Question about Pioneer VSX-455 Receiver
Why poweroff keep on flashing
Sound wont come out the speaker
My friend kept turning it up and i kept turning it back down then it just said poweroff
Sounds like your "friend" has cooked something. It could be one of your speakers (do they all sound ok for the 5 seconds it runs?), or it could be the receiver....
I would try disconnecting all the speakers and see if it stays on. If so, it may be one of the speakers. Connect them one at a time, and see if you can tell.
Nov 10, 2015 | Pioneer VSX-D308 Receiver
Why does my pioneer stereo say POWEROFF and not turn on
Most likely it is going into a safe mode as one of the speaker connections might be creating a short in the audio amplifier. Check speaker terminals connections. The model number of the unit would be helpful to know.
Aug 15, 2014 | Audio Players & Recorders
Battery led flash when turned off
Good day,
It sounds like you may be putting your laptop into "sleep" mode.
Depending on your operating system installed on your laptop.
Make sure that you Shutdown or Poweroff via your operating system to turn your laptop completely off.
Dec 10, 2012 | Computers & Internet
After turning on my reciever i get a flashing poweroff on the display. unit then shuts down
check your speaker connection. if that doesn't work check your fuse to make sure it's good.
Mar 03, 2011 | Pioneer VSX-D510 Receiver
When I turn my optimus STAV-3770 on it reads poweroff and then cuts itself off..please help me
unfortunately most stereo mfgs. install a protect (shutdown) citcuit if it detects an internal short (bad amplifier )or a external short( bad speaker)....disconnectl speakers see if it still shuts down if so there is a genuine component failure inside..however if it stays on then in all likliehood its a bad speaker
Sep 07, 2010 | Optimus STAV-3770 Receiver
Receiver issues- VSX-816 K
the speaker is not broken, its the receiver, cuz i have this model, and now it just flashes a blue light on the power button and it wont turn on. I had the same problem as you before it did wat is doing now. i ran the speakers on my vsx-3900s, and they didnt mess up at all, they only did it on the vsx-816
Apr 06, 2010 | Pioneer VSX-816-K/S Receiver
I have a VSX D710S and it flashes poweroff then
Im having this same problem. It happened after I had the music up really loud for about 3 hours. Also, where it has the volume all i see is -- instead of a number when i try to turn it on
Nov 29, 2009 | Pioneer VSX-D906S Receiver
"POWEROFF" display comes up randomly
there may be broken soldering points in the receiver take it to a workshop or open it your self and check it on the power source
Jul 02, 2007 | Pioneer VSX-D509S Receiver
POWER OFF alert
When you turn on receiver it will power off. Poweroff shows up and than turns off. if the front panal reads over load the output ic pac001a is defective i had repaired this model before
May 29, 2007 | Pioneer VSX-D710S Receiver
20 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
