Question about Kenwood KAC-9102D Car Audio Amplifier
Rockford P550.2 going into protect mode
I have a Rockford Fosgate P550.2 pushing a kicker CVX 12 and when it starts hitting good it will go into protect mode and then come back on after a few minutes, then shut back off.... Can anyone help?
  • 3 more comments
  • hoops2coupes Oct 09, 2007
    it's only for about 20 seconds it shuts off then comes back on, it's not really hot
    How do I figure out the amps ohm load?
  • hoops2coupes Oct 10, 2007
    it's a dvc and if they are wired like an X is that in series?
    it's the 4 ohm impedance
    amp is not bridge
    nah amp is not bridge I have it on one channel
    the thing is I know it's not the amp because I've hooked up 3 different amps to the sub and it's made them all go into protection, and the weirdest part is in the mornings it works fine, of course once I really get it hittin it shuts off but in the evenings it constantly shuts on and off every 30-40 seconds  could it be a bad ground?   I am stumped man
    how would I go about running each coil per channel? have two sets of speaker wires comin off of it?
    well I'm almost positive it's not the amp, I've hooked up 3 different amps and they've all done this, funny thing is most mornings, I can have no problems with it, I can turn it up and it will play for a while until it goes out, but in the evenings it's going out every 30-40 seconds or maybe longer
    as far as running one coil per channel how does that work?  does that just mean I would have to sets of speaker wire coming off that one speaker?
    Man I appreciate all the help you have given me, I feel as if I'm almost near the solution.  Thanks again.
    Jed
  • 631 Answers
Does it shut off for a couple of minutes or a couple of seconds? Is the amp hot when it shuts off? Are you sure you have the speakers wired to an acceptable ohm load for the amp? Have you measured the voltage at the amp (across the B+ and ground terminals) to make sure it's not dropping too low on hard bass notes?
Posted on Oct 09, 2007
  • 2 more comments
  • Anonymous Oct 09, 2007
    Is your woofer a single voice coil or dual voice coil?
    How many ohms is EACH voice coil?
    How is the speaker (assuming you have only one) connected to the amp (bridged or not)?
    If it's a DVC woofer, are the coils wired in series or parallel?
    OR... are they each connected to one channel of the amp?
  • Anonymous Oct 10, 2007
    It sounds like the speaker is wired in parallel (both positives together and both negatives together).
    If so and each coil is 4 ohms, that's a 2 ohm load. The amp shouldn't have a problem is you have the speaker connected to one channel. If you have it connected to the left positive and right negative, it's bridged and that's why the amp is shutting down.
    Unless the other channel is defective, you should connect one coil per channel. The output would be the same but it would distribute the load instead of running one channel at its lowest possible ohm load.
    If it's not easy to run one coil per channel, move the speaker to the other channel to see if the problem remains.
    If you run one coil per channel, you will connect individual speaker wires to each coil and then connect each coil to it's own channel.
    If this problem existed with 3 amps, it could be a voltage problem. Often a loose or corroded connection can cause a voltage drop which can cause an amp to shut down. I've also seen defective fuses cause the same problem. Glass fuses in fully enclosed fuse holders are the worst. If you have a multimeter, measure the voltage across the B+ and ground terminals of the amp when it's shutting down. If the voltage is dropping significantly, doublecheck all of the power and ground connections.
    The problem could also be the speaker. You may want to try disconnecting one coil at a time to see if one coil in the speaker is causing the problem. When one coil is disconnected, insulate the unused wires so they can't short to another terminal or to each other.
Have you tried using bigger gauged wires? If the amp can not pull enough power through the wire it can cause it to run into protected. This solved my problem running a 2000W amp on 12 gauge wire, went to 8 and it worked great.
Posted on Nov 14, 2008
SOURCE:
Hey I have a rockford fosgate t2500bdcp-1 when ever the bass is about to hit the amp goes to protect mode and comes back on
If you can tell that it is about to hit and the amp goes into protect mode, the amp is being over driven on the input.
Feb 06, 2017 | Rockford Fosgate Car Audio & Video
I have a Rockford fosgate P4004 with two 12'
I think you are right about the "fried" part. It would have to be opened up and repaired to be able to use it again
Oct 29, 2012 | Car Audio & Video
What number of cable should use on rockford fosgate 1 farad capacitor thanks
If good brand name wire, jl rockford monster kicker, the 8 gauge wire will be fine. if buying it at walmart or somewhere, then use 4 gauage wire
Jul 19, 2010 | Rockford Fosgate 1 Farad Capacitor Cpc10...
HOW TO HOOK UP 1 CVX 12 FREQUENCY TO HAVE AMP ON
speak english sorry to sound like a **** but this sentence makes no sense.
Apr 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
I have a rockford fosgate p5002 amp. I have 2 alpine 12" type-r's. I just got them bridged together and my amp keeps going into clipping mode. i tried turning down my gain and adjusting my frequency but it...
Hi unbridge the subs and run them sterio your overloading the amp and its going into protection mode. if you have anymore questions about car audio feel free to ask me...
Feb 05, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Multi amp hook-up
honestly i dont think those to amps will push cvxs no matter how you wire them up.
the rms on the 200 should be used to push a door speaker.
the 800watt should deff just be hooked to 1 cvx but still wont max it out.
Dec 25, 2008 | Rockford Fosgate Punch 301M Car Audio...
I have a Rockford Fosgate Puch 1000 watt amp "thermal" problem
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up without the thermal LED being lit, the wiring needs to be checked. If it still indicates that it's in thermal protection, it needs to be serviced. A local repair shop will be the quickest. Rockford will email you the schematics.
Apr 07, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Rockford Fosgate 501bd question
that amp should work fine with those speakers,just make sure that they(speakers)are wired for 2 ohms.at 500-600watts coming from amp, you should be getting 250-300 watts per speaker,just dont crank your gain too high on the amp.
Aug 29, 2007 | Rockford Fosgate Power 501BD Car Audio...
Kenwood KAC-9102D Car Audio Amplifier Logo
286 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
