Question about Jensen VM9215BT
How to change the strip on the Jensen VM9215BT
2 Suggested Answers
SOURCE: how to bypass brake jensen vm9215bt
Did this work? none of the codes (543210 / 1264) work for me. I dont want to hardwire it.
Posted on Feb 03, 2013
Wire schematic for a Jensen vm9215bt
Request the schematic diagram directly from Jensen.
Sep 24, 2016 | Jensen Car Audio & Video
Where can I get replacement screen for Jensen VM9215BT
From all electronic spare part selling shops. An easy to get replacement part, indeed.
Jul 04, 2016 | Jensen Car Audio & Video
Jensen vm9215bt car radio will not power up
Are the fuses okay? With the ignition switch off, you could hook up a temporary wire from the chassis of the car (the outside metal part of a cigarette lighter is a good ground) to the backside of the radio. Once secured, you can try the stereo again.
Sep 14, 2014 | Jensen VM9215BT 1-DIN 7" Widescreen LCD...
Where do i ground my vm9215bt
Any bolt that connects to the metal would be good. I simple test light can be used to check for a good ground. If none are close, simply make your own with a self tapper screw and ring terminal. Most of the grounds are located around the steering column area.
Brake bypass
Just ground the wire for the parking brake to anywhere on the frame of the car.
Jan 04, 2014 | Jensen VM9215BT
I just bought a Jensen vm9215bt head unit. And I do not know how to hook up my subwoofer. I have three cables coming from my amp. I have one of them so the amp will turn on, I have that one connected. But...
Most amplifiers have a common color code to hook them up. On your head unit, there should be a blue wire. That is your amp. Turn on lead. The positive + symbol goes to your battery +. And that lead is usually red. Your negative terminal - is this symbol and the wire s usually black. That either goes to the - side of the battery or grounds to car chassis. The sound inputs to your amp. either by RCA cables or high speaker level input. That depends on your amps. set up. If you have any questions, post back and I'll try to reply by next day or two.
Oct 02, 2013 | Car Audio & Video
How to bypass brake jensen vm9215bt
Oct 22, 2012 | Jensen VM9215BT
Usb problems on Jensen vm9215bt unit
Too many subdirectories is most likely the problem.
The stereo may have limitations like 8.3 standard. That means a file can only be 8 characters long with a 3 character extension. Or 256 for folders, including paths. This is old school naming restrictions.
Oct 14, 2012 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
I know that I need a new main strip wire internally. Where can I order one? Thank You benhughes82@yahoo.com
  • For this you really need to contact Jensen directly and order one from them. I have the link set to your unit @ Jensen's website http://mobile.jensen.com/search/?sku=VM9410 You don't want to take a chance with some cheap aftermarket cord with a $650usd deck.
regards, Tony
May 21, 2011 | Jensen VM9410 Car DVD Player
Will this remote work for any jensen pop My knob for the volume wont turn my volume up any more now im trying to see wil this remote help me?
carefully take batteries out of the remote locate any screws there might be holding it closed. pry open CAREFULLY with flathead screwdriver and separate circuit board from function strip with RUBBING ALCOHOL on paper towel gently wipe off if anything from front of circuit board do the same to magnetic buttons on underside of function strip put back together w/New batteries you should be good to go
Aug 27, 2010 | Jensen 143307 Remote Control
Jensen VM9215BT Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
