I am trying to change my NAT settings from strict to open so that I can play Xbox Live more efficiently, but I only want to change this on my xbox and not on my computer. Help?
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
it says i need a username and a password to access the site. how do i find out what it is??
No advanced settings option to select?
type in admin and then whatever your network password is
what if you dont know the network password?
This is what worked for me: My DI-524 router (firmware version 5.00) always said my NAT was "Moderate". I use DHCP and have UPnP turned on. Rebooting the router made no difference. On a whim I turned off the "Discard PING from WAN side" option in the router (Tools tab, Misc. button) and re-tested. Woohoo! It said my NAT is OPEN! Oddly, I turned "Discard PING from WAN side" back ON and my XBox360 still says my NAT is OPEN. Weird. Maybe just changing it and then changing it back somehow reset something in the firmware. I don't understand it but it worked for me, so it's worth a try!
You just have to set your router to the DMZ and you're set!
If you still experience issues with NAT setting, try opening these ports in your router (if You want extra security make sure to select a fixed IP for the Xbox 360 and restrict these setting to that IP:
3074 TCP/UDP
8602 TCP/UDP
88 UDP
Hope this helps :-)
On the router is the UPnp option. Configure port forwarding for other ports, and DMZ as disabled. NAT should report as Open.
General options for getting your NAT Status to Open
There are four ways to overcome a Strict/Moderate NAT setting when using a router. I have listed them in the order of preference:
If you have an Xbox Live Certified router, use the certified firmware for your router
Use UPnP. If your router supports this. Turn it on. The router will work out the ports it needs to open for Xbox live. If your router does not have this feature, check the manufacturers website for the latest firmware. (also make sure portforwarding and/or DMZ is turned off as they interfere with UPnP)
Port forwarding (look up your router here then follow the instructions for Xbox Live 360)
Use a DMZ (De-militarized Zone)
The DMZ (De-militarized Zone) is area that sits outside of your routers firewall. Don't worry though your not at risk with your Xbox
okay, all i have is a modem and my ps3 wirelessly connects and before i got a new modem it was OPEN and because we had to get a new one, my NAT type has been STRICT and im reading how to get it from STRICT to OPEN and all everyone talks about is using a router. Does anyone know how to change it from STRICT to OPEN without a router and just a modem???
Ok step by step instructions for changing to open NAT type
1. go into the start menu>all programs>accesories>command prompt
2.in command prompt type in ipconfig
3. look for default gateway. this number is your ip address. You will also want to note what number is at the end of the IPv4 address. you will need this later.
4. open your internet and type in your ip address
5. a box will pop up for username and password. generally, the default is username: admin password: password
6. now you get to your router's settings page. this varies from company to company. i know netgear and linksys. if you dont have one of these you may have to google your company's router to learn how to port forward.
7. On netgear, scroll down on the left side until you see port forwarding/triggering and click on it. On linksys click on the applications and gaming tab at the top
8. Now you must enter the ports you need forwarded. either click add custom service for netgear or just type it in on linksys.
9. you need a different name for each port. the three you need are:
3074 TCP/UDP
8602 TCP/UDP
88 UDP
10. under the ip address is where you put the IPv4 address you noted earlier. refer to steps 1-3 if you dont have it.
11. click save and youre done
Now you will have an open NAT type when playing on Xbox. I dont know about you guys but my IPv4 address changes sometimes so if youre NAT type goes back to strict then you just need to look up the IPv4 address again and change it in your settings tab.
I have verizon and it work for me. Click "start", go to "control panel", click "network connections", then click "local area connection", click "support" tab, get the "default gateway" numbers and put it in your address bar in internet explorer and click go. You get a verizon page click "advanced setup." then you have to type in a username and password for me it was admin for username and password for password it should work then go to UPnP (Universal Plug and Play) click it. then click "on" and apply and it should work. again i have verizon and don't know if it works for all isp.
My nat stye is set to Strict and i have no problems online, but my mate who's nat type is set to "Open" can't connect to me. When i connect to my other mates it works perfectly fine.
My nat is strict and i need it to be open so i can play with my friends
To check UPnP and Port Forwarding you need to:
Log onto router..web address 192.168.1.1 and the default password is password.
