Question about Olympus SP800UZ Digital Camera
Opticalzoom and digital zoom does not work together
I AM UNABLE TO OPERATE MY VIVITAR VIVICAM T25 CAMERA. I CHARGED THE CAMERA STILL NOTHING WORKS.
Hello Joseph
I answered your question yesterday.
The T25 doesn't seem to exist!
Here is the link to the T24 and manual
http://www.vivitar.com/product/117/archive/448/vivicam-t024
and the T25
http://www.vivitar.com/product/117/archive/606/vivicam-t125
As I said yesterday, you need to contact Vivitar Support and find a local dealer to check the battery and the camera itself.
http://www.vivitar.com/support
ViviCam T016 Digital Camera Great quality, user-friendly controls, and an excellent value define the ViviCam T016 Digital Camera. A resolution of 12.1 Megapixels together with high quality 4x digital zoom allow you to capture every detail and produce outstanding...
  • ViviCam T024 Digital Camera Take pleasure in using this sleek, elegant, and feature rich camera. With its impressive 12.1 megapixel resolution, as well as anti-shake and red eye reduction tools, you'll be astonished at just how easy it is taking crisp and smooth...
  • Vivicam T026 Digital Camera This flagship model has a high resolution and a large screen, combined with great choice of features. Resolution of 12 Megapixels together with high quality digital zoom allows you to capture every detail and produce large prints. It is also...
  • Vivicam T027 Digital Camera This flagship model has a high resolution and a large screen, combined with great choice of features. Resolution of 12 Megapixels together with high quality digital zoom allows you to capture every detail and produce large prints. With...
  • Support Vivitar
    Oct 11, 2016 | Vivitar Cameras
    I have a Canon EOS 550D camera fitted with a Canon Zoom Lens EF-S 18-200mm lens. I bought both together sometime early in 2010 from London Camera Exchange, Nottingham. I am not in Nottingham at the moment,...
    Just a thought - are your Image Stabilizer and Auto Focus switches On or Off?
    Might be worth experimenting with them.
    Otherwise, sorry, can't help.
    May be necessary to contact your vendor.
    Aug 09, 2011 | Canon EFS 18200mm f3556 IS Zoom Lens + UV...
    Buttons don't work and can't zoom
    hi
    Some of those buttons work in combination with the two dials (i.e., setting ISO and white balance, etc.). Hold a buttin down and user the knobs simoultaneously.
    If this is not the issue, please describe specifically which buttons are not workin...
    thank u
    rate me!!
    Jul 26, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
    I have a fuji finepix s7500 and zoom error. I dont have warranty so I tried to fix myself. I actually found the problem with the zoom. now I am trying to put it back together and I cant figure out where...
    The trick is remembering how you dis-assembled so you can re-assemble.
    Purchase or borrow another camera and photograph each step.
    Buy a plastic tray with little compartments in and start at 1 end and then work back when assembling.
    service manuals from "Flying Dutchmen Plaza" on ebay will show you how to fix
    Dec 29, 2008 | Fuji FinePix S700 Digital Camera
    Setting the ''digital Zoom''
    The digital zoom works fine on mine. It sounds like your have encountered a couple of defective models.
    However, even once you get the digital zoom to work, it gets really grainy, so I don't use it.
    Nov 30, 2008 | Video Cameras
    Putting Lens Back on
    How far apart are you? I mean it all goes back together in reverse order. If the lens is disassembled, you need to get the outer lens tube back on its tracks in the inner tube. That takes a little working, but it should be doable. You should be able to turn the small gear that is on the lens assembly and be able to extend the zoom lens, itll be tough, but if you cant, then the camera will probably not be able to do it either, look for something off track.
    Apr 14, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
    Digital Zoom Stopped Working
    first of all why do you want to use digital zoom? it distorts your pictures! but if you insist, check the settings because it is possible to turn digital zoom off
    Dec 25, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
    D-565 Jammed up...help?
    Take the batteries out, and let it sit for a couple of hours, doesn't always work, but sometimes it does.
    Sep 12, 2005 | Olympus D-565 Zoom Digital Camera
    Difference between the D-460 Zoom and the D-490 Zoom digital camera
    The D-490 Zoom shares the following features with the D-460 Zoom: •Olympus 5.4mm to 16.2mm (equiv. to 35mm to 105mm on a 35mm camera) lens: all-glass, 8 element, 6 groups, 2 aspherical lenses •Automatic TTL focus system •Macro mode allows the camera to auto focus as close as 8 inches •Automatic aperture selection: f2.8 to f8.0 wide, f4.4 to f12.6 tele •3x image magnification inspection mode •Panorama mode: Allows multiple pictures to be "stitched" together to create wide views •NTSC video output to TV •12-second self-timer •8MB SmartMedia card included •Built-in, pop-up intelligent flash: Auto low & backlight, red-eye reducing, off, fill-in, slow-sync •Automatic white balance control or 4 manual settings (daylight, cloudy, tungsten light, fluorescent light) •Automatic ISO sensitivity or manual selectable ISO settings •Uses 4 AA size batteries. AC Adapter is available as an optional accessory In addition, the D-490 Zoom has the following functions and features: •2.1 megapixel resolution (1600 x 1200) •Sequence mode - up to 5 shots in HQ and up to 45 shots in SQ mode (1.3fps) •Motion picture mode - up to 60 seconds of QuickTime movie (.mov) format (w/o audio)
    Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
    Olympus SP800UZ Digital Camera Logo
    21 people viewed this question
    Top Olympus Cameras Experts
    Willem.
    Willem.
    Steven Wander
    Steven Wander
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
