Question about Envision H190L Monitor
The display does not fill the screen of the monitor. How can I fix this
    Problem Solver:
  • 12 Answers
It depends on the type of monitor you have. Generally you will have a physical menu button on your monitor. Depress this and look for Vertical and Horizontal adjustments using the arrow keys on your monitor. You can stretch the screen all you like to fit the diameter of your monitor.
Posted on Nov 19, 2013
The screen is not completely filling the monitor screen
The top button on your control panel (this is where your power button is) lets you cycle through the presets. Try these the presets should fill the screen.
If this does not work I would recommend going into the display settings of your operating system and try changing the resolution and see if this helps. If you are using Windows the instructions can be found here
If neither of these options fix it then did it ever fill the screen?
Oct 25, 2012 | Dell U2410 24 inch Monitor
Picure does not fill out the screen
First try it on another video source. If it changes it's the source. If I hook a monitor to my laptop and put it display and external at the same time it uses the wide screen settings of my laptop display.If I go external only it fills it totally out. Also get into the on screen display and find where you can do reset or auto adjust. If nothing works regardless of machine it's on then the display may be failing and need service. Capacitors on the power board in LCD monitors since about 2004 have been prone to failure.
Jul 02, 2010 | Gateway FPD 1730 17 in. Flat Panel LCD...
Re ACER V203H 20" monitor - appearance. Why is the image size only 16" with black margins approx 2" on left and righthand sides? I bought this monitor brandnew - thought it was widescreen. If I change...
It is definetly a widescreen the issue is either with your display card or your resolution setting you need to check both. If you would have told me wether your display is through mother board or scsi card the model of mother board or the display card then i could fix the issue easilly.
Mar 06, 2010 | Acer V203HA Monitor
Display does not fill screen completely
ok right click anywhere on the screen go to the bottom and click properties now there will be a couple of tabs at the tom desktop screen saver you want settings raise your resolution to about 1200 x800 or higher i think native for that is the 1680x1240 this should fix your problem
Nov 25, 2009 | Acer X203H bd Monitor
The whole of the front page fills more than screen=why? and how do i fix it
If the page is larger than the screen, then your settings on your monitor are ff. Go to the monitor settings, which will either be on the monitor itself or go to my computer then control panel, select displays and change the resolution until the page fits the screen.
Oct 04, 2009 | Compaq Presario 5000 PC Desktop
Home page does not fill the screen
THE RESOLUTION IS TO HIGH FOR THE MONITOR. RIGHT CLICK ON A BLANK PIECE OF YOUR DESKTOP AND CLICK PROPERTIES AND LOWER YOUR RESOLUTION TO 1024X780
May 28, 2009 | Acer X193W LCD Monitor
use the monitor hardware controls on the actual monitor, and if that doesnt work, you have to change the display settings. which you would get to by right clicking your desktop interface, going to properties and display.
Jan 16, 2009 | Acer X193W LCD Monitor
Picture does not fill Screen
It is displays fine up unto the point where Vista loads, then it must only happen when Vista loads the display driver. I would go with your initial assumption and reinstall the display driver.
Jan 15, 2009 | Acer Aspire E700 PC Desktop
Display resolution problemw with Dell Inspiron 8000
I had the same problem you described as small screen in the middle with black border around it. The only resolution that made the screen fill the LCD panel was 1024 x 768. THAT IS WRONG!!!
Dell Inspiron 8000
PROBLEM - Small Screen in the Middle
FIX THIS PROBLEM - Try (Function Key + F7)
Nov 21, 2007 | Computers & Internet
Envision H190L Monitor Logo
Top Envision Computers & Internet Experts
Cleverer2
Steve
Martin Murray
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