Scroll down the list on the left side of screen. UPnP is near the bottem of the list. Click on it and check it's settings.
Port Forwarding/Port Triggering is several options above UPnP. Port Forwarding works for one xbox on the network. Ports to open are mentioned in solution #5.
For over a year i have been running 2 xboxes and 2 computers on my wnr834b with the first version of firmware.
I have updated to the most current firmware.
UPnP turned on both show up as moderate. With one xbox on it's open.
Port Forwarding one xbox is always open and second is strict.
Port Triggering whichever connects to Live is open and the other is strict.
Does anyone have any suggestions?
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Ok i put dmz as enabled and typed in my custom ip adress thing at the bottom of the dmz page and my nat type has been open ever since! and i have a linksys.
Http://portforward.com/
go there. find what you want to forward for, your router make and model, follow instructions.
too easy.
NAT rating can be remedied by either turning on UPnP on your router,
DMZ or portforwarding. This site has some good guides on how to improve
your NAT rating when connected wirelessly to xbox live:
How to connect wirelessly to xbox live with open NAT
NAT rating can be remedied by either turning on UPnP on your router, DMZ or portforwarding. This site has some good guides on how to improve your NAT rating when connected wirelessly to xbox live:
Cant change the nat on my router is a motorola sbg900, i understand everything that is in the forum but i can't do it 'cos there is no options on my router that can do it ... well i mean were does it need to be change.. cos non of the thing you the people have said...are on my router's page
Ok i dont remember my login or password what can i do
I think you can enable UPnP on the router.
Open the ports for Xbox or other gaming station.
Change the MTU size.
Disable the firewalls on the router.
Try webpage on Changing NAT to open
Im really stuck on what you guys are on about.. i have no clues on what you are going on about please take it very easy and tell me exactly what to do and how to do it step by step thanks
I have done all of this and still my NAT type 2 is strict I have a qwest modem/router how can I change this? please help!
Type your ip in adress bar - use google to find your ip- when you load this up you will notice the xyxel rooter config pass type it in - may still be the default one the box if you never used brfore/ changed. when on click adavanced setup - aplie- then click on advanced again then go down to UPnP then tick all the boxes then your nat should be on open after you click apply and it is updated .... sorted hopefullly . hope that cleared up your problem
Try opening these ports in your router gui (select a fixed IP for the Xbox 360 remember it should be in the range of the router IP and restrict these setting to that IP:
3074 TCP/UDP
8602 TCP/UDP
88 UDP
Ok i put in my ip adress in the web browser and its says can not be found what do i do?
Wow that was difficult for me, but it worked. If you examine your router you will find the ip address and ID with password. If you login to your IP address it will allow you to change the settings. Click on the tab "port forwarding" and then at the bottom of the page it give you an option to edit. Click on the tab and then select from the drop down menu either UDP or TCP and fill the rest in with: UDP 88, UDP 3074 and TCP 3074. I personally didn't know the IP address for xbox so I just made the last number up and it worked.
Good Luck.
Ive tried portforwarding triggering UdNP or whatever and disabling firewall help and wtf i dont even know what dmz is
My NAT used to be moderate, but then i enable UPnp and i added the three ports someone was talking about. now my nat change to open
I sense the fact that not many people know how to get to get the IP address for thier individual router. To do this, go to the command prompt screen. When in here, typer in ipconfig then press enter. Remember the numbers that is ways the IP address is. then open your web browser. Type in those numbers into the address bar and it will ask for you to login. The default for my router was that the login was admin and the password is password. When you log in, follow the steps that the other people have given you. I need to fix this on my router as well but I can't find any settings at all within my menus to change the NAT settings.
Just turn the "gaming mode" on in Tools -> Misc. and it should work =D
Or you can try this link here - which seems to be working well for a lot of individuals.
I had the verizon five spot which if you have will not fix the problem get onto ebay and get a mifi 2200 device for verizon and then you will need a cradlepoint router i have the mobile broadband n router hook this system up and game on with a open nat
SOURCE: Change NAT to open
The ports should be opened only in the router not in the x.box, go to a working pc..
To
allow traffic from the internet to enter your local network, you will
need to open up ports or the router will block the request.
