Question about Paxar Monarch 9403 Thermal Printer
When I load my 1131 the labels do not print correctly
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
May 08, 2014 | Seiko Smart Label 240 Thermal Printer
Loaded ribbon correctly according to Zebra S4M Quick Reference guide....but won't print anything on labels.
The ribbon has wax just on one side. So, if nothing prints on the label, first thing I'd check if the ribbon loaded with waxed side facing label.
Jan 11, 2011 | Zebra S4M Thermal Label Printer
Monarch paxar 1110 pricing gun brand new. The box was thrown away and it isn't working. The label prints out without a price the ink is fine we tried it on a different gun. Any trouble shooting ideas??
Here's a video that shows how to properly load supplies into the gun. It's possible that the supplies aren't loaded properly..
http://www.racoindustries.com/monarch-1130-1131-1136-labeler-loading-video.htm
Dec 27, 2010 | Paxar Monarch 9825 Thermal Label Printer
My new hp 2035n printer give an error when i try to print. the error says: load paper to tray 1
Instructions Things You'll Need:
  • Inkjet printer
  • Labels
  1. 1
    Prepare your printer. Make sure the power is on and the drivers are installed correctly on your computer.
  2. 2
    Wait for printer to stop. Make sure your printer is idle or ready or waiting for paper to be loaded. Don't load labels when your printer is already printing or running an operation.
  3. 3
    Prepare your labels. Make sure they are all facing the same way and are right side up. The label side should be face up. Many labels have an up and a down as well, look for a "this side up" or "load this way" indicator. Or take a look at the print preview before you print and make sure your labels will be fed correctly.
  4. 4
    Find the correct paper tray. Some printers have manual feeds and automatic feeds. Refer to your manual to find out which one you should use for labels. If you are going to use the manual feed, follow the manual's instructions. However, most printers will use the automatic feed, so read on.
  5. 5
    Align the paper guide. This is a moveable piece on the paper tray. There should be markers for the width of your paper. Standard pages are 8.5 inches. Move the marker so your labels will fit.
  6. 6
    Load your labels. Place your labels in the tray so it touches the immoveable side of the paper guide. Slide the paper guide over to touch the other side if it is not already close. Do not bend the labels by pushing in too far.
  7. 7
    Find the paper thickness lever. Try looking under the door that lets you change the cartridges. Or search around on the back or side. Check your manual, too.
  8. 8
    Set your paper thickness level. Usually you'll use the standard size. However, your printer may need to use a thicker setting. Check your manual.
  9. 9
    Change your media type. In your printer settings, find the media type option. You can access settings by clicking properties or settings on the print dialog right before you print. Select "labels."
Oct 02, 2010 | HP P2035N LaserJet Monochrome Printer
Ok this stupid paxar 1131 gun is a pain in the ***, is there a video to show how to load this gun?
Here's a video on how to properly load gun...
Sep 02, 2010 | Paxar Monarch 9403 Thermal Printer
I am using a S4m printer to print on non zebra labels, by direct printing ( not thermal paper) I cant get what i'm printing to print in the middle of the page. I have tried every possible setting but I...
You need to make sure the printer is calibrated correctly. If you press the feed key, does one label come out and stop at the gap? Do the labels have a black mark on the back of the liner? This would tell us if the printer is set correctly. (Mark or gap). We need to make sure the labels are loaded correctly and the printer is set correctly. Then we move to driver and software settings. I have 10 years experience working for Zebra, so I will get you the resolution once we determine the current setup.
Oct 16, 2009 | Zebra S4M Thermal Label Printer
Labels are blank
Check first ribbon and the label are OK. After check the darkness settings are correct. And finally prints a test print.
Mar 13, 2009 | Zebra 110PAX4 Thermal Label Printer Print...
Zebra 105SL label issues
I am surprised that you are using that sequence of buttons to solve this problem. I am pretty sure that they want you to go into the "Media Sensor Calibration" setup in the config menu. It is a bit more complicated than what you have described. I also believe that the size of the gap on two of your labels might be out of tolerance (they are usually 1/8" gaps between the labels). The black marks are a problem for the transmissive sensors. You may need to move the transmissive media gap sensor (remember it has two parts: upper and lower). I would usually setup mine for a place beyond the black mark so that you are looking at just the white paper.
To start out:
1. Load the backing of a 6" strip of media (no label attached).
2. Remove a ribbon (if you usually use one).
3. Close the printhead.
4. Press SETUP/EXIT and then NEXT/SAVE until "Media and Ribbon Calibrate" appears.
5. Press "+" to start the calibration procedure. You should see the "Load Backing" in the LCD Display. You already have the backing loaded so continue to the next step.
6. Press "+" to answer the message and the next screen should say, "Remove Ribbon". You have also removed the ribbon.
7. Press the "+" to continue. You should see the screen say, "Calibrating Please Wait". After the sensors are setup by the machine a new screen should appear, "Reload All".
8. Open the printhead, and move the labels until they are loaded correctly to print. Smooth out the ribbon and load it correctly.
9. Withe media and ribbon now loaded, press "+" to continue and the machine should say, "Media and Ribbon Calibrate".
10. Press the Setup/Exit button once. It should say, "Save Changes Permanent". Press Next/Save to finish the process.
11. Do a normal calibration of your stock and print a label.
You are done. The machine will run for the labels you have setup the sensors for. Unfortunately, you must do this for each of the media types. To automate this, you could run a Configuration listing, capture the settings you just created for each type of label. Take these to a programmer to have them send the setup to the machine before the job. This is beyond the scope of this type support to really help you.
May 13, 2008 | Zebra 105SL Thermal Label Printer
Epsom Stylus Photo R300
Yes I had a similar problem and in fact returned my printer for a replacement. You need clearance as the CD tray emerges some 2.5 to 3 inches behind the printer. If the tray hits an obstacle it is unable to correctly line up for printing and the trat is rejected
Dec 24, 2007 | Epson Stylus Photo R300 InkJet Printer
Paper feed
The feed rollers are slipping on the surface of the label, causing the page to load incorrectly. There is no permanent solution at this time. Try one of the following workarounds to correct this issue. Workarounds Workaround 1 Adjust the top margin using Page Setup.
  1. Click File , then Page Setup in the program being used, (accessing Page Setup may vary from program to program. Refer to the Help file for that program).
  2. Adjust the top margin until printing is correct on the label.
Workaround 2 Manually print one sheet at a time. Place one sheet of labels in the input tray at a time, printing only that page. Repeat for all pages of labels needed.
Nov 20, 2007 | HP PSC 1210 All-In-One InkJet Printer
Paxar Monarch 9403 Thermal Printer Logo
Top Paxar Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Paxar Office Equipment and Supply Expert? Answer questions, earn points and help others
