Question about Dryers
Hunter fan 27302. I connected a Hunter 27302 as per instructions, & confirmed power going in OK at 110v. Unit will not come on (lights or fan). I re-checked my wiring connections, & they are OK as per manual. What now? ps: I re-tested the old fan I replace using same power in as new Hunter. Is ther a problem with this model??? Any suggestions? P.
Master_Tech
  • 770 Answers
SOURCE: manuals
I thinkl you can order the manuals from www.sears.com under the parts tab enter your model # also if it is an electric dry it is 220v with a neutral leg check with the local electrian to see if the power there is phased..Hope this helps
PS::The washer and the refrig will work on the tranformers
Posted on Jan 22, 2008
  • 8 Answers
SOURCE: REPLACING POWER CORD
White to center, red on Right, Black on left, Green goes to case or external ground screw.
Posted on Mar 27, 2008
  • 5 Answers
SOURCE: hunter fan/light control wiring
solution depends on how many wires are in the ceiling box. was there a ceiling fan in place before? were the light and fan controlled by seperate switches or was there only one switch? if two switches, then there should be two seperate hot wires in the ceiling box. if only one switch, then only one hot wire in box. if only one, then your black and red from the fan will wire together to the single hot. green goes to the bare copper wire, if not one, then not needed
Posted on Aug 14, 2008
SOURCE: Kenmore HE4 no power to control, no sound, but the drum light bulb on when door opened
I have the same indications. It power up intermittently with the check lint LED lit. The manual said it will (lintLED) turn off when the start button is press but only gives me a beep when I press start. Lint LED only turn off when I open door. The dryer will function normally. I disassembled lint assemby and clean it thoroughly, including moisture sensor. I run a diagnostics, all LED lit with 88 displayed on panel. The second 8 flash with a continous beep. I check the power cord and removed panel but have not done a continuity check. The dryer is working now.
Posted on Aug 18, 2008
Greg20
  • 149 Answers
SOURCE: Replace a 3 wire power cord with a 4 wire power cord.
red on one end, black on the other, white in the middle, green to cabinet ground.
Posted on Jun 12, 2009
How can I replace the receiver on hunter tribeca ceiling fan
The black & white on one end go to the house wiring. The other three go to the fan wiring. Black to black, white to white & connect last two wires together.
Aug 17, 2014 | Hunter 52" Ceiling Fan With Light And...
Wattage limiter hunter ceiling fan
As per the Energy Policy Act of 2005, all ceiling fans manufactured or imported into the United States must utilize a light bulb wattage limiter as of January 1, 2007. This limiter limits the capacity of the fan's light kit to a maximum of 40 watts per bulb. Not very bright at all!
Put in LED lamps and save a lot of work. Go to: http://www.youtube.com/watch?v=7WeWSKNe64A it will show you how.
Oct 18, 2013 | Hunter Ceiling Fan Light Switch Control
I have a Hunter Ceiling Fan Model No. 27185. I can control the fan with the remote but can not control the lights with the remote. is there some instructions on how to operate the system?
27185 is the model # of the remote. Check to make sure your light wires are connected at the light fixture & receiver. Also, make sure your dip settings are set on the same frequency. Lastly, push the light button & pull the chain on the light.
Oct 06, 2013 | Hunter Dryers
Hunter ceiling fan fan is working but lights are not
Make sure light wire is connected at the ceiling & at the bottom. Otherwise it's probably the receiver. 1-888-830-1326 ( Hunter parts )
Jan 05, 2013 | Hunter 52" Ceiling Fan With Light And...
We have a hunter ceiling fan with light kit. When we turn on the light all light blink. What could be causing this?
a lose wire in the fan/light housing. the motion of the fan is moving it creating a short. I wouldnt us it till it gets repaired. Its a pretty basic unit, kill the power, and drop the light housing and check all connections. If not in housing, check connection in the ceiling, you got a lose wire somewhere.
Mar 12, 2011 | Hunter Ceiling Fan Control Switch
Hunter fan model 21617 remote fan won't turn on light from wall switch
You mean only the light? and the fan is working? Have you checked the light bulb? If it's ok, then checked on the wall switch. If is also ok, then probably there's is something wrong with the wiring in the fan.. It's either a bad or loose connection
Jul 01, 2010 | Hunter Ceiling Fan Light Switch Control
DIP Switches don't seem to matter
You need to completely power off (wall switch or breaker) when changing the dip switches. Not just power off from remote because it will keep previous setting. I learned it the hard way....
Sep 14, 2009 | Hunter 27185 Remote Control
Hunter Fan model no.22570
take it back, and explain to them it will not work. you should be able to get a new one !!
Aug 16, 2008 | Hunter Ceiling Fan Light Switch Control
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