Because our routers use NAT (Network Address Translation), you
can only open a specific port or ports to one computer at a time. For
example: If you have 2 web servers on your network, you cannot open
port 80 to both computers. You will need to configure 1 of the web
servers to use port 81. Now you can open port 80 to the first computer
and then open port 81 to the other computer.
Step 1 Open your web browser and enter the IP address of your
D-Link router (192.168.0.1). Enter username (admin) and your password
(blank by default).
Step 2 Click on the Advanced tab at the top and then click Virtual Server on the left side.
Step 3 Check Enabled to activate entry.
Step 4 Enter a name for your virtual server entry.
Step 5 Next to Private IP, enter the IP address of the computer on your local network that you want to allow the incoming service to.
Step 6 Choose Protocol Type - either TCP, UDP, or both. If you are not sure, select both.
Step 7 Enter the port information next to Private Port and Public Port.
The private and public ports are usually the same. The public port is
the port seen from the WAN side, and the private port is the port being
used by the application on the computer within your local network.
Step 8 Enter the Schedule information.
Step 9 Click Apply and then click Continue.
i have the same problem, ive looked at the thread its the same as myne but when i go on the virtual servers it doesnt say discription or imbound port it just says lan port publick port i dont understand :(
Open an Internet Explorer browser page.In the address bar type - 192.168.1.1
Leave username blank & in password use admin in lower case...
Click on "Applications and Gaming" tab and then click on "Port Range Forwarding" subtab...
1) On the first line in Application box type in ABC, in the start box type in 88 and End box type in 88, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
2) On the second line in Application box type in PQR, in the start box type in 3074 and End box type in 3074, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
3) On the third line in Application box type in XYZ, in the start box type in 53 and End box type in 53, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box and click on Save Settings...
3) Once you return to the set up page click on the Security tab and uncheck Block Anonymous Internet Requests and click on Save Settings...
4) Click on set-up and change the MTU Size to 1452 and click Save Settings...
5) Goto the XBox Network Settings and IP Address Settings and select manual IP Settings and assign the following on your Xbox
IP Address :- 192.168.1.20, Subnet Mask :- 255.255.255.0, Default Gateway :- 192.168.1.1...
6) Also assign the DNS Addresses on the Xbox
Primary dns :- 4.2.2.2...Secondary dns :- 192.168.1.1
7) Turn off your modem, router, and Xbox...Wait for a minute...
8) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect...
Kudos! Thanks!
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: change NAT from strict to open
You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
I keep getting a "strict" warning on my xbox 360.  I change the DMZ every couple of weeks  and it still says the same thing.
i need to open my nat so i can play xbox live
this is the first time that my xbox setting is strict and i have used my router with my xbox many times infact i used it this morning now its changed to strict how can i change it
i have the same problem, just slightly different... my NAT setting says it is open, but i have other gamers who try to join my party say they can't because my NAT is closed, or i try to join someone else party but i cant, i had a friend experiencing a problem similar, and they say it is because my NAT is closed, BUT THE DAMN THING SAYS ITS OPEN... help?
nat is strict and cant match up to my friends on xbox live. how do i change my nat so that it stays open. i have a belkin F5D7230-4. pls help
i have at&t highspeed dsl and they gave me a routor that every time i try to pley halo 3 it tells me matchmakeing may be slow due to your routor being strict how could i change my routor to open?
I have a moderate NAT and I cant play with any of my friends how do I change it to open??
I cannot join my friends
my NAT says moderate but i cant play xbox live with my friend because he has open....how do i chance my NAT from moderate to open?
I use a ethernet cable to connect to my laptop which gives me a connection to my bt homehub but the problem is when i test the connection the "Nat" comes up as strict. Im new to computers and not too great at using them so a basic step by step guid on how to change the nat from strict to open would be much apreciated.
im trying to play xbox live and everytimei try to play it either kicks me out of the game or it wont load it says my NAT is at moderate i didnt no what the problem was i just wanted to see if it was my router but i dont wanna buy a new one.
in englsih a non computer nerd can understand how do i change nat settings to open?
