Question about Radio Communications
Realistic Pro 2023 Manual - Radio Communications
5 Suggested Answers
TOLhamRadio
  • 509 Answers
SOURCE: I lost my code sheet and I can't program my
Radio Shack has a pretty good search feature for old instructions on their website. You will need their part number off the unit, which will be something like "20-321". Do a search and you can get a PDF instruction manual for it online.
Posted on Dec 29, 2009
BillB-SA
  • 2761 Answers
SOURCE: I need to reprogram my Realistic Pro-2023 police
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Posted on Feb 21, 2010
BillB-SA
  • 2761 Answers
SOURCE: i need codes for my
Codes? Assuming that you're looking for frequencies, you can find a comprehensive database of active frequencies in your area, and a lot of other useful scanning information by visiting:
Bill B.
Listening in since the 60's
Posted on Dec 26, 2010
  • 3 Answers
SOURCE: i have a realistic pro-2023
i also need same manual have contact no for someone who may be able tosupply
Posted on Mar 24, 2013
How do i program realistic pro-59 scanner
http://support.radioshack.com/support_electronics/8567.htm
don't know what you will pickup. Nearly all law enforcement, ems, fire have gone to digital trunked systems that are encoded. The above link has a link to the operating manual. You will need to know the frequency of whatever you are wanting to listen to.
Aug 28, 2016 | Radio Communications
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Dec 18, 2015 | Radio Shack Radio Communications
Good Evening Pam
Radio shack has a listing of Scanner resources here:
Radio Shack Realistic Scanner Manuals The materials for the Pro 58 are here
http://support.radioshack.com/support_electronics/8570.htm and gives access to specs, parts list, features, and a guide to scanning. It's very mid-20th century in appearance, including using type-writer style fonts.
Hoping this helps!
D
Looking for a manual for a Realistic Patrolman Pro 40 UHF/VHF Scanner. I don't even know what kind of power supply it needs.. LOL
Hi, that unit looks to be a mobile scanner and if I'm seeing right then you would need a Base power supply that could supply 12volt to it. Course you could also use a computer power supply and find the 12 volt line out on it. Here is the link to some spec's for it. Looks also to be crystal controlled so it cannot be reprogrammed. Good luck.
RadioPics Database RadioShack Realistic PRO 40
RadioShack Realistic Pro 40
Sep 06, 2015 | Radio Communications
I have a realistic pro-2023 lost manual and can`t reprogram it ,have u any ideas.....................baz
You can download and print the operating instructions for your scanner, at no cost, here:
http://support.radioshack.com/support_electronics/doc18/18513.htm
Bill B.
Jun 12, 2011 | Radio Shack Pro-2018 Scanner
I need codes for my realistic pro 2023 scanner
Bill B.
Dec 25, 2010 | Uniden BCT7 Base Scanner
Realistic patrolman pro16A radio scanner, do not know how to program freq, this scanner does not have crystals, does anyone know how or have a manual??
I have checked several sources, and they all show that the PRO-16A is a 16-channel VHF/UHF CRYSTAL scanner. Remove the bottom cover and you should see the crystal sockets.
http://radiopics.com/RS-Realistic/PRO-16A.htm
Bill B.
Oct 14, 2010 | Radio Shack Radio Communications
I lost my code sheet and I can't program my scanner any suggestions? It's realistic Pro 2023 Scanner
Dec 29, 2009 | Radio Communications
How can i program a realistic pro 2023?
Hi there - I will admit I am no expert with scanners but I did find these instructions that will hopefully tell you what you need:
http://support.radioshack.com/support_electronics/18517.htm
Aug 28, 2009 | Office Equipment & Supplies
Realistic pro 2010 scanner
to program
turn on unit, press program button, key in frequency ###.### press enter. keep advancing thru the channels with the program button until finished
Jun 24, 2008 | Audio Players & Recorders
Radio Communications Logo
24 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
