Kenmore model # 45872404 washing machine cycle stops and reads c 6 on panel
  • 1314 Answers
SOURCE: washer kenmore elite calypso 21086
promblem with the lid switch is it happing durning the drain spin cycle
Posted on Jan 20, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore Washing Machine Model 110.20862990
You don't open the rear panel. This is a typical symptom of a lid switch problem. The link below will explain how to access it. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading as item number 11 (Part number 3949238). For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
I hope this helps you. If you have questions, please let me know.
Posted on Aug 07, 2008
SOURCE: washing machine will not spin
MY WASHER WANT SPIN AT ALL
Posted on Nov 15, 2008
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
vickygomar
  • 460 Answers
SOURCE: washing machine stops mid-cycle
F30
DISPENSER SYSTEM ERROR
when the dispenser motor cannot be driven to its proper positon.
==========The following information is for a TECHNICION SERVICE(only)========
1.- Unplug washer or disconnect power.
2.- Check mechanical linkage from dispenser motor to the top of the dispenser.
3.- Check wire hamess connections to the dispenser motot and Central Contol Unit(CCU)
4.-Check dispenser motor for power rotation.
Was this helpful?
Posted on May 12, 2009
How do I find the lid sensor switch on a Kenmore 500 washing machine
If the washing machine stops in the middle of the cycle then it is very unlikely the lid switch is involved. It could be a number of reasons.
Best to drain the washing machine and repeat the cycle a few times to check if it happens at the same point. Could be a problem with the timer or pressure switch.
You can locate all the parts and their location in this site. I hope I have the correct model for your washing machine.
KENMORE Residential Washer Parts Model 11029522800
Aug 05, 2014 | Kenmore 500 3.5 cu. ft. Top-Load Washing...
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
My kenmore washing machine is stopping mid-cycle and reading f6 on the panel
The F/06 error according to the official repair manual is a Motor Tachometer error . . the error is triggered because the main control board loses communication with the tachometer either a short in the wiring or a short in one of several other places. . The tachometer sits on the spindle of the motor and has two wires from the spindle to a wiring hub on the left side of the motor . . . two of the black wires are for the tach then feed to the MCU (Motor Control Unit) in the bottom left facing the washer which then feeds the info into the main control board which is at the top on the machine under the top cover. Some find that checking the connections with a volt meter is a starting point however in most cases you will not find issues with electrical continuity, the manual has the expected readings. The MCU is known to go bad in these machines so that would be the first suspect in resolving the error, however it could be the wiring, the motor or the main control board. The MCU costs around $200 so consider the possibility that it may not solve your issue. The error may even be sporadic only happening on heavier loads in the tub.
Nov 18, 2013 | Kenmore Washing Machines
My Kenmore Elite Oasis washing machine has error code "UL" while in rising cycle and stop. Can you tell me what is the problem and how to solve it.
My Kenmore Elite Oasis washing machine will drain but not spin and it keeps jumping back and forth to different time cycles. It continually reads "UL" and I keep trying to adjust and balance the load but it does not help.
Jun 25, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a kenmore model 110.28922790. It will not stop filling with water. What would be the likely cause?
the water pressure/level fill switch under the control panel is defective,it uses water level/pressure per you setting on the control panel for wash load size to fill it to the set level,then start the washing cycle after it fills
Mar 23, 2011 | Kenmore Washing Machines
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Machine stops during spin cycle and reads 'ob' on the display
Read this thread about your error. I am sure it relates to your (drain) problem.
Good luck and if you have any more questions, just come back here and leave a comment - I'm happy to help.
May 21, 2009 | Kenmore Washing Machines
Apr 24, 2009 | Washing Machines
Washer will not complete a wash cycle and panel lights become dim
ok take the bottom panel off you will see a tech sheet usually on the right side of the unit in plastic. this has everything you need. but the clean out will be directly in front of you when you take the bottom panel off. clean that usually you will find lots of things in there plugging the path for the drain causeing tons of problems with your washer.
Mar 31, 2009 | Kenmore 45981 Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