I need to change my NAT settings from strict to open how do i do that but i am not wireless
my NAT is strict so it wont let me join any custom games my friends host help me please.
how do i change the thing on my router i need lyk a step by step guide for dummies i'm bit dense like dat. could u help plz
i have a dynex dx-e402 and i want to change my nat code to open on my xbox360
we have 3 xbox's and we have always had a problem with the NAT settings for the past 12 months my settings have been changing from strict to moderate and it has been doing the same on my husbands apart from some of the time his will go to open why is this.My son is on a wireless adaptor and his seems to be ok.
Please can you help we have tried everything.
tried new router
looked at router manager
rang xbox live
spoke to aol
same here, I've had same problem for last week. It say's my nat is strict and can't play ANy halo matches!
I cant talk to some people on xbox because my NAT is on moderate. So i cant talk with some of my friends.
yeah, same problem with the whole NAT moderate thing..
yep.
i have done everything, from opening ports, updated the router, opened dmz, manually enetered the isps, one at a time of course, and still strict nat... what gives?
my xbox live NAT is strict. i have a wireless router and was bought a week ago. my problem has just occured last night. how do i change or get it to be open?
want to change the 360 to an open nat but not my computer. i know i have to put in ip adress for the xbox but dont know how
me too im new to this nat thing i need step by step guide on how to make Nat open for xbox live
i want to change my nat from strict to open only for the xbox and not the computer
how do u do that?
I have a macbook, and I am running xboxlive through a shared ethernet port. My laptop wireless internet is feeding the xbox. how do i change my nat to open?
yeah i need to change my nat to open for xbox live.... i have a belkin wireless router in my house with wireless xbox live
My Azureus program keeps telling my my NAT needs opening..i looked at all your solutions and to be honest they are all techno-****. speak some english for those people who dont know technically what u r talking about. step by step clear instructions would be helpful please. thanks.
I'm trying to change my NAT settings from Strict to Open on my Netgear wireless router. So that I can paly Xbox live more efficent. I tried using the Port Forwarding but it didn't not work.
I want to open my NAT for my Xbox 360, so that it's no longer on moderate. How can I go about doing that, if it says nothing about it in my Router's manual? Please help, ASAP. =]
Same exact. the sign pops up that it is not open and finding matches may be slow. Also I seem to get a lot of glitching which ends up freezing only in call of duty 4 though maybe its to complex or if my routers to cheep I'd like to get a better one if it would fix it. Thank You !!!!!
i just want to do the same i cant talk to any of my friends who i moved away frm last week and cant get into games sum1 help please
lkihjlkn.
trying to get my router to switch from strict/moderate to open this problem never existed until today my 360 always worked fine with the linkys router but for some reason its screwed up now.
My problem may be slightly diff... i have my xbox connected to my computers ethernet port and my computer has a wireless N card... my xbox is telling me nat is set to strict...
when i check my router it said nat is off... my other 360 is using the pelican adapter and says nat is off... so my question is there is something in my computer that is wireless that is creating a nat... what could it be... and how do i turn it off....
my xbox live NAT is strict and i cant talk to any one in private chat and i cant join any game session
ive tryed setting my xbox live up again
i cant change my NAT from moderate to open...how do i do that?
cant change my nat port to open
I Did everything the guuy said and it still says Moderate
can some one tell me how to open the nat
im playing naruto rise of a ninja and all it does is disconnect me
People have told me to change my upnp to be enabled, I tried that, but my nat settings are still strict... Can anyone provide another solution to this?
plz help. i am with BT internet and have a BT Homehub-30CE if that means anything and xbox live was working fine (NAT was Open) till yesterday when i couldnt talk to my mates and it said my NAT was strict. I really dont know wt to do.
want to add to that. i have no idea wt a unpn is and with a BThomehub i got no idea wtm to do . can a tech guy plz email me. if so then write ur email adress and then ill email u my email cos i not puttin m y email on the internet. plz help. plz. plz
I want to change my nat settings to strict to open . But i do not now where to find it to change it.
i have sattelite brodband and i have a belkin f5d8233 4 router . the problem is i cannot talk to my brother on x box live i can send him pitcure messages and also voice messages i no problem but also i cannot play him on any game he comes onto sreen but then freezes . i rang x box and they told me to check my ports to see if they were open but the strange thing i can talk to and play loads of other people on x box no problem can you explain to me how to check to see if all my ports are open ?
My NAT is moderate and I need to change it to open.
