Question about Logitech LX7 Cordless Optical Mouse
No mouse well my conputer rec. the mouse but i have no commnocation between mouse and screen
  • ken1226 May 27, 2008
    same issue..reconizes the mouse, but no communication between screen and mouse....what to do???
  • cmgm May 11, 2010
    i have recently bought a wireless mouse from yard sale and thats all i got how do i adapt it to my comp. to work?
I have the same issue.. i think its the lil reciever radio is dead or something
Posted on Sep 06, 2008
SOURCE:
Cannot install my memory card reader
Put Your Card reader then put u r driver cd in u r Dvd Rom.
Go to Desktop then my conputer right clik mange ,divice manger, see any yellow colour question mark or add New hardware, keep mouse pointer top in the questin mark,then right clik update driver
Jun 20, 2011 | Computers & Internet
Purchased new laptop and wireless mouse, first day worked great, after a week tried to use mouse again.....just not working have replaced battery no luck
I would try unplugging the usb receiver and restarting the computer.
Then plug it back in.
Sadly, with these, along with replacing the battery, that's the only option.
Mar 12, 2011 | HP Wireless Optical Mouse
I am a casio fx-82MS user. i would like to know how i can convert polar form to rectangular form in my calculator
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
I just realized that your question pertains to the FX82MS but is listed under the FX115ES (That is quite a difference) So my answer above does not concern you but I will leave it as is should anyone need the answer for the FX115ES.
Look at the enclosed screen capture for the FX82MS
Nov 13, 2010 | Casio FX-115ES Scientific Calculator
How do you use the pol and rec
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Jan 19, 2010 | Casio FX-115ES Scientific Calculator
How to convert polar to rectangular form
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
Hope it helps
Oct 18, 2009 | Casio FX-115ES Scientific Calculator
I have installed wireless soft ware but mouse not doing anything
Normally you don't have to install the software, your computer has tons of drivers and software already built in. When plugging it in did your pc install the drivers and say your device is installed ready to be used? If its a cordless mouse make sure the batteries are good and some of them have a learning button you have to press then use the mouse so the receiver recognizes the mouse. Also if there in interference it will cause the mouse not to work , You never want to put the rec. on top of the tower (causes interference). and if all else fails it could just be a bad mouse kit. Take and swap for another.
Aug 09, 2009 | HP Wireless Optical Mouse
Can't get mouse to work when i hook it up. put rec. in mouse port ant it won't light up. the tranmitter will but the rec won't.
First replace the batteries in the mouse and insure they are inserted correctly.
Next make sure the mouse switch (if it has one) is on.
The mouse and receiver should be close enough and without obstructions to work. Once they work you can experiment with where to put the receiver as the mouse will stop working or get sluggish if the receiver is not close enough.
Next press the connect buttons on both the receiver (if it has one) and the mouse within 30 seconds of each other.
Allow about a minute to see if they connect up.
I am assuming it is not a software problem.
May 19, 2009 | Computers & Internet
WRONG IP ADDRESS
download the for the exact type of router you have and check also the manual of setting there should be descrive all configuration you need to set.
Dec 10, 2008 | Computers & Internet
Sp/2 connections faulty
Hi again,
Seems that you posted twice. Here's the  link to your other post with a response.
Cheers.
Oct 24, 2007 | Microsoft Multimedia Internet Keyboard...
Logitech LX7 Cordless Optical Mouse Logo
46 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
