Question about Sony MHC-771 Shelf System
MHC-771 no sound out
Friend of mine gives me MHC-771, everything seems functional well, but no sound at all, just hear "ououououou...". The signal seems ok. How can I troubleshoot the problem? Thanks, Lee
  • chris taube taube Aug 23, 2008
    Sony MHC 771, All seems well but no sound. Is there an internal fuse/protector that needs replacing?
I have a Sony MHC-771 mini stereo system with a 3 cd disk tray. I need to replace the belt that operates the cd tray? The tray is stuck in the closed position. Any suggestions?
Remove the belt and measure it in MM. The search for a belt at that size with Google. You don't have to be too precise about the size. For example if it is 48mm than a 50mm belt should do the trick. Don't bother with the maker's name either. Then can be universal. As long as it looks right.
Jan 30, 2017 | Sony MHC-771 Shelf System
How do I adjust Left-Right speaker balance on Sony MHC-771 Shelf System? My speakers are mounted the way that I am closer to one of them and I need to compensate for that. Thanks Tom
If you have balance controls for each speaker decrease the vol. to the one closest to you. If you do not have separate balance controls , the one closest to you must be muffled so that the sound will be absorbed and will not sound as loud as the other speaker.
Oct 12, 2014 | Sony MHC-771 Shelf System
My denon avr-985 has no sound coming out of it why could this be
Go though your menu on the reciever, Look for the speaker functions for your front end rear speakers ,It was probably turned off. Was it working before you got it from your friend,
Sep 20, 2012 | Denon Avr 985 7.1 Channel 945 Watt...
How do I connect Optical Audio or HDMI to Sony MHC-GN100D, to have 5.1 & Dolby sound effects?
I guess you are in the same boat as me.
There are Digital (optical) to analog signal converters available. You can use them. I checked on ebay and here are the converts available on ebay India.
http://www.ebay.in/sch/i.html?_trkparms=65%253A1%257C66%253A1%257C39%253A1&rt=nc&_nkw=optical+to+analog+converter&_ipg=200&_trksid=p3286.c0.m14.l1514
Mar 27, 2012 | Audio Players & Recorders
My sony MHC-GX250 says relay is it possible that it is causing my system to keep skipping tracks and randomly jumping ??
Mine says that all the time and it doesn't skip like that.. try using some air duster in the back and cd tray.. mine actually quit playing cds at one point.. my friend said it was the "dust cover" or something like that by the eye..
Feb 06, 2011 | Sony MHC-GX250 CD Shelf System
I can not figure out how to get the audio from my tv/PS3 through my Sony MHC-65200. Is it possible and if it is possible what do i need to do?
Usually the way to do it is to connect audio out (Phono connectors) on the TV to audio/aux in on the stereo (phono connectors) Of course to do this, both of the pieces of equipment have to have the right connections.
Jul 15, 2010 | Sony MHC-771 Shelf System
I listen my self on my car sound system when i transmit
its a fact of life when it comes to CB. Some times you will hear it over the radio if it is on. Happens with mine. There really is no way to solve it unless you replace all the speaker wire in the car with shielded wire.
You are sending out RF. When the AM modulation hits the speaker wires, the act like an antenna a bit. If there is any electrical signal in the wires, from the radio being on, even if the volume is low, and some times even down all the way, the signal in the wire coming from the radio acts like a carrier signal and causes the speaker to resonate to the modulation, giving you your voice on the speakers.
You can try running the power wire right to the battery, but its most likely coming from the antenna.
You probably will not ever be able to get rid of it.
Some cars it doesn't effect depending on the speaker wires, some it does.
I can say that a lot of people have their radio modded so that they can hear them selves over the radio when they talk. its called talk back. This way you can know how your audio sounds.
Think of it this way. You don't have to pay a tech to add this feature.
Mar 18, 2010 | Midland 1001Z 40-Channels Base CB Radio
Re: Sony 771 ... constant buzzing sound in background
Sounds like feedback. Check your speaker connections at the speaker and the main unit.
Jun 26, 2017 | Sony MHC-771 Shelf System
Sony MHC-RV888D - TAPE Recording to Laptop as mp3
on laptop, ensure the following: 1. go to Volume control (look for icon on system tray). 2. under Options tab select Properties. 3. under Adjust volume for recording option, ensure that microphone is is check-boxed if no luck, borrow a second amp and connect your L/R jacks (red and white colour) to the borrowed amps line in jacks and test whether you hear anything to confirm your line out capability.
May 27, 2007 | Sony MHC-RV888D Shelf System
Sony MHC-RV888D Tape Recording to LAPTOP - How to connect?
you have to connect the S-VIDEO output of the device to your laptop via s-video - usb cable , if they do not have a cable like that than you might as well use an adapter from s-video to usb, if u have your hands on one.
the second method is to hook up a audio recorder from the speaker output, and use a volume controller witch steps down the speaker output so you can plug the cable directly to your laptop microfone output..
good luck!
Apr 11, 2017 | Sony MHC-RV888D Shelf System
49 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
