Question about Cricut Expression Cutting Machine
Repair manual for cricut - Cricut Expression Cutting Machine
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    Cricut expressions 2 pressure wheel
    You say you have a Cricut expression 2 but you say quote"...of how to reset the machine including the rolling of the dials up and down three times!" The problem I have in sorting your problem is that the Cricut expression 2 does not have wheels which work the speed, pressure and size. If you have an expression version 1 machine then there would be 3 wheels on it to adjust the speed pressure and size. Obviously if you have had the machine for 4 years it is out of warranty and I am not sure just what the person did to "fix" your problem. I do recollect a video on you tube with a similar problem however looking at the video he mentions that once it is fixed the blade housing should bounce up if you push it down, does your housing now do the same as the video. In the video Evan did he mentions at the end that the soldering of these wires may not take the first time so this may be a point to check as he mentions that it was travelling the machine that caused the wires to break in the first place. The youtube.com video I am speaking of is http://youtu.be/n7LJnfPdd08, by Evan Craftman. I am assuming that when you called cricut support you called the UK support line. I often speak with support in the USA being from New Zealand it is an overseas call however I have found them very good. If you are able to I would like to see a video of just what your machine is doing. If you dont want to post it here you could email me flohillrennie@gmail.com.
    I do feel very sad that you don't wish to try the Explore as I find it a surpurb machine. I have had my Expression version 1 since early 2009, I have added every Cricut to my family of cricuts and own 3 expression 2's and now an explore. If you had bought a computer 4 years ago and you currently took it to a repair person to get it fixed I am sure their first response would be it would be better to get a new one. Your computer boards appear to be fine maybe you need to take the video to the person who did your fixing as most people who do this sort of work would not understand how the machine runs. I hope this helps and you can get your Cricut working again. If all else fails you may be able to buy a 2nd hand one cheep and have your repair person change the carriages completly.
    Jun 13, 2014 | Cricut Expression Cutting Machine
    Cricut repair
    usb port broken on cricut expression 2 can it be fixed
    Sep 08, 2013 | Toys
    I have the cricut jukebox but no instruction manual. Where can I find one?
    http://content.cricut.com/c/downloads/JukeboxManual.pdf
    There you go :D
    Mar 01, 2011 | Computers & Internet
    The cricut blade holder doesn´t go up or down.
    My housing was not going up or down. Every time i wanted to make a cut it dragged and cut shapes in half. So when I took it apart I pushed it up and down myself and noticed that it was very difficult. So where you see the coils, I lightly sprayed WD40 (my cricut is out of warranty, I would not advise to take apart if you are still under a warranty). I lightly sprayed until it was easy to move up and down. When your done be sure to wipe any access WD40 that dripped to the bottom. This fixed mine and thank goodness because I was close to pulling out my hair! Hope this helps someone else!
    Jul 26, 2010 | Cricut Expression Cutting Machine
    I need a manual for my Cricut Machine. I got one on E-Bay and it come without a manual. It is the smaller one. Any idea if I can download the manual or find it on line?
    Have you been here? http://www.cricut.com/ ?
    You may find someone here who has this manual but ... and this is BIG ... Terms of use agreement for this site prevent any contact between us (Question asker and Question catcher) outside of this forum. We have the larger model Cricut and, for the cost, I would get the manual to you - but I cannot jeopardize my standing here at FixYa.com for the buck or two that I might receive from this transaction.
    Most people who answer questions here are volunteers working out of their home, like me. If there is a large depository of instruction manuals here on this site, I have not discovered it.
    If all else fails, I would suggest that you send a e-mail to the company (at the above address) and ask to purchase the manual or the CD that comes with your make and model.
    Thanks for your question and I hope you find your manual. Did you try asking the person you bought the device from?
    By the way, we love our Cricut! You will have a lot of fun with it.
    Feb 12, 2010 | Provo Craft Cricut Disney Font Cartridge
    Cricut makes loud grinding noise and will not turn roller bar
    My wifes' cricut seems to have had the same problem. Try turning off the power, then manually slide the cutting carriage to the left look inside to the right. you should see a red button pull on it until it clicks. power up the cricut and see it it works. it solved the problem for my wife.
    Jan 02, 2010 | Provo Craft Toys
    Jpeg file onto a cricut
    Cricut does not accept jpegs. They use their cartridges that come with the machine and others that you can purchase. However if you have Cricut Design Studio you can design your image with the cricut. Any further questions feel free to ask.
    Dec 02, 2009 | Provo Craft Cricut Disney Font Cartridge
    Cricut Expression Cutting Machine Logo
    59 people viewed this question
    Top Cricut Crafts & Hobbies Experts
    R.A. Ellis
    R.A. Ellis
    Debbie
    Are you a Cricut Craft and Hobby Expert? Answer questions, earn points and help others
