Apr 29, 2008
    dryer will not heat 9659522
  • Anonymous Apr 30, 2008
    where do i find this fuse please
    yes no heat.. no glow no nothing hot
  • Anonymous Aug 22, 2008
    no heat
  • Ms Blade Jan 25, 2009
    Kenmore heavy duty 60 series dryer won't heat up and timer won't move to shut off when done.
  • Anonymous Mar 30, 2009
    dryer running, but no heat
  • njherrero00 Apr 21, 2009
    Where can I find parts for my dryer?
  • Anonymous Mar 13, 2014
    kenmore electric dryer has no heat
  • Anonymous Mar 16, 2014
    I have a Kenmore heavy duty dryer model C1108540190 type DR 1 I was wondering if it has a coil element or two seperate ones because only one side will heat up and I have to restart the dryer a second and third time when I want to dry a load of clothes Can you tell me what is happening
  • Anonymous Mar 17, 2014
    dryer will not heat
    DRYER INDICATES F 0 3 IN SCREEN DRYER DOES NOT DRY CLOTHES..FUSE?
  • Anonymous Mar 19, 2014
    smells hot and may smoke
  • Anonymous Mar 31, 2014
    will not start - it makes no noise at all & the motor will not turn on at all
  • 291 Answers
You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat. Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Posted on Oct 08, 2007
Were is the fuser
Posted on Apr 29, 2008
Most problems with dryers not heating is the thermo fuse is blown. bout 20 buck to replace it looks like a small white flat football. but most likely if it went out that means the the high temp thermostat is messed up too
Posted on Feb 07, 2008
The dryer will not turn on.
Posted on Jan 04, 2008
2 Suggested Answers
SOURCE:
  • 1122 Answers
SOURCE: kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Posted on Feb 26, 2009
Kenmore heavy duty plus dryer modle number 886573130 works fine just stopped heating up.
Gas dryer no heat means the heating element broke or fell apart, need to install new one, go to sears hardware and order a repacement....model # in hand.
Feb 22, 2015 | Kenmore Dryers
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
My Kenmore Series 90 heavy duty gas dryer does not heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 19, 2011 | Kenmore Dryers
I have a series 90 heavy duty electric Kenmore dryer. I think the heating element has gone out. Is this an easy fix. Dryer still works just doesnt get hot to dry clothes.
If The front panel is one assembly then the element is on the back behind the cover, if there is a small panel on the bottom ending about where the door starts the element is behind that panel on the right hand side. In either case it if fairly easy to get to. Also check the two thermostats on the heating element. Both should have continuity. If either one is open replace them both.
Jan 31, 2011 | Kenmore 62802 Electric Dryer
Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Mar 17, 2009 | Kenmore Dryers
Feb 25, 2009 | Kenmore Dryers
Kenmore dryer won't heat and must hold button down
Switch on fan motor not working sw must prove that fan is running! bad motor sw or loose wireing motor sw will by pass start button is released if working!
Jan 04, 2009 | Kenmore Dryers
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
Sure. The likely problem is a broken belt. Do you hear the motor? If not, it could be the motor. Pull the back off the unit...with the power off and have a look.
Dec 21, 2007 | Roper RES7646KQ Electric Dryer
Kenmore 63942 Dryer Logo
6,737 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
