Question about Dynex Dx-wbrdvd1 Blu-ray Wifi Player - Blu Ray Drive Not Working - Fixable
I cant connect to the internet
It says wired and i want wireless
    New Friend:
  • 18 Answers
What error message you get when you try to connect to wifi network ?
Posted on Dec 19, 2013
Need to know where antenna card is located on my p25 toshiba laptop
The Wireless Module is located on the Bottom of the laptop,
http://www.irisvista.com/tech/laptops/ToshibaP25/disassembly/big/Toshiba_SatelliteP25_03.jpg
The top card to the left. (With the red arrow)
White Wireless Antenna wire, and a Black Wireless Antenna wire.
You can see which terminal the White wire connects to. Leaves the other terminal for the Black wire.
Beginning page of pictorial disassembly guide, (Page 1),
http://www.irisvista.com/tech/laptops/ToshibaP25/SatelliteP25_1.htm
Page1::Page2::Page3::Find another model, is in White, and on the Top of each page, and Bottom of each page.
The Wireless Antenna wires attach to the Wireless Module,
http://www.ebay.com/itm/WIFI-WIRELESS-PA3299U-1MPC-Card-for-17-Laptop-Toshiba-Satellite-P25-/170900245815?pt=LH_DefaultDomain_0&hash=item27ca72cd37
Looks to me the White wire to MAIN, and the Black wire to AUX.
The Wireless Antenna wires then thread up through a cavity (Hole), in the laptop body, and go through/by the Right Hinge.
From there they go into the Display Assembly, and connect to the Wireless Antenna,
http://www.irisvista.com/tech/laptops/ToshibaP25/satP25_LCD.htm
http://www.ebay.com/itm/Toshiba-P25-Satellite-Laptop-WiFi-ANTENNA-K000006070-/220547282983
Scroll down, read the description.
The Wireless Antenna wires route through CHANNELS, and LATCHES.
The Wireless Antenna wires MUST go back in the SAME routing they were originally.
Failure to do will cause the laptop to not go back together correctly, and can cause damage to the Wireless Antenna Cable. (Wires)
[Pinched/Broken]
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 06, 2013 | Toshiba Satellite P25-S607 Notebook
Cant connect to d-link DIR-615 wirelessly, can someone help me?
What is the operating system on your laptop?
Can you access the Internet if you connect the computer to the router with the Ethernet cable?
If the wired connection is working then it must be the problem with the wireless network.
If the wired connection is also not working then you may need to reset and reconfigure the router.
If only wireless is not working then you can try creating a new wireless network and then connect your laptop to the new wireless netwok.
I can suggest you a website which may help you for Home network connection.
May 20, 2012 | D-Link DIR-615 Wireless Router
What's your problem?cant connect internet to wiihooked wire to computer and wii console went through steps to connect and cant connect
you connect it to the internet, not the comouter, plug it into your wireless router, wired router, or cable modem, not your computer
Oct 11, 2011 | Nintendo Wii Console
How do i set bridge mode?
Depends if you need a wireless or wired bridge?
Here is some info for you.
Infrastructure Mode
With a wireless Access Point, you can operate the wireless LAN in the infrastructure mode. This
mode provides wireless connectivity to multiple wireless network devices within a fixed range or
area of coverage, interacting with wireless nodes via an antenna.
In the infrastructure mode, the wireless access point converts airwave data into wired Ethernet
data, acting as a bridge between the wired LAN and wireless clients. Connecting multiple Access
Points via a wired Ethernet backbone can further extend the wireless network coverage. As a
mobile computing device moves out of the range of one access point, it moves into the range of
another. As a result, wireless clients can freely roam from one Access Point domain to another and
still maintain seamless network connection.
Wireless Bridging Overview
Using Wireless Router as a Wireless Access Point
May 03, 2011 | NetGear RangeMax WPN824 Router
Cant get online
Before you can go online on the PS3, there is need for you to have either a wireless lan network or a wired network with an ethernet cable.
If you are using a wireless network, here is how you go about it
  1. Make sure your wireless Internet connection is active and at full strength. Unplug the PS3's Ethernet cable if it is plugged into the system.
  2. Turn on the Playstation 3 game console and select "Network Settings" under the "Settings" option in the main menu.
  3. Select the "Internet Connection Settings" tab and select "Yes" when the system displays a new screen saying you will be disconnected from the Internet.
  4. Select "Easy" on the next screen that asks what type of installation you want to use.
  5. Select "Wireless" when it asks you what type of Internet connection you have.
  6. Select "Scan" on the next screen.The system will search for all available Internet connections in the area.
  7. Select your home Internet connection when the screen pops up displaying the available Internet options. Select your security settings and enter your encryption key. Save your settings.
  8. Test the connection by selecting the "Test Connection" option. If the connection has been made, your network information will appear on the screen.
If you are using a wired connection. just go over the same steps but select the wired connection instead of the wireless connection.
Hope this was helpful? Please comment for more information.
Jan 21, 2011 | Sony Playstation 3 (PS3) Console
Can anyone tell me whose the best... the wired or wireless broadband internet connection....please anyone..
wired one is best if you dont worry about mobility in terms of speed wired is faster than wireless one ;-)
May 20, 2010 | Computers & Internet
I need to know u r wireless networking
you can find whether your network is a wireless or wired by verifying your router. step1:see whether your are having one incoming wire and outgoing wire. step2:rigth click on network place which is on desktop step3:click property
step4:there you can thus your network is a wired or wireless
May 10, 2010 | Motorola Canopy 5.2 GHz Wireless Access...
Cant change wired to wirles on my ps3
Settings->Netwirk Settings ->Internet Connection Settings->Custom and there u can change it :) have Fun
Apr 16, 2010 | Sony Playstation 3 (PS3) Console
I cant connect using my linksys wireless adapter...it was working fine before but when i downloaded LELA in my wired pc, the adapter stopped working thus, my 2nd pc is not connecting to the internet..
  • hard wire the laptop to the router, which reestablishes the connection.
  • set the connection to be wireless
  • follow the prompts and you will soon be wireless again
Sep 13, 2009 | Linksys WUSB300N Wireless Adapter
Dynex Dx-wbrdvd1 Blu-ray Wifi Player - Blu Ray Drive Not Working - Fixable Logo
103 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
