Question about Palm TX Handheld
Cell phone connection
Is there anyway to connect my cell phone which is blue tooth capable to my pda? It is not listed as one they support
You could go to palm.com and update the list of phones-it worked for me.
Posted on Dec 03, 2007
6ya staff
SOURCE:
After i paired a bluetooth headset with my Nokia E5, it disconnects / connects every 30 - 45 secs. When I make a call or listen to music when bluetooth is connected the line crackles so much that you...
some units cannot handle blue tooth. Check to make sure yours is blue tooth capable. If it is, check your settings both security and blue tooth to ensure there is no conflict. Also check the headset for compatability ratings. Sometimes that is why there is interference.
Jul 04, 2011 | Nokia E5 Cell Phone
Unable to connect bluetooth to another cell
Some of the carriers actually have a lockout on Blue tooth transfers. So depending upon your carrier even tough the phone itself is capable it may not be allowed. I work at US Cellular and all the B tooth options on these phone are unlocked, however they are unable to link to a verizon or sprint phone for example without having their associated data plan.
The process for doing the pairing is rather simple and if you followed the steps and they still wont its a lockout.
Go to your blue tooth setting on one of the phones, turn the find me mode on or make visable to others.
take the second phone and go to blue tooth check registered devices and click new search. once you find the other phone click pair and eenter in 0000, the other phone will ask if you want to pair in which case enter the 0000 pass code again.
Once paired if you are transfering pics or music go to your media library or pic gallary and find the fill. Select options and send via blue tooth, it will bring up the registered list and select the phone you are transfering to. that should be all you need to do, if it says not supported or unable to connect the BT is disabled and you need to speak with your wireless carier for assistance.
Nov 20, 2010 | Cell Phones
Can not transfer songs from my old phone to my new phone via blue tooth the both phone have connected but when i try to send information it comes up not connected
Hi, you will need pair both phones together before you can be able to send .
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 20, 2010 | HTC Wildfire Cell Phone
How to connect a blue tooth with cell phone
HOW TOCONNECT BLUETOOTH
Take care.
Aug 08, 2010 | Cell Phones
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
Take care.
Jun 28, 2010 | Nokia N73 Cellular Phone
Bluetooth will not stay connected on my 2006 BMW z4
Depending how far of a range your getting, between your razr and your blue-tooth is important. Any range of 30ft or over is less likely to connect/search/and or pair with any capable blue-tooth device.
Try pair the two devices again, but remember to save the trusted blue-tooth to your device so that disconnection can be prevented only by your command.
If your blue-tooth has a short, or battery is extremely low then that TOO can cause disconnection.
Hope this information can be of a benefit to you. Thanks.
Mar 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Conecting blue tooth
You did describe the full question.
If you have facing some problem while connecting via blue tooth check you these sittings
you phone have name in blue tooth
your phone should be visible on
And you should one it while connecting to any device then you can search for any blue tooth device.
Let me know if you have any other question regarding this topic.
Nov 18, 2008 | Cell Phones
Blue Tooth
Go to active device menu and delete all the listed devices in it and then start a fresh search
Oct 09, 2008 | Motorola Mobility RAZR V3m Cellular Phone
How do I disconnect my phone from another Blue Tooth device?
Go to active devices menu in the bluetooth menu and delete any devices listed there and start find new device ... it should work fine ...
Oct 08, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Palm TX Handheld Logo
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
