Question about Tunturi Exercise & Fitness
E8 error code on Tunturi J66o treadmill
Hi The treadmill running belt exceeded the side of the parameter. When I turn it on the belt will move slightly then goes to the error code 8.
SOURCE: bodyguard t300 treadmill. belt will not turn
Smashed harness created short.
Posted on Jan 27, 2009
  • 82 Answers
SOURCE: Proform 590 HR Treadmill. Belt won't run
Hi, i fixed one just the other day, the control unit fails.
broddersbaldrick on a big auction site fixes them :)
Hope this helps
Posted on Apr 22, 2010
maxtreadmill
  • 832 Answers
SOURCE: hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
Posted on May 14, 2010
  • 15 Answers
SOURCE: Where can I purchase a teflon spray lubricant for treadmill?
Tunturi.com or accellfitnessna.com should have the lubricant you need. Order it online and they should be able to ship it directly to your house. I service tunturi treadmills, although I haven't come across a teflon lubricated machine, it is very important with these machines you stick with the manufacturer specified lubricants.
Posted on May 27, 2010
stevebuck453
  • 4 Answers
SOURCE: I have a Tunturi j770 treadmill with error code E1...
Buckmanservices.com solved the E1 code issue only $30 fixed it from online told me what to do
Posted on Jun 13, 2012
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 08, 2013 | Tunturi T40 Folding Treadmill
Tunturi t7 showing error 20 !
this means the treadmills power reading when the treadmill was operating at speeds of 1 miles per hour or less . Excessive amount of power is being demanded from the motor controller for an excessive period of time
Causes:treadmill user (especially a heavier user) is standing on the drive belt.
the drive belt too is badly worn.
brush motor faulty
SCR motor cotroller lekay or shorted drive motor or capacitor
IN short RUN the sotware calibration for diagnostic.
Remedies:Lube the deck belt, determine using AC ammeter for the amount of use the current being drawn by the readmill.Replace the drive motor brushes.or replce the motor controller board. see the block diagram
God bless you
Oct 11, 2012 | Tunturi T70 Treadmill
Tunturi t7 showing error 20.
Try to RUN the sotware calibration for diagnostics.
This means user is heavy standing in the drive belt.
Causes: drive belt is worn, brusher motor faulty, motor faulty, motor controller board faulty
Remedies: use AC. clamp for drawn currente entering to the treadmill. Repair brusher and motor. Replace motor controller board.
God bless you.
My tanturi treadmill model j620p does not work. thou it has a power n the panel indicate a number 51 even i press the reset button it does not reset and all the key button does not function. what sould i...
Dear Sir:
I will try to help you:
If any error code appears on the display or there are other
malfunctions, proceed as follows:
1. Turn off the power switch for a minute and then
turn it on again.
2. Insure the tether key is properly inserted.
3. Insure the power cord is properly plugged.
4. Insure the treadmill is properly lubricated (see 4.3.
LUBRICATING THE RUNNING DECK).
5. If the error code does not disappear after the
above mentioned maintenance actions, please
contact your local TUNTURI dealer. Always give
the error code and serial number (see the sticker
at the back of the frame, below the left-hand side
rail).
4.3. LUBRICATING
THE RUNNING DECK
Lubrication is the most important service activity for the
treadmill. This is absolutely essential, if the friction of the
running deck increases noticeably or the motor begins to
heat up. Lubrication intervals must under no circumstances
exceed 200 usage kilometres; we recommend relubrication
once a month. During the first 200 km of use, the running
deck must be lubricated at intervals of 50 km. Insufficient
lubrication will cause the belt, running deck and motor to
wear out and break.
NOTE! Before you start to use your treadmill, it must be
carefully lubricated per the lubrication instructions
below! NOTE! If the treadmill is not used for at least
three weeks, it must be carefully lubricated per the
lubrication instructions below!
The need for relubrication depends to a great extent on the
running styles and weight of the user: heavy user weight and
slow speed put particular strain on the device and therefore
demand greater lubrication. Use only the teflon enclosed to
lubricate the treadmill. Contact your local TUNTURI dealer
for further supplies of teflon.
NOTE! The device must under no circumstances be
lubricated with silicone!
Please apply teflon by using the pressurised can provided
with these instructions.
instructions on the teflon bottle carefully.
1. Let the treadmill run at a slow speed and spray
teflon into the lubrication pipe underneath the
treadmill. The pipe is marked with a decal.
2. When teflon is applied for the first time, the
spraying time with the pressurised can should be
approximately 20 seconds. Later, a spraying time of
10 seconds is sufficient.
3. Teflon drops through the holes of the lubrication
pipe to the center of the running belt; the treadmill
is instantly ready for use.
Please ensure after each time that you relubricate your
treadmill that a strip of about 8" wide on the underside of the
running belt becomes moist with teflon oil along its whole
length. If necessary,
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 23, 2011 | Exercise & Fitness
My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
2.Press the "ENTER" button three times to access the treadmill's error log.
3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
I hope you find it very helpful.
Sep 04, 2011 | Exercise & Fitness
Hi, We have had our treadmill for about 3 weeks. For the past few days, when we start it up, after about 15 seconds of running on it, it stops and Error 1 shows up on the screen. It is a t40 model. ...
error 1 is a fairyl universal code for treadmills that means your control board has gone bad. Here is a list of things that will cause this to occur:
1. Improper lubrication of belt/deck (too much friction and amperage draw)
2. electrical variance (example: going from US 110 to foreign 220)
3. potentiometer on control board may be set too low (usually blue box with turnable dial) - to change this you would have to turn the dial ever so slightly and test after each movement until the belt starts to run on its own without the error.
other than the above issues you would have to replace the motor control board
Aug 05, 2010 | Tunturi T40 Folding Treadmill
My Tunturi J620P stops and E-1 shows in display
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the powerswitch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
May 14, 2010 | Exercise & Fitness
Speed sensor error
Your speed sensor may have failed and cause this condition Call Accell Fitness Of North America @ 1-888-388-6887 they are the Tunturi Distributors
May 04, 2010 | Tunturi Programmable Treadmill with...
Abrupt stop Tunturi J 660.
I am all set. I located a Tunturi service person in my area. We have an appointment set up. Thanks for following up. I. Hazelhoff
Jan 21, 2010 | Tunturi Exercise & Fitness
Exercise & Fitness Logo
26 people viewed this question
Top Tunturi Exercise & Fitness Experts
gbob59
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
