Question about RCA Audio Players & Recorders
RCA Recorder/Player CDRW120 shows recover message half way thru record mode. Why?
Recording works only part way thru then recover message appears. Copying from disc CDRW to CDR.
  • 112 Answers
SOURCE: RCA CD recorder/player CDRW120
You sure it's recognizing the CDR? And you are using 'consumer audio' cdr? Watch it at all times. If it 'opc fails' after you put a blank in it still shows as a CDR and 0:00 on the display but won't record. It's easy to miss.
Posted on Feb 20, 2008
SOURCE: i have a RCA model no; cdrw121 2 disc
Hardware problem. Replace the flat cable of the recording optical pick-up, if that doesn't work replace the unit. A replacement recording pick-up isn't available commercialy.
Posted on Oct 28, 2009
Testimonial: "that answer was very helpful,a local tech told me to replace the unit,thank's for the conformation."
  • 49 Answers
SOURCE: my rca cdrw120 2 disc cd recorder does not play or
firstly call customer service to see if here are updates on this unit, else, there are two possibilities, the mechanism-which you can easily identify if the cd is spinning at all. the second is that a new optic assembly is required.the first you can do,easily; the second you can research before putting money into it.
Posted on Mar 04, 2010
SOURCE: not able to record cd get message unreadable cd
I found out that memorex cds that have on the package (for use in audio recorders)work every time.They're red label packaging,I hated buying cds only to find out they dont work. Dont forget READ THE LABEL look for (use in audio recorders)
Posted on May 07, 2010
dunnbiker
  • 8546 Answers
SOURCE: Please I need instuctions to
http://www.retrevo.com/support/RCA-CDRW120-CD-Players-manual/id/402ci673/t/2/
Posted on Feb 11, 2011
Got an RCA CDRW 140 Dual Disc Recorder but there was no manual for it. How do I record from a Disc with music on it to a blank disc?
Search rca website for instruction manual or just google the model number followed by instruction manual
Nov 10, 2010 | RCA CDRW120 2-Disc CD Recorder
I would like to hook up my 50 disc CD player to this unit
That should be easy. Not knowing what model 50-disc unit you have I'll assume it has at least one analog Audio Out RCA pair and maybe one or more of the possible digital outputs that correspond to the digital inputs on your CDR.
Simple: compatible Outs on the source go to compatible In's on the recorder. Ta-da!!!
Apr 21, 2010 | RCA CDRW120 2-Disc CD Recorder
Not able to record cd get message unreadable cd
Dec 24, 2009 | RCA CDRW120 2-Disc CD Recorder
Need directions to record from annalog input
go here
register and search for RCA CDRW120 for a free download of the manual.
May 06, 2009 | RCA CDRW120 2-Disc CD Recorder
Need Manual to RCA CDRW 140 dual tray CD recorder
this is how i got a free manual, go to google search, type rca cdr140,
than look for radioshack.com click it and look for rca cdr140 in the
drop down list,click it and look for owners manual, you will need
adobe reader to download the entire manual for free. enjoy.
let me know what happen gmoye1@cox.net
Feb 26, 2009 | RCA CDRW120 2-Disc CD Recorder
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
CD's won't play in other machines
Your problem is an easy one.....you need to "finalize" your completed/burned CD first...then it'll play in tray A...and others. Good luck....from Middleman
Feb 07, 2009 | RCA CDRW120 2-Disc CD Recorder
RCA CDRW120 CD RECORDER
go to the rca website www.rca.com and look under support for cd burners look up ur model and find parts list then call or email rca to send you distributors number and call them order part pick it up and install it good luck with it
May 09, 2008 | RCA CDRW120 2-Disc CD Recorder
Nov 02, 2007 | RCA CDRW120 2-Disc CD Recorder
19 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
