Question about Kenmore Washing Machines
My kenmore washing machine is stopping mid-cycle and reading f6 on the panel
My Kenmore Quiet Pak2, model # 11045872404, serial # CST 1917529, is stopping mid-cycle and reading F6 on the panel. it happens mainly during the rinse or spin cycle.
The F/06 error according to the official repair manual is a Motor Tachometer error . . the error is triggered because the main control board loses communication with the tachometer either a short in the wiring or a short in one of several other places. . The tachometer sits on the spindle of the motor and has two wires from the spindle to a wiring hub on the left side of the motor . . . two of the black wires are for the tach then feed to the MCU (Motor Control Unit) in the bottom left facing the washer which then feeds the info into the main control board which is at the top on the machine under the top cover. Some find that checking the connections with a volt meter is a starting point however in most cases you will not find issues with electrical continuity, the manual has the expected readings. The MCU is known to go bad in these machines so that would be the first suspect in resolving the error, however it could be the wiring, the motor or the main control board. The MCU costs around $200 so consider the possibility that it may not solve your issue. The error may even be sporadic only happening on heavier loads in the tub.
Posted on Nov 25, 2014
  • 1003 Answers
SOURCE: kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Posted on Jan 24, 2008
SOURCE: Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Posted on Nov 11, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
SOURCE: Washer won't spin- flashing "f 02"
in the HE3 series it means the drain tube or pump is clogged
Posted on Mar 10, 2009
SOURCE: Kenmore HE4t Won't continue drain cycle Code F6 & beeping
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
Posted on Apr 19, 2009
Kenmore elite quiet pak2 washer-in the time remaining/de l at display a y, digital numbers are flashing and sometimes read08,8:88,0:88 and when I choose a setting and press start the machine locks the
Sounds like the control panel is defective or you have a stuck key on the unit. Check the control panel for any obvious cracks, damaged, etc. if all else fails, you'll have to replace the control panel.
Jan 09, 2015 | Kenmore Washing Machines
I have a kenmore elite total care flex king size capacity plus quiet pak2 oasis that makes loud noises like a airplane when its in the spin cycle Model #110.28032701 which parts should be change?
If the washer is roaring during spin, the bearings are bad and you will need to replace the outer tub assembly.
Here is the part to order.
The part comes with a 365 day, any part, any reason return.
Nov 03, 2012 | Kenmore Washing Machines
Unresponsive control panel on Kenmore washer 110.280 327 01
check and make sure its not set on delay mode first,if so press delay button till it cancels delay time on readout
May 11, 2012 | Kenmore Washing Machines
Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elete 45862401 Quiet Pac2 front end washer that stops during the wash cycle. it flashes a f6 error code. The manual says it is a loose wire between the mcu and/or control panel,shipping...
With the front door open, see if you can rotate the basket freely.  If not, most likely the bearing of the rear tub is worn out.  You will have to replace the whole rear tub which is about $300 for the part.  I am having the same issue with my Kenmore Elite Quiet Pak 2.  I'm contemplating with just buy a new top-load washer.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
I have problems with my kenmore elite quiet pak2
hi thanks for the question the dlf code for the duet says drain pump remove bottom panel the pump is on the right but there is a big nut in the front remove the nut use bucket as water will come out and clean filter thanks please accept and a positive feed back is nice thabks the appliance doc
Sep 17, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
54 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
