Question about Dryers
Samsung dryer dv5471 stuck on cool mode - Dryers
Shows hE code, does not cool down
possible Heater Relay failure
Heater relay stuck open or closed; Wiring defective
Check for short circuit across heater relay(s) (RL5, RL6, RL7) or L1 applied to heater relay output(s) (J5-2, J7-1, J7-3) with cycle stopped. Check for open circuit between L1 and heater relay connection(s) (J5-1, J5-3, J7-2). If no wiring problems are found, replace Electronic Control Board and retest.
Apr 02, 2015 | Samsung DV337 Electric Dryer
WHY DOES MY SAMSUNG MODEL DV448AEP/XAA SENSOR DRY MODE RUN FOR TWO MINUTES AND THEN WILL GO TO COOL DOWN MODE, ALL OTHER DRY CYCLES MANUEL AND STEAM CYCLE OPERATE FINE!
Sensor is screwed or the timer relay for that part of it is not working . Go to an appliance store to get wiring diagrams ordered and might even know about the problem w that model
Feb 19, 2015 | Samsung Dryers
Samsung rs263tdbp and demo/cool off mode will not turn off
from the manuals Page 1. Activating/Deactivating Cooling Off Mode When the refrigerator is in Cooling Off Mode (aka Demo Mode) the display will read "OF OF, O FF, or OFF OFF." Cooling Off Mode prevents the unit from cooling. It is used by retailers to display units without wasting energy.
Note: Models without digital displays will display scrolling lines when the unit is in Cooling Off Mode.
Tip: If your display panel has buttons that have to be pushed in to perform any functions, replace the word "Touch" with "Push" or "Press" in the following steps.
  1. Touch and hold the top two buttons on the left side of the display panel.
  2. Important: You must touch the 2 buttons at the exact same time. Not doing so will result in an unsuccessful attempt to activate/deactivate Cooling Off Mode.
    [img src="http://www.samsung.com/us/system/support/content/2011/04/25/h5408/Demo_Mode_250_Pix_1.jpg" align="bottom" border="0" height="127" width="250">
    Notes:
    • As long as the display panel is located on the exterior of the left door of your refrigerator you will use the top two buttons on the left side of the display panel to activate/deactivate Cooling Off Mode.
    • If your display panel is located inside of the unit along the door frame you will need to locate the words "Cooling Off (Hold 3 sec)" printed on the panel. The Power Freeze and Freezer buttons are the two buttons used for Cooling Off mode on these models.
    • Wi-Fi Touchscreen displays on RF4289* and RSG309* are exceptions to this article. Cooling Off Mode is activated/deactivated through the settings menu.
Apr 01, 2014 | Samsung RS263TDBP Side by Side...
Dryer timer will not advance in any mode.. timed, or auto mode. Dryer works, but will not turn off unless you open door or advance timer. Do I need to replace the timer?
the timer will need to be replaced if it's stuck in the mode as you stated. the timer is built with cog teeth gears that rotate slowly as the timer operates normally. If a cog tooth breaks off the timer is stuck in that position causing your problem here
Jul 11, 2011 | Whirlpool LEB6200 Electric Dryer
Dryers Logo
69 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
