Question about Jarden Mr. Coffee BVMC-KG1 Single Serve Coffee Maker
Kcup stuck side lever fell off how do you replace
Keurig handle wont raise or lower it is stuck in the halfway position
Check for obstructions behind the machine, in the area behind the handle and in the area behind the kcup holder. Ensure that the kcup holder is inserted correctly, aligning the arrows at the top. Be careful of the needles!
Apr 06, 2014 | Keurig Elite B40 Coffee Maker
2007-Nissan Murano-air blows to specified temperature on the driver side vents, but does not adjust on passenger side-blows only cold or ambient air
the flapper damper valves are stuck.
due to
1: cable broken or sheath loose.
2: cable not attached at either end.
3;bad flapper inside duct or lever to it snapped. or fell off.
its just a flapper , watch it and see if it works.
open or closed, using a flash light, under the dash.
Sep 28, 2013 | 2006 - 2007 Nissan Murano Grille 1650-99-1...
My 2006 Chevy truck is stuck in D but the lever moves and cannot start the truck What could the problem be?
mcdevito75 here, A neutral Safety switch keeps your car from starting in D, L 1--2 Or R Most likely the cable or rod connecting the shift lever to the transmossin fell or broke off the transmission. Best Bet Have the car towed to your local repair shop, in case you need to replace the entire shikt cable or linkage, you can start the car if you can find the lever on the tranny and move that lever into N you'LL have to do this by feel the lever will be close to the broken cable or rod that shifts the tranny.
Jun 18, 2010 | 2006 Chevrolet Silverado
How do you replace the shift lever shaft on a 06 yamaha ttr 230?
Yes. You need to remove the crankcase cover, oil pump, brake lever and clutch to remove it.
Sep 19, 2009 | 2006 Pontiac G6
The lever is stuck on my LG ice dispenser
You'll need to replace the whole ice maker system. Problem exist in the mechanical box connected to the lever which once opened is almost impossible to re-assemble. Cost around $95.00
Aug 06, 2009 | LG LRSC-26922 Side by Side Refrigerator
I need to replace the Ice dispenser lever in ny
Unless the old one actually broke, you can re-install it if it merely fell off. Use a mirror and a flashlight to see the hole on the side toward you so that you can re-insert the lever that goes towards the front, then re-insert the lever into the back hole. If the lever actually broke, the new lever will come with directions on how to install it.
May 14, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Canon MP530 print head malfunction
I had the same problem with my printer. There is a switch that tells the printer that the cover is open or closed. Unplug the printer. Open up the printer cover and look on the inside right side edge. About half way back, you'll see a 3/4 inch by 1/2 inch hole where this switch resides. If you put your finger into it, you may be able to push on a lever and it will go down. It should spring back up when you pull your finger out. If you can feel the lever but it just sits at the bottom then there either this lever is broken or the spring fell off.
The problem with my printer was the spring had popped out. To access the switch, you'll need to remove the right side cover. Do this by removing the two screws in the back on the right side. Open the printer cover and find the third screw. It is located on the right hand side, near the front of the printer, on the top. Remove this screw and pop out the cover and see if you can find the spring that is attached to the lever. Make sure you do this in an area that if a small piece fell out you could find it.
Look at the switch and lever. If there is no spring attached to the lever then it is most likely the problem, otherwise the switch may be bad or the electronics inside the printer. There is a hook on the lever and one on the printer. Reconnect the spring and it should fix the problem. I found my spring had completely fallen out and fell on the floor when the cover was opened. It is possible that this spring if fallen out can fall back inside the printer so you may have to shake the printer to find this little spring. It is about 1/2 inch long. Hope this helps.
Dec 20, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Misfeed
there is most likely a small piece of paper on a sensor/
remove paper tray and look inside, is there paper behind the tray? look at the tires are they bald and sniny? replace. Look at the tires and see if there is any scrap of paper there.
open right door and look down towards the paper tray, do you see any pieces of paper? there is a small black lever there, it's the sensor is it stuck?
look into the fuser (where it gets hot) ,you may have to remove it the paper sometimes gets crumbled like an accordion there, htere is also a small black lever there see any paper is it stuck?
Sep 15, 2008 | Sharp AL 1631 Copier
Jarden Mr. Coffee BVMC-KG1 Single Serve Coffee Maker Logo
67 people viewed this question
Top Jarden Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Jarden Kitchen Appliances - Other Expert? Answer questions, earn points and help others
