Question about JVC RX-6500V Receiver
Losing left or right channel
When in 2 channel mode, I sometimes lose the left or right channel. It's quickly fixed with a hard tap on the case. I assume I have a short of some kind. Any help would be appreciated. Thanks
  • 93 Answers
Somewhere is loos contact. You should find it and resold it with soldering iron.
Posted on Oct 08, 2007
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Apr 24, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
I have a Kenwood KR-V9030 and the right channel is crackling and will not provide increased output when the volume is turned up. 1) Swaped speakers from left to right and the problem is in left speakers...
There is a chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
If it still doesn't work you might want to prove if its a low-level signal loss or a high level amp failure.
One way would be to run an RCA cable pair from the Tape Out to any other device (even a TV with speakers) you might have that accepts an audio input. If IT can't detect receive the DEAD Channel you're losing it in the preamplifying or source selection stages.
If it CAN be played externally, the receiver is losing it on its way to or at the amplification stage. Further isolation would require hands-on technical expertise.
Apr 16, 2011 | Audio Players & Recorders
It keeps losing the signal for my macbook pro and nintendo dsi. Right after losing signal it waits a second or two and then gets signal again.
hey,
There are a number of reasons for this.
1. try to move your router to the center of the room. If it is placed in a corner this could happen.
2. If there are multiple routers at home, then this could happen.
3. Try to login to the router page and try to change the signal strengths and channels.
4. This could also happen due to the type of encryption you have chosen. try to disable wireless encryption and if the disconnect does not happen, then try different combination of encryption until you get the desired result.
Cheers!!!
Mar 02, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
I am unable to receive fax. I have tried to fix
try this go into maint. mode * 2 8 6 4 quickly. then hit 9 twice. it resets with out losing any quick dials or tti
Apr 12, 2010 | Brother MFC-8440 All-In-One Laser Printer
Losing the right channel
usually this would indicate a dry joint inside or some other temp related intermittent fault, component problem. Take it to a tech and tell them what happens
Sep 17, 2009 | NAD C370 2-Channel Amplifier
Usb 2wireless adapter keep losing sigal
If your computer keeps losing the signal, you need to either change the wireless channel or boost your wireless power on your router. Sometimes even a combination of both is needed so you stop losing signal.
Feb 19, 2009 | 2wire 1000-200004-000 Network Adapter
Mortalkombat cheatcodes
There arnt any cheats but there are hints
Mortal Kombat: Shaolin Monks Hints playstation2.jpg Kung Lao Fatalities list Fatality 1: LEFT, UP, RIGHT, RIGHT, QUICK
Fatality 2: RIGHT, RIGHT, RIGHT, RIGHT, QUICK
Fatality 3: UP, UP, UP, RIGHT, QUICK
Fatality 4: UP, UP, UP, DOWN, QUICK
Fatality 5: LEFT, RIGHT, LEFT, DOWN, QUICK
Fatality 6: LEFT, RIGHT, LEFT, LEFT, QUICK
Fatality 7: UP, UP, LEFT, UP, QUICK
Fatality 8: UP, DOWN, UP, RIGHT, QUICK
Fatality 9: RIGHT, RIGHT, UP, UP, QUICK
Mutality 1: UP, RIGHT, DOWN, LEFT, LAUNCH
Mutality 2: LEFT, RIGHT, RIGHT, LEFT, LAUNCH
Brutality 1: LEFT, LEFT, UP, UP, POWER
Liu-Kang Fatalities list Fatality 1: DOWN, LEFT, RIGHT, UP, QUICK
Fatality 2: DOWN, LEFT, UP, RIGHT, QUICK
Fatality 3: LEFT, UP, UP, RIGHT, QUICK
Fatality 4: LEFT, RIGHT, DOWN, DOWN, QUICK
Fatality 5: UP, RIGHT, DOWN, LEFT, QUICK
Fatality 6: DOWN, RIGHT, LEFT, LEFT, QUICK
Fatality 7: LEFT, LEFT, LEFT, UP, QUICK
Fatality 8: RIGHT, UP, RIGHT, UP, QUICK
Fatality 9: RIGHT, LEFT, DOWN, DOWN, QUICK
Mutality 1: UP, DOWN, UP, DOWN, LAUNCH
Mutality 2: LEFT, RIGHT, UP, UP, LAUNCH
Brutality 1: RIGHT, UP, DOWN, DOWN, POWER
Baraka Fatalities (VS Mode) Fatality 1: DOWN, LEFT, RIGHT, RIGHT, QUICK
Fatality 2: LEFT, LEFT, LEFT, LEFT, QUICK
Johnny Cage Fatalities (VS Mode) Fatality 1: DOWN, DOWN, RIGHT, RIGHT, QUICK
Kitana Fatalities (VS Mode) Fatality 1: LEFT, LEFT, RIGHT, RIGHT, QUICK
Reptile Fatalities (VS Mode) Fatality 1: LEFT, RIGHT, LEFT, DOWN, QUICK
Fatality 2: LEFT, LEFT, LEFT, DOWN, QUICK
Dec 18, 2008 | Sony PlayStation 2 Slimline Console
Loss of Picture on Right and left side
Take your remote control, press volume to 0
Press the mute button on your remote, at the same time, press the menu button on your TV for 3 seconds.
A menu will apear, press the right arrow on your remote to go to menu 002 to fix your problem.
gbr@yahoo.com
Jan 02, 2008 | Apex Digital AT3208S 32" TV
Loss of channels
If you mean "losing" as in you could no longer tune to those channels because they disappeared out of the channel list entirely, then it's likely a software problem.  If you haven't already, try resetting your DVR to factory settings (since this unit is TiVo powered, it should be under the main menu, Messages and Settings, then Restart or Reset system; follow the on-screen instructions to reset the system).
If you mean "losing" as in you can tune to the channel but there's no signal, then that sounds like a tuner problem to me.  If the box is still under warranty or you lease it, have it repaired or replaced.  If you bought the box and the warranty is up, it looks like you might have to get a new one, or pay for the repair out of pocket.
You might also try calling back to DirecTV tech support and asking to be escalated or to speak with a supervisor; especially if it's a box you're leasing from them, since it is definitely *their* problem in that case.
Oct 21, 2007 | Samsung SIR-S4040R DirecTV DTV Receiver /...
JVC RX-6500V Receiver Logo
82 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
