Question about Euro-Pro SC618 Handheld Steam Vacuum
Does not steam when you push trigger
Water does not get hot enough
3 Suggested Answers
  • 4088 Answers
SOURCE: Steam doesn't come out anymore when I pull the
Try putting some white vinegar in the tank to dissolve any hard water deposits. You should use only distilled water in this machine. Don't try to clean anything with the vinegar in it, but take it outside to run the vinegar through.
Posted on Aug 15, 2009
heatman101
  • 43501 Answers
SOURCE: Shark steam mop is spilling water out and not steaming.
Empty tank and fill with bottled spring water...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 26, 2010
I push the trigger and no water comes out
the trigger must made contact to a solenoid valve inside the steamcleaner , open the steamer and measure the solenoid if there is power on , lime could be the problem. open the solenoid and clean the spring and metal piece so it moves again close open normally you can hear it.
Made al safety Always think about your safety, pressure steam, electricity and hot water.
Aug 01, 2016 | Vacuums
Gets super hot but steam won't come out.
i have a simular steamer made by a different company. it used to work when i had first gotten it, but i think one time that i had plugged it in for a long period of time without using it has caused the plastic parts under the trigger that releases the steam flow to melt. so now the steamer that i have still heats up really hot but when i try to push the button it does nothing, no steam will come out of it at all... so i think my mistake was plugging it in without using it for too long, making it now inoperable basically garbage. sorry to say
Apr 17, 2014 | Scunci 52067 Handheld Steam Vacuum
How do I use a turbo steamer 220 portable?
if your talking about a 220 volt you will have to have a 220 plug in, otherwise most are 110 volt, fill with distilled water, apply appropriate pad, turn on machine and wait for the indicator lite to tell you its ready and go. i recomend a medium pace to let the steam do its work.
Jan 26, 2014 | Vacuums
Will not supply water from tank to brushes
Pulling trigger pushes a rod which opens valve to allow water to flow. Follow from trigger down to try to locate problem
Sep 29, 2013 | Hoover Max Extract Steam Cleaner
I do not know how to operate are hoover steam vac
pull out water container, fill the inner "bag" with hot water and cleaning solution, (the dirty water goes outside of the "bag" inside of the container. First run, squeese trigger to wet area, leet sit for a minute or two the go back over it until you feel it has picked up enough of the water. It will still feel wet, but as long as it was not picking up any water when passing over the area, thats all you can do. run fans and open a window.
Jan 24, 2010 | Hoover F5886-900 Steam Vacuum
Euro-flex monster baby 1000 watt will not release steam
try running a descale through the unit. probably blocked with mineral deposits. Descaler available at most steamer retailers
Sep 20, 2009 | EuroSteam Vapor Steam Cleaner Vacuum
Steam doesn't come out anymore when I pull the trigger. I think the water in the tank is getting hot, but when I pull the trigger, only a little water comes out. No steam
Aug 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Too much water coming out.
When you press the trigger an angled piece on the end of the plastic rod attached to the trigger pushes valve button in that then releases fluid. On releasing the trigger, the valve button is supposed to be pushed back out by an internal spring. The button gets sticky with evaporated cleaning fluid and does not come back out, causing fluid to continuously run. Try taking the machine outside, fill the tank with very hot water, pull the trigger, and let the clean, hot water flow through the valve. Perhaps it will free up. If not, the valvle will have to be replace. Either way, once it is working, ALWAYS flush the entire system with hot, clean, clear water to remove any cleaning solution in the system or it will only clog again
Jan 01, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Polti Vaporetto
Dear Terena
Had the same problem with a polti vaporetto 1500 ( vtt 1500 ) after butchering the big valve on the top I realised that the problem was that there was a blockage in the black pipe that comes from the machine to the trigger, the pipe that carries the steam in other words, so I got a piece of wire ( brake cable form a bike shop ) long enough to go at least half way down the pipe and then I pushed the wire down the hole at the trigger end and then from the other end that joins to the polti and hey presto the blockage was gone and the machine works fine again. If you use the machine again after you have cleared the blockage from the pipe you should be able to remove the valve from the top remeber that the water is now steam so it is very hot and will burn you so be carefull when opening the valve when hot I think that you will have to open it when it is warm not hot as what has happened is that scale has got in the threads of the valve and sealed it, so if you get it undone ( try pushing it down hard as you turn it Whilst it is warm only not hot ) then get some kettle descaler and put some in a bowl of hot water and put the valve threaded end in the descaler for 10 minutes to get rid of the scale and in the mean time put some descaler around the threads on the polti where the valve goes this will allow the valve to screw back on easily and you will be back to normal use again remember to keep the valve screw threads free of scale in the future I have only just reallised this so dont feel alone.
Pete
Sep 26, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
No steam release
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
Dec 12, 2006 | Euro-Pro Super SC710Z Steam Vacuum
Euro-Pro SC618 Handheld Steam Vacuum Logo
60 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
