Amp burned out need replacement part no#
SOURCE: phase linear uv8=jensen brake bypass code
from remote setup, 5 4 3 2 1 0(hold "0" for 4 seconds) let go. look for the brake override option and turn it on.
SOURCE: Phase Linear UV8
I have same problem with same uv8 but i use remote to activate am/fm then hit setup on rem.enter 543210 and a new menu came up. ( listening for the beep after each 3 is pressed ) select the hammer in upper left hand corner of screen, select brake bypass to on, then hot the X near bottom os screen. this works for me it should work for you.
SOURCE: phase linear UV7i makeing the dvd player without useing parking
There is a pink wire that goes to the parking brake. It connects to the ground wire on the parking brake that makes the brake light come on the instrument panel.
connect the pink wire on your stereo to a frame ground.
SOURCE: The UV8 needs to use The Pink wiere to play an CD audio?
I got through to tech support. For problem of no audio from DVD or CD (can only hear radio), reverse the Blue wire (power antenna) and the Blue/White wire (external power amplifier). This should solve the problem.
SOURCE: i need a remote for my jensen phase linear uv8
Get one off of ebay. Just received one for bout 30.00 Good luck