I need to change my Linksys Wireless G router's NAT from moderate to open
Need to chnage nat to open
i cant cvonnect to some of my friends sessions
i cant join my friends games
i need to figure out how to change my NAT so i can play xbox live
My NAT is STRICT and I want to change it to an OPEN NAT but I don't know what to do. Need Help.
exactly what he said want NAT open but dont wana mess up my computer
Ok kids... all you hve to do is log in to your belkin 54g athttp://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZ portion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
Need to change my NAT to open and i have a NETGEAR WNR834B N ROUTER
What if i dont kno the password or username for thehttp://192.168.2.1 thing?
I am trying to change from NAT Type 3 to NAT type 2 so I may connect with my PS3. How is this changed?
Xbox 360 is saying my Nat isn't open
Having problems getting my nat setting to open so i can play xbox live using my motorola sbg1000 wireless cable modem.
Please help
my upnp is enabled and i have tried opening some ports . it still is strict
having the same problem connecting to friends games on xbox live. how exactly do you change your nat settings for your router
its horrible
ANY TIPS HOW TO CHANGE THE NAT
I know it's something about typing your xbox 360's IP adress into the internet explorer's adress bar and changing the UPnP settings to enabled, but my IP adress isn't loading on the screen! I"M GOING CRAZY OVER THIS!!!
I need to open my nat on my xbox.
How do i change my NAT settings to open 4 my xbox 360
This NAT thing drives me nucking futs lol but really its always hell trying to play Halo with my friends. If someone could help me out that would be GREAT!!! Just get ahold of me at [email protected] Thanks.
I have the same problem
Mine is Strict
I also hav the same prob with my NAT settings, does anyone knO how to change my nat settings to open?
cant get my nat to open
i got to my ip adress but i dont no the username
Hello, i tried to join my friends match on xbox 360 (Halo 3) It says im incompatible because my system setting is Strict Nat, I have tried to find out my router Ip and read this entire website nothing helped me find what im looking for, could somebody give me a detailed explanation on what to do?
ive got the same problem so help jesus
I dont know where to get my IP address and i dont know if it has a password neither
I have the same problem.
i have connected to my router using the ips add and manage to get into a sub menu it only gives me the status of the router ie. no options on the left to re-configure ,,,is my router blocked ?? i have entered 1234 and password for paswords and still the same ? any help would be great thanks in advance Â
I don't know how to set my NAT to open.
i have a linksys wrt54gs router and wonder how to change it to open.
cant play some of my friends online and cant join and xbox live party
my nat is strict and i dont kno how to change cant play wit friends on xbox live
I can paly online with my PS3 but I cannot host a game to invite my friends to play with me from their PS3 and I cannot join the game they host. I have opened 8 ports with numbers supplied from Sony and Activision
on mgo2 i cant host games which i really wanna do and my nat type is strict but i have a NETGEAR router
when i log on to my ip adress i cant find any way of editing any info jus gives me the status theres no advanced option anywhere??
Nat changes from Open to Strict on it's own every few months, want to know how to change xbox nat.
can't connect to peoples connection on xbox live
cant join gears parties or party chats with friends
well ... My router is from switzerland (since i''m living there)
it's bluewin...
And if i log in... I onl y get my details... and nothing to change...
whenever i play halo 3 i cant connect to my friend and that is because my NAT is not open can someone please help me open my NAT
when i go on some of my xbox games it wont allow me to connect to some of my friends. I heard my netwirk is on strict and i need to change it to open so i can play with most of my friends. How do i switch it from strict to open step by step......PLZ HELP ME
i try to play with my friends but it wont let me it suxs
urg
my nat type is still strict even thought i have the upnp(universasl plug n play) enabled. this is ****
me too
on halo3 it wont let me join my friends game cos of strict nat or something help!!
I'm sorry, but how exactly do I retreive my username and password when it asks me to use it after typing in my IP address into the website address bar?
I have the same exact modem, problem is, there is no ''advanced setuup'' option on the modem's page
says cant connect to game session, returning to single player... grand theft auto 4
Cant play games online due to the NAT settings... help
I can suggest you all the users a new webpage where you will get some idea about how to change NAT type to openhttp://theroutersetup.com/how-to-change-...
