Question about Coleman Mach III Air Conditioner
How do I change fan motor on my Mach 1 roof top RV A/C Model 8335D8764
How to change fan motor to RV Roof top A/C. Model # 833D8764
    Guru:
  • 588 Answers
Try airxcel.com, you should get some options, to get either their literature or tech support and they should be able to help you.
Posted on Apr 10, 2016
  • 127 Answers
SOURCE: My roof top Coleman Mach model 9202-876 only hums
Check to make sure that you are getting power to the fan motor. If you are getting power, then change the Fan Capacitor, if no power then trace the feed back to where the incoming power stops and repair that problem.
Hope this helps,
Jeff
Posted on Jul 06, 2009
jumptrout51
  • 3361 Answers
SOURCE: rv coleman roof mach 3 a/c compressor runs
Replace the thermostat.
Posted on Jul 21, 2009
SOURCE: Looking for manual for rv roof air conditioner on
Looking for a coleman thermostat number 7330-3351. Anyone know where I might find one. It is for a Coleman 7300 roof air.
e mail at aacebail@att.net thanks
Posted on May 20, 2010
motor1258
  • 6674 Answers
SOURCE: i have a 6799a800 series
Sounds like fan start capacitor is faulty. That is your cooling fan above as well as blower inside, all in one motor.
Posted on Aug 27, 2011
  • 884 Answers
SOURCE: coleman mach rv roof ac, the fan comes on but the compressor doesn't, i've replaced all capacitors and stll is not comming on, how do i check voltage to the compressor to maske sure i have pow
At the compressor connectors you have a live and a neutral phase. The live usually goes to a ptc relay starting mechanism which you can test with a meter. If you can disconnect the relay and check the windings of the compressor from one pin to the other two it will tell you if the compressor is open circuit. It is more often than not an overload fault.
Posted on Apr 23, 2012
Coleman mach rv roof ac, the fan comes on but the compressor doesn't, i've replaced all capacitors and stll is not comming on, how do i check voltage to the compressor to maske sure i have pow
Apr 23, 2012 | Coleman Heating & Cooling
Fan not blowing in coleman trs rv roof air
well check a few things first....have someone remove the cover and reach in with a hand and try to manually spin the blade...free spinning?....then tell the person below to click in the on postion while someone views from up top.....is it humming? or even trying to spin?....if not check the fuse on the RV that protects the A/C unit.....good?.....now replace the capacitor ( it the silver or gray can looking thing that the motor wires run to) only the correct size will work w/o causing further motor damage.
Jul 08, 2010 | Dometic Rooftop RV Air Conditioner
Fan does not run. Compressor is running. I can spin the fan, just doesn't run.
If the fan motor is getting the proper voltage and the capacitor is good the motors bad.
Either open windings or overload is open.
Mar 15, 2010 | Dometic Rooftop RV Air Conditioner
My roof top Coleman Mach model 9202-876 only hums when trurned on.
Hope this helps,
Jeff
Jul 05, 2009 | Coleman Heating & Cooling
Coleman Mach roof top ac
Under the drain pan on each side should be a small plastic drain plug they might be clogged up with debris.
Jun 07, 2008 | Dometic Rooftop RV Air Conditioner
Coleman Mach III Air Conditioner Logo
104 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
