Question about Plumbing
Repair mico 7711-cp faucet seashore
Where can I find the special tool to repair the spray head to the mico seashore 7711
  • 2692 Answers
SOURCE: The faucet leak is from the top gasket around the control handle.
Yes, Grone will give provide a daagram and parts list.    All you need to know is the model number. The beasst source for parts is the manufactor. Can you match it up? Is it single lever or two handles? Can you go to a grone dealer and look it up in their model book? THey can also provide the rebuild parts.
Posted on Apr 25, 2009
  • 333 Answers
SOURCE: kitchen faucet spray head broke off
Home depot or Lowes
Posted on Jun 17, 2010
  • 3640 Answers
SOURCE: I have a pull out
take old sprayer with you and you should be able to get one at a hardware or even at homedepot.most sprayers come apart. maybe the rubber ring is bad on inside of sprayer.
Posted on Apr 21, 2011
  • 2841 Answers
SOURCE: The base of my Grohe faucet, where the faucet goes
You are correct. You need a special tool that the manufacture calls a fitting key. Without this key you cannot tighten the faucet to the counter top. Look at this diagram of how it is installed and you can see what the key (G) looks like. You will also need this key to remove the sprayer head to clean it.
http://www.groheamerica.com/lib/1/tpi/1311700.pdf
Call the person who installed the faucet and ask them what they did with the key. Look around after you see what it looks like and you may find it. Sorta looks like an old outdoor faucet handle. You can contact Grohe for a replacement key from this link.
http://www.groheamerica.com/en/contact-grohe/tech-email/m/25_8195/page/modules/contact/index.php?topic=kpprodukte
Posted on Jul 26, 2011
  • 51280 Answers
SOURCE: Where can I buy cartridges for my Mico kitchen faucet?
try plumber supplies wholesalers where the plumbers get their spares from
not a hardware or supermarket shop
Posted on Dec 24, 2017
Dec 24, 2017 | Plumbing
How do i unclog the spray head
Here is the breakdown for that faucet:
Kohler K-14402
Go to page 6 to see how to remove the aerator. You may need a special tool. This can be ordered from Kohler at 1-800-456-4537.
Hope this helps!
Dec 20, 2013 | Kohler K-14402-4A-SN Purist Single...
Need to tighten my ladylux
Grohe has a special tool that is used for installation that comes with the faucet. You have to remove the pullout spray and remove the curved neck of the faucet by pulling out. Insert the tool in the main body and tighten from above. Most plumbers will keep this tool when installing. I don't know if Grohe still uses the same system still today, but they did in the past.
Sep 03, 2013 | Grohe Ladylux Cafe Faucet with PullOut...
Spray does not work properly. Water comes from tap and small amount of water comes from spray. Unit is also loose on sink. Is special tool needed to tighten ? Thanks Helga
It sounds like the hose suppling the water to the hose spray has become kink or swisted check that and if no take the spray head and soak it in 50/50 white viniger and water for 1 or two hours to clean the lime from it. You can also use lime-a-way if you have it.
It is easyer to tighten the faucet with the tool provided with the faucet when you buy it but it can be done with a small wrench or locking pliers illistation 4 in the link below.
http://www.faucetdirect.com/mediabase/specifications/7835_install.pdf
Feb 03, 2011 | Moen 7835 Camerist Single-Handle Kitchen...
Hi, my shower faucet /head drips regularly how to repair the leak?
You need to order seals and replace them. Typically, dirt in the water system damages the rubber (neoprene, plastic) soft parts. Sometimes the damage wrecks metal parts, but this is less common.
Oct 05, 2010 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
May 22, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
One Handle Tap has gone random and hot/cold keep moving position.
look under the cap for a screw,see if you can tighten,if no screw under the handle is a plastic piece that is attached to the faucet diverter,this may have broken or the screw has come loose.you may have to replace the handle
Jul 30, 2009 | Plumbing
Broken thumb lever to a kitchen faucet side spray
Unless you have a super duper fancy faucet, all spray head for kitchen faucets are standard, and can be picked up at any hardware store, home depot, lowes or plumbing supply.
The easiest method of replacement is to screw off the handle, and leave the old hose intact. On the hose you will find two black washers. one fat and one thin. Take note which one comes off first and replace in that order. Pull back the screw housing and you will see the white plastic tube on the end of the spray hose has a locking ring nestled in a groove. Remove it. Now you can remove the old screw housing and put the new one on. After putting the handle screw housing on the hose, install the lock ring back into the groove., put washers back on in correct order, and screw your new spray head on. Good luck!
Apr 08, 2017 | Plumbing
Plumbing Logo
139 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
