Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Kyocera km 3035 error code 0630 - Kyocera Mita KM-3035 All-In-One Laser Printer
SOURCE: KM-3035 scanning issues
the 30/40/5035 series machines have two network cards in them. One for printing and one for scanning. and they have separate IP numbers also. make sure you have scanfile utility running on your pc or wherever you are sending the files and the folder set up in the utility. then set it up on the scanner network card.. Not the printer.
Posted on Jun 19, 2008
SOURCE: Kyocera KM-3035 - Paper Jam 00 error. Paper removed, still not working.
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Posted on Aug 15, 2008
leroyal
  • 2120 Answers
SOURCE: What is the code for KM-3035 printer's scanner network card?
Print/Scan System (U) 083H9503 Network Print Controller and Network Scanner
Posted on Feb 13, 2009
  • 66 Answers
SOURCE: Kyocera KM-3035 System Error C0240
this is a printer error
it sound like you tried to update the printer firmware with an unzipped file from an incorrect print system
you need to format the cf card on the PC first then you need to format it on the printer, you will see the card option when you go into the user printer menu. it is print system U
Posted on Mar 10, 2009
  • 66 Answers
SOURCE: 0630 Fault code on KM 5035
you have a defective main PCB. you should contact your nearest service agent
Posted on Mar 21, 2009
How to fix system error c6050 on my km-3035
It is a fixing assembly error code. The thermistor doesn't detect heat. Kyocera you replace the fixing assembly. You may be able to reset.1087 1087 gets u into served mode go to reset and activate.power off and on.
Feb 02, 2015 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
KM 5035 0630 FAULT CODE
Fuser failure , enter service and reset fuser error.
Jul 15, 2014 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Solution of error code 7410 for kyocera mita 5035
When Your Kyocera Mita KM 5035 Indicates Code 7410, It's the problem with your Drum Unit Or Drum. You Can Solve This Problem Either By Changing If You Have Another Drum Or Buy A New Drum Unit.
May 23, 2012 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Km-3035 (kyocera) send email from scanner key, eveything seems to go fine, but no one gets emails, going into history of sending I find error E022. manual is no good, it give no codes. searched google, no...
The E022 error indicates -
The mail contained an e-mail address that the SMTP server can not find.
Check to make sure that the destination e-mail address was entered correctly.
The link below will take you to the manufactures web page where you can download the Scan System Operation Guide (Function Edition which list the error codes.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=11796&rid=14242
If you continue to have a problem you can go to www.gfbm.net for more assistance, also they have some Kyocera setup and troubleshooting information.
I hope this is helpful,
Shawn
Feb 24, 2011 | Kyocera Mita KM-3035 All-In-One Laser...
My kyocera km 5035 has an error code of c 2642. Any suggestions?
C2642 is not a listed error code for the KM-5035.
C2600 is deck conveying motor / desk motor problem.
C4200 is a LSU (laser unit) problem.
Jan 27, 2011 | Kyocera Copystar CS-5035 Copier
I have mita km3035 but when is working shows an error 0630 and then stop.so i have to turn it off and wait few seconds and turn it back on to continue help me please
Sorry to hear this.
A C0640 Is a DMA Problem:
• DMA transmission of compressed, decompressed, rotated, relocated or blanked-out image data does not complete within the specified period of time.
Solution:
Defective main PCB.
More than likely you will need to replace the main board.
Hope this helps.
Aug 21, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
Mar 13, 2009 | Kyocera Mita KM-5035 Printer
Feb 12, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
ID Code for KM-3035
i want to change the id code for km 3035 kyocera how to chang
Jul 30, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
133 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
