Question about Brother MFC Office Equipment & Supplies
MFC7310 complains about paper jam - but there is none in the path. It is clear thru. Is this a known problem
  • 2692 Answers
SOURCE: Paper Jam detected. None found.
Here is the Xerox support page for your printer. It even has a movie on removing paper jams.
http://www.office.xerox.com/perl-bin/product.pl?page=sprt&product=8400&country=United%20States&language=en#_manuals_and_documentation_
Posted on Jan 04, 2009
  • 131 Answers
SOURCE: printer says paper jam but there is none
Look Inside of each cover on the printer & see if there is a small piece of paper inside. Also, check if there is loose dust from the paper built up by the sensor switches. If none of these work, try flipping the sensor switches manually. Sometimes these get stuck in a particular bad paper jam.
Posted on Feb 12, 2009
SOURCE: says paper jam but there is none. pixma mp450
Take any paper out of the paper feeder and get a plastic ruler the softer the better lift the top of the printer up so you can see where the print cartridges are now push the ruler down through the paper feed roller be careful because you could break the rollers go from left to right right to left twice and check for any debris once you have done this unplug the printer for about 20 seconds then plug back in and let it reset then try copying or printing a doc and see how you go!
Posted on Mar 11, 2009
FixinFax
  • 3085 Answers
SOURCE: HP 3015 Laserjet paper jam error message
The paper is probably jammed between the fuser and the rear cover if you can't see it.
Posted on Aug 18, 2009
  • 2385 Answers
SOURCE: Have completely cleared papaer path, unable to
you can get the technical support from Epson Official site HERE
Good Luck
do rate the solution if it helps
Posted on Nov 28, 2010
I have a lexmark e238. Keeps showing paper jam light after cleaning rollers even though no paper is in there.
Either paper is moving too slow through the paper path or one of your paper path sensors is not registering. Pull the paper tray out and check to make sure the little plastic sensor is swinging free. That sensor tells when the tray is empty. Follow the paper path thru the printer checking all the sensors to make sure they are "opening" and "closing".
Apr 07, 2015 | Lexmark E238 Laser Printer
Paper jam
Hi
Try turning the printer off and on.This is known to automatically push out the stuck paper.
Look through the paper paths and remove any obstructions/stuck papers.
Clear any print queues.
Disconnect the printer completely from power,wait for a while and then connect again.
Hope it helps.Thanks!
Mar 06, 2012 | Canon PIXMA MX860 All-In-One InkJet...
Hello. I have a xerox docuprint 2125. When i go to print it says that there's a paper jam and to open the front cover, but there's no jam. I remove the paper tray, open the front cover, it resets and the...
This printer has a straight flow through path.
* Situate the printer so that you may clearly get to the back of the device.
* Open the rear door path and check for the presence of any paper in the path there.
* If none. Then you need to check the area around the fuser.
* Permit the printer to cool for several minutes.
* Release the side catches and open the top of the printer.
* pull out the cartridge.
* inspect the area around the fuser. You might see a paper jam there. Clear and reassemble.
Mar 22, 2011 | Office Equipment & Supplies
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
For message 3.0 PAPER JAM [LOCATION]
means
A non-specific paper jam occurred.
Soln
1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation.
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
Printer did not show ready status, showing 13.20 error
13.20 is a generic jam message that appears when there is a piece of paper stuck in the printer or one of the flags in the paper path is stuck in the wrong position. Most times this error occurs when one of the flags in the facedown assembly is in the wrong position. One thing you can try is to turn off the power and open the right side door below the manual tray and sitck a piece of letter paper in that opening and then close the door. It will not quite fit right but try your best. Now turn on the printer and after initialization and warm up the printer will attempt to clear the paper path and will feed that sheet thru. If it goes thru the error may now be gone, but most times the paper will jam entering the facedown assembly and stop since there is a piece of paper stuck up there or the the flag is preventing the paper from moving. If it comes thru but you still have the message then one of the 2 flags in that assembly is stuck. Good Luck.
May 31, 2010 | HP LaserJet 9500n Printer
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
New out of the box 13:20 error paper jam there has never been any paper in machine we're just setting up. open and close front, then theres a fuser jam lift and close top, front door again.We have paper in...
PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
Jun 24, 2009 | HP LaserJet 3600n Printer
Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
