Question about Gemmy Toys
I need the snow pellets for my inflatable snow globe
3 Suggested Answers
richroth
  • 9472 Answers
SOURCE: Snow Globe snow pellets have static & are
In dry weather conditions, some static may be seen, this should only be temporary during such weather. Also after years of use, the pellets may lose some of their anti-static protection. You may try using an anti-static spray on the pellets to help prevent such an occurrence.
Posted on Dec 03, 2010
SOURCE: my gemmy inflatable snowglobes ( 2) are not blowing snow
I am having the same problem the globe is inflated and the characters are rotating but no snow its all bunched up on the bottom and doesnt blow all the way up if you get an answer from gemmy its a miracle. if you solve it please contact me at marriageishell@aol.com thanks.
Posted on Dec 15, 2010
Craftmans Snow Thrower 247887001 Tire Flat. How to Refill.
The tires are probably tubeless type. If the bead is broken ( not sealed to the rim) the tire will not inflate. Taking the weight off the tire will some times allow the bead to seal against the rim and allow tire to be inflated. You can also put a small ratchet strap around the tread of the tire and tighten it up. This will squash the tire and make the bead seal up. MAKE SURE to loosen strap as soon as bead seals and tire begins to inflate. Hope this helps.
Jan 01, 2014 | Garden
Airblown snow globe instructions
"snow" is small styrofoam pellets that get sucked into the blower on the bottom..there is a sort of recycleable drain in the base that allows the pellets to be reblown over and over..HOWEVER if the unit gets wet, the pellets stick together and will not go through until dried out..to dry.. use a hot air blowdryer to heat the material carefully ..as it is nylon.. it can melt...then the pellets and drain may need unplugged..(unstuck)
Dec 15, 2013 | Cars & Trucks
I bought a snow globe and I can't get it to charge nor turn on. My pc won't even recognize it. What is the deal and do I just need to send it back? It is a Unison Digi-Snowglobe with DPFMate...
I also have this same snow globe bought it in Pigeon Forge, TN this Christmas...today I decided to pull it out and use it and guess what?? It wont come on and my computer doesnt reckognize it either...Did you ever get yours working?? If so how?? Thanks
Dec 18, 2012 | Sakar Cameras
Blower motor
This is a common problem with the inflatable snow globe. Regretably you can only obtain a replacement on the planet kuku in the zooloo star system. Good luck as it is three million light years away.
Dec 02, 2011 | Cars & Trucks
My 6 foot inflatable snow globe won't blow the snow inside,the fans and motor are working just fine it just wont blow the snow it just sits in the bottom...
Maybe the problem is condensation. The globe gets all fogged up and the snow pellets start sticking to the plastic and it just looks like a mess. Temperature might be less of a concern where you are, but it is something to consider. I had briefly thought of putting something like a hair dryer in line with the main fan to keep the inside temperature up. But it turned out to be more of a problem than I wanted to deal with. Good luck though!
Dec 20, 2010 | Gemmy Inflatable Polar Bear on Motorcycle
Need a new moter model SJD-B2 so we can fix our penquin snow globe. do you carry this so we can order one? 120 volt 60hz 0.442a 3130rpm
My Gemmy blower worked great for a Christmas inflatable. At season end, I packed it into it's bag and into the box. Next season, lights light, but blower won't spin. The motor sounds like it wants to go, but no spin.
I removed the blower base, opened the blower housing (the part where the air comes out. I dropped about a dozen drops of 3M household oil on the shaft , spun it a few times and let it set.
Three hours later, blower works just fine.
I suppose the trick is to oil the shaft before it gets packed away.
Dec 06, 2010 | Gemmy Industries Corp. Airblown 9 ft....
My gemmy inflatable snowglobes ( 2) are not blowing snow this year. The fans work fine- the globes inflate- but the snow just sits in the bottom of the globe. If I shake the globes the snow works for a few...
Dec 12, 2009 | Gemmy Toys
I have a disney snow globe that has a rusted music box and the fluid is low in the glode. How should it be repaired?
Hi
i hope my advice will help you. What I would do is the first thing is take it to a ceremic workshop they have all clock parts music box parts phone parts as when people make these they sell them the parts and show them how to put them in if that dosent work or you are not near a ceremic workshop try a clock or a watch maker they will take a look and might be able to repair it. If not I would then go out look for a music box find the company that made it or the company that makes snow globes just type it into google manafactures of snow globes or who makes snow globes and send it off to them but call them first and ask them if they could fix it for you they will usually say yes either drop it into the repairs area or send it to them but you will have to call first.
Hope that helps
Aug 07, 2009 | Disney Princesses Beauty and the Beast...
PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Feb 07, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Toys Logo
146 people viewed this question
Top Gemmy Toys Experts
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
