Question about GE Profile Advantium PSA1201RSS 1.7 cu. ft. Over-the-RanSpeed Oven with 925 Micowave Cooking Watts, Speedcook Technology, Traditional Oven, WarminSensor Microwave and 300 CFM Vent Fan: Stainless Steel
Keypad shorted - GE Profile Advantium PSA1201RSS 1.7 cu. ft. Over-the-RanSpeed Oven with 925 Micowave Cooking Watts, Speedcook Technology, Traditional Oven, WarminSensor Microwave and 300 CFM Vent Fan: Stainless Steel
How to get the 5E error off my display on my kenmore microwave
fix it.
SE Shorted key 1. Check if cable of keypad has been inserted into connector of main PCB. 2. Check for short between main PCB and connector or keypad and cable. 3. If there is not a problem with connector on main PCB and cable of keypad, replace the main PCB.
Jan 22, 2016 | Kenmore Microwave Ovens
The smart wash light on my kenmore elite model 66513753K602 is flashing. I have tried the suggested button sequences to reset it and they have not worked. How do I troubleshoot it to determine which...
From the tech sheet:
CHECKING KEYPAD
OPERATION
A rapidly blinking LED over
one of the keys of the keypad
(or sometimes a "dead"
keypad/console) indicates one
or more key switch lines are
stuck or shorted on either the
control or the keypad. To
determine if the control or
keypad is faulty, do the
following test:
1. Unplug dishwasher or disconnect
power.
2. Open the dishwasher door.
3. Open console and disconnect the
keypad ribbon connection from
the control (at P1). Make sure all
other connections are made.
4. Put console back together. Do not
close the dishwasher door.
5. Plug in dishwasher or reconnect
power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
? If the control is OK (no longer
sees shorts with the keypad
unplugged), it will respond by
turning on a Drain Motor for
2 minutes. Check and/or
replace the keypad if the
control responds OK.
? If the control is not OK (still
unplugged), then the drain
motor will NOT respond and
will remain off. If no response,
replace the control.
Jan 21, 2015 | Kenmore Dishwashers
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
Numeric keypad on keyboard stops working after signing onto desktop computer
Sounds like a short key is being activated when you are pressing series of buttons disable short keys on your PC options menu or hold down the shift key then disable the short/hot keys menu
Feb 22, 2013 | HP Pavilion Computers & Internet
GE microwave says "shorted keypad", what causes this? How can I fix it?
a shorted keypad is when the tiny capacitors across the keypad,become shorted,the only fix is to replace the membrane keypad........no fix
Dec 14, 2012 | GE Profile PVM1970SRSS 1.9 Cu. Ft....
Why is my 7360 keypad stuck on BUSY???!!
Something is causing a short on the keypad bus. It could be wiring, or the panel could have had a power surge. There is also a jumper on the main alarm panel board that could be shorted. Open the panel, and make sure there is no connection between the pins in the middle of the board marked RESET. If that isn't the issue, pop the keypad off the wall and make sure that there isn't a connection between the yellow and green wires. The wires are on a harness connected to the back of the keypad, so follow them back far enough to see where they connect to the wire going to the panel.
May 11, 2011 | Icon Dmp 7360-w Thinline Icon Security...
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
Heard on news of fires even when off
That's usually form shorted or shorting keypads.
What to look out for is is you get an F3 error on your keypad (assuming you have a GE - the code is different on other brands).
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls or short the keypad.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
Or just to be safe, you can just leave the oven's door open at night or actually any time you're not using the oven..
May 24, 2009 | GE Spacemaker JVM1740 Microwave Oven
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
Keypad won't stay in keypad mode.
Go to settings and check your keyboard settings
Jan 17, 2018 | Kensington Pocket KeyPad Calculator...
GE Profile Advantium PSA1201RSS 1.7 cu. ft. Over-the-RanSpeed Oven with 925 Micowave Cooking Watts, Speedcook Technology, Traditional Oven, WarminSensor Microwave and 300 CFM Vent Fan: Stainless Steel Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
