Question about Sharp EL-1197P Calculator
Set time and date on Sharp EL-1197P11 - Sharp EL-1197P Calculator
drknow
  • 44 Answers
SOURCE: set date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Posted on Dec 19, 2007
SOURCE: Setting time & Date
I copied this from another post & it worked for me:
To enter the date
1. Be sure to switch to "rate set" from GT
2. Enter the month
3. Press the decimal point
4. Enter the day
5. Press the decimal point
6. Enter the year
Example 3.09.2007
7. Press the button that look like a clock/calendar
To enter the time
2. Enter the hour (please use military time)
4. Enter the minutes
Example: 13.24 or 9.24
5. Press the button that look like a clock/calendar
Then change the "rate set" back to the GT setting.
Posted on Mar 24, 2008
SOURCE: EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Posted on Dec 04, 2008
SOURCE: need to change the time on calculator
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position.
Date:
Enter in the order of month, day and year, then press date/time button
to complete the entry.
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
and displayed as “date”
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
(There is no entry available for the seconds value. The
clock starts at zero second.)
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
and displayed as “time
When settings are complete place the switch back to GT
Posted on Mar 13, 2009
SOURCE: Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Posted on Mar 16, 2009
HOW CAN I SET THE DATE ON MY SHARP EL 1750 PIII CALCULATOR
Here is a users manual for your calculator which explains the date and time setting process.
http://www.fixya.com/support/p193843-sharp_el_1750piii_calculator/manual-5324#
I hope this helps you.
Jul 08, 2010 | Sharp EL-1750PIII Calculator
How to set date and time on sharp el-1801pIII
User guide is here ...
http://safemanuals.com/user-guide-instructions-owner-manual/SHARP/EL-1801PIII-_E
Instructions are halfway down column 1.
Basically, you use the reset button on the back, then enter the relevant fields, delimiting as with a period <.>
I think their illustration explains it better than I can in words!
Feb 28, 2010 | Sharp EL-1801P Calculator
Setting the time and date
To set the date, make sure that you are in Rate Set. type in the date such as August 3, 2010 would be entered as 08.03.2010 then press the date time key. This will set the date. To set the time type in the time such as 4:20 PM would be entered as 16.20 then press the date time key and this will set the time.
Feb 02, 2010 | Sharp EL-1197PIII Calculator
I want to set the correct date and time and also the tax percentage on my sharp el-1801p calculator
go to the commanding prompt and type cd.. there you will type date and time there you can set the date and time
Sep 19, 2009 | Sharp EL-1801P Calculator
How do I set the date on Sharp EL-1801Piii
Adjusting the tiome is just like adjusting the date, owith the only difference that you just enter two values (hours and minutes):
1. Move the Grand Total/ Rate Setting mode selector to the "Rate Set" "position
2. Enter the time in the orde of hour, minutes (use a point to separate the two values) and then presse the [Clock/Calendar] button to complete the entry.
You may also want to download the SHARP EL-1801PIII OPERATION MANUAL
May 15, 2009 | Sharp EL-1801P Calculator
How do I set the date and time on the EL 1197P III
http://www.sharpusa.com/~/media/3F4ED1815067459995912CEE6A6A6DCB.ashx?cal_man_el1197P.pdf
Mar 13, 2009 | Sharp EL-1197P Calculator
How do I set the date and time on my EL-1801V calculator?
Push the button at the top over from GT to SET.
type the date in using the decimal as a spacer.
Then press the date/time key.
for the time...
Press the date/time key until the date shows,
then enter the time in military time and press the date/time key again.
Dec 01, 2008 | Sharp EL-2630P Calculator
Time date
i know i set this model before but i recently tried to again and it didn't work right for the time for some reason... but i do remember that you flip the middle switch to rate set, the you put in the date 12.10.08 seperated with a "." then you hit the time date button once. then you do the same with the time, hours(militarytime).minutes.seconds all seperated by a period I.E if it were 1:30 PM you woud put 13.30.00, then you hit the time button again.. the date and time should be set, might have to do it in the opposite order... but i know that is generally how its set
Oct 27, 2008 | Sharp EL-1801P Calculator
Sharp EL-1197P Calculator Logo
27 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
