Question about Rowenta Perfect Iron
Rowenta steam iron water leak DW9080
Rowenta DW9080 iron leaks water out of the base. Have used spring water, tap water, and cannot get the iron to quit leaking.
SOURCE: Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Posted on Sep 03, 2008
wizzard8955
  • 18 Answers
SOURCE: iron leaks water from the back end of the base
This problem is the way that rowenta seals the water tank. If the iron is disassembled and the seal is properly put on it will not leak,, however this seal is a silicone based product and not just an off the shelf gasket. I have sealed and repaired some using a high temp silicone
Posted on Mar 06, 2009
brnspncr
  • 67 Answers
SOURCE: THIRD leaking Rowenta
Try buying a cheap one from wallmart or some similar store. They are not too dear so you can use them until they fail and then buy another cheap one.
Posted on Aug 04, 2009
aferrell09
  • 105 Answers
SOURCE: I have a Rowenta steam iron and it has been
the loss of steam is from usually from a barrier or o-ring or some sort of insulating material it has to be sealed because if it is not the the steam will not build up the pressure required for adequate cleaning power, try to seal up where the water is coming from, and yes you should be able to use something to get rid of the build up just make sure you rinse it all out so it wont mess anythng up and tap water is fine you will just get that build up from it cause of the chlorine and other products in tap hope this was helpful:)
Posted on Nov 16, 2009
heatman101
  • 43501 Answers
SOURCE: Rowenta model 1700W. Water leaks out front of iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
Leaking & no suddenly no steam available
the steam tank is leaking. Buy a new iron.
Jul 18, 2016 | Rowenta Irons
Rowenta superpress DG 050 leaks water while steaming all over garment. Do I need to Descale the unit?
I've had the same problem with two Rowenta irons. When set to a lower temperature, the iron has a bad habit of leaking water when the steam option is on. I have to either turn up the temperature setting or shut off the steam option.
Feb 28, 2015 | Rowenta Irons
We have Rowenta DM 890 steam iron. It dumps water. Also Why not use distilled water?
The following web blog about Rowenta steam irons has some tips on maintaining the iron:
http://www.nasa1.org/iron%20rowenta.htm
The following web blog explains the issue of not using distilled water:
http://ths.gardenweb.com/forums/load/laundry/msg011421358265.html
I guess the bottom line is that it takes a higher temperature for distilled water to boil. It also explains that will cause the unit to spit, drip, and leak.
Try affordable spring water, and you should get better results.
Jan 27, 2011 | Rowenta Irons
Cleaning a Rowenta steam iron
According to the manual, you should use regular tap water as long as it is not above 12 grains of hardness. Never use 100% pure distilled water, Rowenta recommends using inexpensive bottled spring water.
Jul 18, 2010 | Rowenta Effective DX1900 Iron with Auto...
ROWENTA STAM IRON - NO STEAM !!!!
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
My Rowenta iron is leaking down by the cord. can
heatman101
Oct 16, 2009 | Rowenta Professional DE880 Iron
heatman101
Mar 23, 2009 | Rowenta DZ1700 Iron
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
Iron leaks water from the back end of the base
Sep 26, 2008 | Rowenta Power Duo Iron
Jul 14, 2008 | Rowenta Perfect Iron
Rowenta Perfect Iron Logo
71 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
