Question about Reddy Heating & Cooling
How to bypass the thermostat on a torpedo heater
How to bypass thermostat on my torpedo heater
if you do this it will just run all the time and possibly over heat.
Dec 06, 2016 | Heating & Cooling
How to bypass photocell
It would be very unwise to bypass or remove the photocell on your heater, it is there as a safety control, if the heater doesn't ignite or while running unattended runs out of fuel, it will stop. Without that safety net it will just keep going, and the result could be disastrous. It would be better to cure the problem caused by the photocell, and then return to use with it the way the heater was intended. What was the problem??
Mar 02, 2014 | Reddy Kerosene Heater with Thermostat:...
When plugging in my reddy heater 110 it blows air & no heat and then goes off.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 12, 2011 | Reddy Kerosene Heater with Thermostat:...
HEATER WILL SPARK BUT WILL NOT IGNITE
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 07, 2010 | Reddy Kerosene Heater with Thermostat:...
HAVE REDDY 55, I GET NO FIRE TO THE SPARK PLUG,
heatman101
Nov 20, 2009 | Reddy Kerosene Heater with Thermostat:...
Heating & Cooling Logo
192 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
