Question about Sewing Machines
Kenmore sewing machine 385.1551600 seized up - Sewing Machines
3 Suggested Answers
  • 19 Answers
SOURCE: Bernette 800D seized up
Please don't use WD40 on your sewing machine, WD40 is an alcohol based cleaner and will do the opposite of lubricate. Take your machine to a certified Bernina Repair shop, they will have a look at the timing and lubricate all of your gears. Lubricant will dry out over time, grease turns to putty and oils turn to varnish after several years of non-service. Lint is attracted to moisture, moisture being those key areas of any machine. Lint acts like an oil wick and will draw out your lubricant from key areas. It then begins to attract dust and other nasty things over the years to become grit. Your motor begins to burn out due to stress trying to move all of these clocked gears, cams and shafts. Take your machine in!
Posted on Dec 10, 2008
Tally Girl
  • 1133 Answers
SOURCE: kenmore sewing machine won't sew vinyl
There is several things you should use when stitching vinyl, treat it the same as leather. The main issue usually is getting the feed dogs to grip and move it through; this is why there are commercial grade machines specifically for leather hides and fur etc, it is tricky to stitch.
To stitch on a domestic machine, you need a leather needle with a spear tip to cut the leather so it doesn't split. Also, if you can get one, use a roller foot to roll over the fabric, or a teflon foot if you can't find a roller one. Also, use paper clips rather than pins to hold raw edges together (remove as they approach the foot and needle). You may also need to bash seams open after stitching (rubber mallet) and glue down the raw edges, this is how leather hides are stitched professionally. If you have to join more than 2 layers ie crossing seams, you'll probably need a Jeans-a-ma-jig device to help with feeding through the thickness and still getting feed. Like this http://www.punchwithjudy.com.au/shop/jean-a-ma-jig.html
You don't say what it is actually doing, ie stitches not catching, or the feed dogs not moving it through?
But if it is an entry level machine, it may not have sufficient engine power to pierce the vinyl, especially if the textile is thick. Also, don't try to use a heavier thread than normal weight, if you want the stitching to look heavier, then just run two reels of thread through all the thread guides, tension and the needle eye together. Something like buttonhole twist will be too heavy for the bobbin tension and top tension to handle.
Hope that this helps you with your project.
Posted on Dec 18, 2011
My kenmore 22 stitch sewing machine I bought in 1990; it doesn’t reverse anymore. How do I fix it
Those older machines do need regular cleaning and oiling. I suspect the oil has dried and caused the switch mechanism to seize. As time goes on, more parts may seize, so it's probably important to get it addressed soon. It could eventually damage the motor if the motor is trying to move seized parts. Well worth the expense if you value your machine.
Mar 19, 2018 | Kenmore Sewing Machines
Sears kenmore 158.18023 sewing machine is stuck in reverse!!
How long since the machine has had a thorough clean and oil? Could be seizing due to old oil that has dried.
Wheel on right side that controls the needle up and down is very tight...
Dec 19, 2017 | Kenmore Sewing Machines
Manual for kenmore sewing machine 158 1784183
Search for:
Make Model manual
*may not find the exact same model but similar models operate and thread the same--some have more stitches and accessories than others"
Your Kenmore is a keeper (wish I still had mine...) Be sure to clean and oil frequently to keep it running smoothly. It may seize due to old oil drying out. Below is how I treat a seized machine, but the oiling procedure should work for you.
Nov 27, 2017 | Kenmore Sewing Machines
Kenmore sewing machine my sewing machine won't sew, it just makes a noise
If it's an older mechanical machine, it most likely has seized due to lack of recent, thorough oiling. Refrain from forcing the machine to run as it could damage the motor.
Aug 10, 2017 | Kenmore Sewing Machines
Should I oil the motor on a kenmore sewing machine model 158.905?
Do NOT oil the motor unless the manual instructs you to do so. (Sears carries manuals for most of their machines.)
Your machine appears to be an older mechanical machine. As such, oiling would be necessary for the moving metal parts. The following may be helpful to keep your mechanical machine happily operating. (Although the following is for machines that have seized due to lack of oil, following the procedure is helpful in preventing the machine from seizing.)
May 06, 2017 | Kenmore Sewing Machines
My kenmore sewing machine is stuck in the reverse mode
The feed assembly is starting to seize. You will have to take it in to be serviced
Jan 04, 2015 | Kenmore Sewing Machines
Kenmore sewing machine 15343
I had this problem but have resolved it (for the most part) by lowering the needle down into the fabric before beginning to sew.
Aug 12, 2008 | Kenmore 15343
Sewing Machines Logo
37 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
