How to use washing machine Lenco - Washing Machines
I need a wire diagram for my bernina 830, please help I am out of commission until 8 get this back together! ! I have the original machine manual but that doesn't go into the wiring of course! I had to...
You will have to deal with this site being in German but it's not difficult to get to grips with. The site is a bit randomly disorganised (much better than it used to be). You'll find lots of other information scattered about the site.
Try the following links:
S21 Elektrik 1 Herzogenbuchsee Info BERNINA Service Tipps Lenco Switzerland
S22 Motor Service Herzogenbuchsee Info BERNINA Service Tipps Lenco...
and here:
830 Record Serie Herzogenbuchsee Info BERNINA Service Tipps Lenco...
I hope this all helps.
Mar 17, 2015 | Brother Sewing Machines
Why does my lenco l90 turntable cut out when near the end of playing a 45
If you search Google for the model manual you will find a PDF of it.
A quick look at it says turn the auto return switch off.
Aug 20, 2014 | Audio Players & Recorders
Bernina 830
Need more information about the nature of the problem but in the meantime, take a look at the site below (in German unfortunately).
BERNINA Startseite Herzogenbuchsee Info BERNINA Service Tipps Lenco...
Jun 13, 2014 | Bernina Sewing Machines
Lenco ipod tower
Power cable may work fine but the power supply is burned out and needs to be replaced
Feb 19, 2014 | Computers & Internet
Lenco 17ips17
Look on www.shopjimmy.com. They have repair kits for many problem tv's. Lots of TV parts.
Dec 31, 2013 | RCA Mikomi 5290925 15 in. LCD TV
How to start lenco LMW-2651BJ WASHING MACHINE
need the english manual for lenco lwm-2651bz washing machine.
Jan 22, 2012 | Washing Machines
Hi, my washing machine is LENCO LWM-2651BJ my problem on my machine is when he reach to drain it go off and he cant drain the water, i bought this machine in israel and i send it to philippines and i dont...
Possible that the drain valve/pump is faulty.Now this can be failure of the pump/valve or the pump is clogged with dirt and so does not work. You need to first check the voltages on the drain pump at the time of drain, if not present the program controller is faulty but if present the valve/pump is faulty. remove from the drain outlet hose fittings , remove the pump and clean or back-flush with jet water, test outside for the pump to work freely , if not the pump is faulty and must be replaced.
Apr 23, 2011 | Washing Machines
SIR. I NEED LENCO XEMIO 766 8GB MP4 PLAYER DRIVER. THANK'S BABUL HOSSAIN
I have a problem with my lenco xemio 766 . When i no my lenco xemio 766 it's not working . every time he is loading.
Feb 12, 2011 | Audio Players & Recorders
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
