Question about Sony Handycam CCD-TRV37 Camcorder
Cassette holder wont close
My cassette holder will only close if the tape is not in it.
SOURCE: the cassette holder isn't closing......and the tape is not loading
not geting in holder tht mean u must open ur casset holder and put in polethin bag for a hour and it will accept tape
Posted on Oct 01, 2007
SOURCE: sony ccd-fx310
My camera won't play back.  Occasionally, if I ffwd it will show the picture otherwise its a blank screen.  Any ideas?  I've tried cleaning the heads a few times now
Posted on Feb 02, 2008
  • 231 Answers
SOURCE: reinsert cassette
i recommend these people ..
Posted on Feb 18, 2008
  • 3 Answers
SOURCE: Can not load any cassette even empty cassette holder can not be closed.
I had the same problem and solved it by removing the battery to allow the camera to reset. Worked fine after that.
Posted on Apr 11, 2009
  • 6784 Answers
SOURCE: Wont load tape
HI, this is a mechanism fault beep you are hearing. the mechanism and load motor is damaged. you will need to send this unit to the Handy cam repair depot for this repair. you will need a new load motor and loading dock mechanism as well.
Posted on Jun 03, 2009
SOURCE: loading tapes
Sony HDR models that the carriage won't close is caused by the mode switch on the chassis. The mode switch controls the cameras function for loading and loading of the cassette. Basically tells the electronics what is happening. This becomes dirty and causes the chassis not to complete it's cycle on eject. Thus staying open. It has no idea where the mechanism is at this time. It can be cleaned and realigned but the chassis needs to be removed to get at it. Definitely a service depot repair. Sorry!
Posted on May 02, 2011
0 characters
1 Points
How do I fix the tape holder system on my camcorder? The door won't lock, and the cassette won't get inside the compartment.
is it close without a cassette ? if so the reel sensor in the cassette compartment may be faulty. if the head drum not rotates the cassette drive will not work correctly, if so please loosen the head drum with a plastic rod or some tools like that. do not put your finger in hence sometimes will jam your finger. remember don"t touch the scanning chip of the head.
Oct 26, 2015 | Panasonic Palmcorder PV-GS12 Mini DV...
The cassette holder wont come up aoutomatically
what you have to do is ejecting the tape, and as soon as it starts to eject , close the door immediately, then safeguard mode should be gone, and you will be able to eject normally.
Mar 04, 2008 | JVC GR-D290 Mini DV Digital Camcorder
Cancorder not wrking-e007 error message
moisture in the cassette holder. Take out the cassette, leave the holder door open for a couple of hours in a dry, warm location, and it should work again.
Sep 12, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Record problem
There are two things 1.there is a push switch under the cassette holder may be brocken 2.cassette holder is bad.put a cassette and press on cassette holder then try this way you can make sure which part is bad.
The cassette holder isn't closing......and the tape is not loading
See if this works--If you are on battery there may not be enough power .Charge the battery or use the the mains power through the transformer and see if it works.
Hope this helps
Nov 17, 2007 | Sony DCR-PC55E Mini DV Digital Camcorder
How do I close the cassett holder? (JVC GR-D70 comcorder)?
man just try pushing that place by a small support on its lower side. ( imean below... just the opposite side where it is told to "push here". i hope if you didnt broke its locking mechanism, it will work..
Oct 11, 2007 | JVC Cybercam GR-D70 Mini DV Digital...
Dcr-hc40 dropped and tape door won't close
try and take the door off and straighten the cassette holder assy
Sep 14, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Cassette holder does not close
Try inserting another tape first. If the trouble is still there,Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Aug 20, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Aug 14, 2006 | Sony Handycam DCR-HC42E Mini DV Digital...
Will Not Load Cassette
I have the zr850 which I have used less than a dozen times, and it does the same thing as you describe. Was told by canon tech people to try a maxell brand tape and a head cleaner tape. Have not tried their sugestion yet. camera is 3 months old.
Aug 07, 2006 | Canon ZR70MC Mini DV Digital Camcorder
Sony Handycam CCD-TRV37 Camcorder Logo
23 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
