Question about Refrigerators
Bna17 Not running
Fridge was running, had some bad weather that caused power to go out for 1 hour, not it wont run at all.
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: my fridge stops running after several hours. What
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Oct 04, 2011
Fridge now constantly CYCLES ON AND OFF for 10 to 15 minutes
Perhaps calling in a refrigerator repair man so he can check the freon as that is what causes them to run alot more than normal
Jun 03, 2016 | Westinghouse Refrigerators
U line ice maker is overflowing water
This is usually caused by a bad water inlet valve. This part is usually found behind the fridge at the bottom behind a panel on the fridge itself. It has 1-2 water lines running into it and 1-2 wire harnesses connected. You need to turn off the water going into the fridge and cut the power to the fridge to access this part. You can buy a new one at a local appliance parts store or online.
Aug 11, 2015 | U-Line Icemaker
Black and decker refrigerator bna17 not running
Check the fuse, the compressor is running?
Mar 24, 2013 | Garden
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
Side by side , fridge & freezer both stopped cooling last night, cleaned every thing this morning, unplugged for about 2 hours, plugged in and can hear fan running, but fridge and freezer do not seem...
did you feel the compressor runing?if not , need to check have power to the compressor. if power ok. i think the start relay or capacitor is bad. but make sure the condensor not drity. sometime it cause the problem. good luck
Jan 09, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
We are going to lose power at 12 am tonight and my husband has sizures and we need generator so we bought one but cannot find manual how long will it run? we bought at menards
I really depends on the size of the generator. 1 gallon of gas should last close to an hour, the tank should hold about 3-4 gallons so I would say atleast 3-4 hours but keep a check on the level as you never know when leaks occur, or how much gas it sucks up. Good Luck
Oct 09, 2010 | McCulloch Garden
Engine fails to accelerate and transmission shifts hard in hot weather.On hot days above 85 after the car has run awhile it stops running well. The coolant fan is running seemingly at an excessive speed....
check engine coolant temp sensor, its detect engine overheats that command the computer to engine shutdown for protection, try to replace a good one
Jun 19, 2010 | 2001 Saturn L-Series
Fridge won't restart after power outage.
If your power came back on within an hour of going off it is more than likely that the fridge will simply have tobe unplugged and left for 2-3 hours to let the gas de-pressurize inside the compressor. However if after you try this, and the compressor still isnt running then it will most likely be cause by a faulty relay & overload on the compressor. This is a saftey device so the compressor isn't overloaded during an electrical surge. The original part is sometimes expensive to replace, however a 3 in 1 hard start can be purchased to generically replace the original part.Hope this helps
Thanks
Nov 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
DISH NETWORK RECEIVER 625 WONT STAY RUNNING???
Unfortunately, there is no way of saving your DVR, i would ask Dish for an upgrade to a Vip series rec, for example a 622 or 722 which can allow the use of an external hard drive. it also sounds like your root problem is with the voltage in the outet your dvr in connected to, try to plug directly into wall, if it is already, have an electrician check your voltage to prevent future issues.
Jun 25, 2009 | DISH Network DVR-625 DTV Receiver /...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
