Question about Hardware & Accessories
ELITE EL-105UL What is the power transformer's output voltage and ma? I have a box full of transformers and don't know which one to chose.. Thank you, Dale. ixtix99@outlook.com
SOURCE: Need to know voltage needed for wrt54g Linksys wireless router
The stats on my adapter are as follows:
.5V 2.0A
Posted on Feb 23, 2009
welcomejee
  • 10594 Answers
SOURCE: sony boombox model cfs-b11 transformer
Your tape requires 9 volt transformer as shown in below schematic..
Part number is 1-450-016-11
Posted on Mar 05, 2009
SOURCE: Philco 841.205 Power Transformer
Hi:
...I have a brand new one exactly the same (Philco) that I will sell you for ten bucks.... but I don't know where you are?
Please e-mail me at: brodi@telus.net
Posted on Mar 24, 2009
  • 6 Answers
SOURCE: Transformer blew on Hk395 speaker sysytem
I think I remember it being in the 12-24VAC range. If you are still interested I will open mine up and measure it.
Posted on Aug 16, 2009
buffalonyman
  • 1865 Answers
SOURCE: 600 low voltage transformer hook up to 3 outside pedestal lights
bulbs or wiring
Posted on Aug 18, 2009
How volt transformer for AOpen spekers?
If it is the transformer, it should be a DC output. Look where it connects, it will tell you what voltage you need. Use a volt meter to see if you are getting that from your "transformer". If so the amp in the speaker is probably blown, if not you need a new DC power supply with the correct voltage. If the replacement ma is higher that will not hurt, The information should also be on the "transformer".
May 31, 2016 | AOpen Audio Players & Recorders
Does a ATX power transformer makes the difference of watts of a power supply unit of a computer? Exactly I am planning to improve performance of my pc's ATX power supply unit. Trying to attach another...
NO NO NO... PC power supplies are switching supply's. The transformers use high voltage to drive other components. Increasing the power out of the supply will require you to upgrade the power supply to a higher wattage output.
Oct 23, 2013 | Microsoft Computers & Internet
No output from Orbit transformer Model # WT41-2600300AU, transformer rated output is 26volts, 300ma. Only transformer I have been able to find is Orbit # 57040-10C, 24vac, 750 ma. Is this supposed to be...
The 750 ma transformer is fine. The only concern you have is that it matches voltage. The higher amperage is what it is capable of delivering. It would be like plugging a radio into a circuit with a 15 amp breaker or a 20 amp breaker. My transformers are 1250 ma, 24 volts. The 24 volt transformer will probably give you the 26 volts of your old unit. It is fine to use.
Gary
Sep 15, 2011 | Orbit Sprinkler System Power Source...
How many parts in transformer & briefly explained
Firstly - DANGER.Power can kill so be very careful.
These can be made of a couple of parts but are sold as one peice.Check your manufacter for more info.
How Magnetic Iron Core Transformers work........
the transformer has a pair laminated wires normally copper or iron core wrapped around in a tight coil called windings.they are independant circuits not electrically connected together(x2 wires = 2 Circuits)
this creates a magnetic effect when power is applied to one end and mutual inductance creates a power output at the other end.Like a magnet really.
There are some transformers that have a multi voltage outputs called TAPS which will have different voltages to the input voltages.
ie
Input in New Zealand can be 230volts
Output can be 12 volts or 5 volts or 230volts
depending on the applications required,
for example
Street Transfomers can be 11,000 volts INPUT stepping down to 230volts.OUTPUT for your household power
or
Garden lighting transformers output can be 12volts but still be 230volts input
or
computers power packs can be multi voltage outputs of 12 volts,9 volts,5volts but still 230volts input.
There are also Electronic Transformers available too.
Commonly used for dichrioc Halogen downlights in homes or the office,
Apr 26, 2010 | Sunbeam Transformer (ICTRBA) ATX Full...
Power to printer but printre will not turn on as there a reset
Are you using a volt/ohm meter to determine that the transformer is supplying power to the printer?
If so, what is the input (measured at the receptacle) to the transformer?
What is the output of the transformer and is it supplying the correct amount of voltage (output voltage requirement is normally found imprinted on the body of the transformer or in the technical specifications section of the printer's manual.
Don
Dec 01, 2009 | Canon i860 InkJet Photo Printer
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
I need to change the transformer inside the power supply. can you tell the the output voltage?
You need a meter to test the voltage else check the manual or normally it is written on the transformer about power,voltage and current.Hope this helps.
Jun 25, 2009 | Polycom SoundStation Accessories:...
Looking for technical manuals
I talked to 3 different departments at ITI, they all say you can't get them anymore (sales, tech support, and repair) No one even has a number for a refurb equipment company.
LINE CARRIER POWER TRANSFORMER
: : ITI part #60-145-235 Canada part #60-366
: : The power transformer supplies a DC voltage of approximately 13 to 14 VDC (unloaded) to the CPU through terminals 1 & 2. Additionally,it contains the line carrier circuitry for the Wireless Interior Siren through terminal 3. The AC power indicator voltage for the CPU is carried through terminal 4.
: : The Transformer is fused with a 400 mA fuse on the primary side of the transformer. Replace only with a 400 mA 250V Time Lag Fuse (ITI Part #33-023).
This is all I could locate, hope something here helps.
please leave rating. thank you
May 06, 2009 | Computers & Internet
Power adapter / transformer voltage, is this a safe combination?
brosent88,
do not use a transformer that is not a match to the original. go to a radio shack or contact the company that made or marketed your frame for a replacement transformer.
Jan 04, 2009 | Cameras
Pyramid 14G power supply
Hi.
It very unlikely the voltage went down. I think you should re measure what the voltage should be yes it 13 volt is after the bridge you wil get this with dual 6.5 volt ac from the transformer, they don't change voltage unless you have a short at the output, and if you did you will blow the transformer, is your reading from 2 wires or is it three wires, output, the center to the end should be 6.5 and end to end maybe 13.8.
I would need to see the schematic to know what voltage you should be getting.
I wouldn't look on a bat transformer but ether, bad bridge or wireing.
I hope this help's
What About Bob
Feb 10, 2008 | Audio Players & Recorders
Hardware & Accessories Logo
153 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
