SOURCE: cannot delete events from Sentient N663HH 4 camera DVR system.
go to hard drive setup
you will need to overwrite over it.
go to overwrite on your set up and select yesto enable to overwrite harddrive when capacity is full
SOURCE: Sentient 250GB DVR-RW CCTV N63HH - recording for longer peroids
Just reduce the frame rate slightly on each camera or the record quality and it will increase the data retention period.
SOURCE: just installed a sentient 250gb
By default it goes to VGA port out of the DVR.
So you could hook up a pc monitor to it and use that. Once logged in you can change to tv out via the desktop menus.
It is also possible to hold down a button on the DVR (cannot remember which one sorry) at DVR power up to switch it to use tv out instead of vga.
SOURCE: sentient dvr cctv playback
Hi, I have a maplins sentient model Sentient dvr cctv is there a windows 7 PCviewer programe ?
Yes, and yes.
The HDD light shows when there is disk activity.
After system boot-up, hold a right mouse click
button and there will be login window. Hold a left
mouse button to click the order of "Account", and
input correct account. Then left click the order of
"Password" and input correct password. At last
left click "Login" to enter system. There is one
factory-preset login "account/password"
"admin/111111" at admin level. The user can
use it to login the system for the first time
