Question about Kenmore 24 in. 16193 Stainless Steel Built-in Dishwasher
Kenmore Energy Star model 8575287 - no lights, no power
No lights flashing. Reset breakers. No power.
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
Only reset you can do is unplugging power cord for 10 minutes.
The control panel it is probably faulty and in need for replacement.
Posted on Jul 19, 2008
Kenmore electric range model 790 door lock light flashing
Hi, When door locks, This is when oven is in self clean mode. After the heat has cooled down the door should release again. If this does not work try turning the power off to the stove (breaker) This should reset the stove to normal. Call a repair man if this continues. Good luck.
Jun 01, 2015 | Kenmore Kitchen Ranges
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore Dishwashers
I need energy star rating for kenmore refrigerator #795.71309.012
The 795.71309.012 was built by LG for the Kenmore line. You can buy a copy of the Energy Star Rating label from Sears Parts Direct or other appliance parts store for a few dollars. It is part number MEZ62603802; see http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/MEZ62603802/0046/795/Model-79571309012/0582/0161000?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=F1201020&diagramPageId=00004&productTypeId=x&searchModelNumber=79571309012&subCompDesc=Refrigerator%20parts%20%28pantry%29&brandDesc=KENMORE&modelDesc=REFRIGERATOR&blt=11&shdMod= .
Unfortunately the 795.71309.012 is not listed at the EPA Energy Star site any more. (It's no longer qualified due to changes in the energy efficiency requirements.)
I wish that I could be of more assistance.
Jun 09, 2012 | managemylife.com Computers & Internet
I have a Kenmore 8575287 The clean button is blinking and when I push start it just blinks and does not start.
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Jan 27, 2011 | Kenmore Dishwashers
The clean light won't stop flashing...
Some Whirlpools to reset the sequence, push Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry with the door open and then close the door and hit cancel. Push the buttons as fast as you can - within 4 seconds. Also you can try Normal then Heated Dry then Normal then Heated Dry within 5 seconds to reset. Try those and see if it resets.
You can also try turning off the breaker to the dishwasher for 30 minutes and turn back on as long as the breaker isn't supplying your refrigerator too as in some countries where several appliances can be tied to one breaker, but in the USA, the dishwasher usually has a single breaker for itself.
You can find a troubleshooting guide found inside the door panel in which the screws are taken off and the door slips off and the troubleshooting guide (or tech guide) will be found there and probably is found there with your model. For others with different Whirlpools models it is found by removing the kick plate panel at the bottom of the dishwasher and it is usually glued there. It will list troubleshooting solutions you can try for your dishwasher and diagnostic codes for your dishwasher.
The flashing light is probably an indication that something caused the cycle to not complete, whether the water isn't hot enough or a faulty motor or several things, but the troubleshooting tech guide will help address that.
Apr 09, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Freezer Alarm keeps going off...
I think your freezer's coils have been damaged. Consult a enjinner.
Aug 10, 2009 | Kenmore Freezers
Is my fridge energy star rated?
ALL ENERGY STAR APPLIANCES HAVE A "ENERGY-STAR LABEL" USUALLY LOCATED ON OR NEAR THE MODEL AND SER. NUMBER TAG OR LABEL. CHECK ON THE BACK OR INSIDE THE REFRIGERATOR WHERE THE COLD CONTROLS ARE LOCATED.
Apr 26, 2007 | Kenmore 53612 / 53614 Side by Side...
Kenmore 24 in. 16193 Stainless Steel Built-in Dishwasher Logo
50 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
