Question about Ovens
SET TIME ON AEG B7500M OVEN - Ovens
AEG single oven - clock runs for 12 hrs , buzzes and goes back to 12 o'clock - if set timer and check time remaining, it buzzes and jumps to clock setting loosing time remaining. Buzzer sounds ''hoarse''.
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
Jul 17, 2010 | AEG B2100-4 Electric Single Oven
The light on my aeg competence oven and grill is not working. I can not use the timer.
It's either the thermostat / switch or the timer unit. Make sure the timer was not set to have turned off the grill first
http://www.espares.co.uk/part/cookers-and-hobs/thermostats/aeg/p/1604/143/0/0/1061574/top-oven-thermostat.html
May 20, 2010 | Ovens
MY AEG OVEN IS IN SAFE MODE HOW DO I GET OUT OF THIS MODE
Just found out that the 'safe' mode on my oven is for child protection. I had to press 'p' en 'minus' (-) at the same time for a few seconds. Problem was solved immediately. My oven is an AEG-Electrolux Micromat-Combi.
Apr 23, 2010 | AEG B8139-4-M Electric Single Oven
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
How to set the time on clock
Have not been able to set the time on clock - the actual model number cannot be found on the oven
Jul 17, 2009 | AEG D2100-4 Electric Double Oven
AEG 3032 Oven, no light, no main fan, no heat to grill or oven however the exhaust fan does operate when the grill/oven is switched on. The thermostat clicks when moved from 0 to a higher temperature but...
If you are sure the timer is set to manual and not auto , then I would say that it sounds like the selector switch is faulty or the thermostat is faulty, some times they are combined as one unit, and sometimes they are 2 separate switches.
You need to remove top cover of oven and have a look inside the control panel and see if there is anything obvious like a burnt wire or bad connection
If it is a combined unit, then sometimes the 2 parts of the unit become disengaged or the cam inside the switch breaks.
Plz rate my solution .
Thanks.
Jan 05, 2009 | AEG B1180-4 Electric Single Oven
My large main oven will not work on my AEG U7101- 4- M. The small second over/grill is working fine.
Is the clock set? The display must show the correct time and must not be set to automatic cooking.
If the light comes on and the fan is working then the clock is set. If there is no heat then the element behind the cover and surrounding the fan is probably open circuit. This can be accessed without needing to remove the oven from the carcass.
Good luck
Nov 27, 2008 | AEG U7101-4 Electric Double Oven
Clock settings
press 1st and third buttons together. use rhs button to set time and it should then work
Jul 13, 2008 | AEG B1180-4 Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
