Question about Motorola Mobility RAZR V3
Scandisc cellphone memory card
I formated the minicard in my Motorola RAZER2 cell phone. Then I placed the minicard in an adapter and into the card reader slot on my Vista computer. The card is not identified.
  • hubbs Oct 11, 2007
    Thanks, I needed to download an update for our computer, and it now recognizes the card.
  • 432 Answers
There is a format feature on your phone to format the card. This will reset the microSD card so the card reader on Vista will see it again. These phones are new and I don't that much about the settings yet.
Posted on Oct 08, 2007
Need isatap driver for vista
im assuming its a laptop computer
Turn the laptop over and remove the battery.
Remove the screws that are used to secure the memory/wireless LAN minicard cover with a Phillips-head screwdriver. Lift the edge of the cover to remove it.
Disconnect the antenna cables from the wireless LAN minicard with the needle-nosed pliers.
Locate the screws that are used to secure the wireless LAN minicard to the motherboard and remove them with the Phillips-head screwdriver.
Pull the wireless LAN minicard out by grabbing the card by the edges.
Reinsert the wireless LAN minicard and push down on the card to set it in place.
Tighten the screws to secure the card to the motherboard.
Replace the antenna cables with the needle-nosed pliers.
Replace the memory/wireless LAN minicard cover and secure it with the screws.
Replace the battery and then turn on the laptop. Windows Vista will load and reinstall the drivers for the ISATAP adapter.
hope this helps
Sep 22, 2012 | Asrock K8Upgrade-VM800 Motherboard
Tip
How to Transfer Files from Cellphone to Laptop and Vice Versa
<span>There are three ways that you can use enable for you to transfer files from your cellphone to your laptop or vice versa.<br /><br /><span style="font-weight: bold;">1. </span> <span style="font-weight: bold;">By using a connectivity cable</span>. <br /><br />It is a cable which you can buy from any cellphone stores. Just plug the other end to your computer and the other to your cellphone. You can then access the pictures in your cellphone.<br /><br />A connectivity cable looks like this.<br /><br /><img src="carloadrian_2.jpg" /><br /><span style="font-weight: bold;">2. Bluetooth</span>. <br /><br />Click the link below so that you will be directed to the procedure on you to connect your cellphone to your laptop by using bluetooth. <br /><br /><a href="/../support/t8013435-connect_laptop">CLICK HERE</a><br /><br /><br /><span style="font-weight: bold;">3. Memory Card<br /><br /></span><img src="carloadrian_4.jpg" /><br /> <a><br /></a> <span style="font-style: italic;">SD cards are used in many cell phones</span>.<br /><br /> Many cell phones come with removable memory chips, which can be used to expand the available storage on the cell phone, or to transfer files (such as music and pictures) between the cell phone and other devices. Once you identify the kind of expandable memory in use on your phone, an adapter can usually allow you to connect it to a laptop as if it were a USB drive. <br /><br /><span style="text-decoration: underline;">INSTRUCTIONS</span><br /><br />1. Determine what kind of two-gigabyte memory chip your cell phone uses. You can do this by checking the specifications of your cell phone in the manual or on the manufacturer's website, or by removing the card and examining it. As of April 2010, the most common kind of memory card used in cell phones is the SD format, which comes in standard, mini, and micro sizes. Your phone may also use the Memory Stick Pro or Pro Mini format. The format type will be printed on the side of the card. <br /><br /> 2. Purchase a USB adapter for the card you are using, which is available from many different vendors. If your card is in a mini or micro format, make sure that the adapter comes with a sleeve for the card of your size; this allows you to insert a mini or micro card into the sleeve, and changes the card into a standard size for use with the adapter. <br /><br /> 3. Insert the card into the sleeve, if necessary, then into the adapter. Connect the adapter to a USB port on your laptop. The card will appear on your laptop as if it were a USB drive. When you are finished working with the card on your laptop, you can move it back to your cell phone.<br /><br /><br /> </span>
on Jan 28, 2011 | Cell Phones
How do I upload pics from my cell phone to my laptop
There are three ways that you can use enable for you to transfer pictures from your cellphone to your laptop.
1. By using a connectivity cable. It is a cable which you can buy from any cellphone stores. Just plug the other end to your computer and the other to your cellphone. You can then access the pictures in your cellphone.
2. Bluetooth. Click the link below so that you will be directed to the procedure on you to connect your cellphone to your laptop by using bluetooth.
CLICK HERE
3. Memory Card
SD cards are used in many cell phones.
Here's the instructions on how to do that:
Hope this helps.
Please don't forget to rate this solution. Leave your comments or suggestions on how I can improve my service.
Thanks
I want to formatting my phone...but i dont know how...i have the motorola software program but i still cant formatting my phone????
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Aug 26, 2010 | Motorola Mobility L6 Cellular Phone
MEMORY card
Hello there
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Aug 03, 2010 | Motorola Mobility W270 Cell Phone
    Help with memory card inkrazr cellphone
    Do not use card reader and format with pc, you only format the card with the phone,and only once.
    If you format the card with your pc the phone migt not see the card anymore,even if you format fat32. The card is suppose to be formatted with phone because the phone needs to build folders in the card.
    As for saving anything,say pic,just open options and choose card.
    Apr 13, 2009 | Motorola Mobility RAZR V3x Cellular Phone
    Err
    Could be your memory card faulty,try another card put in to check.
    Jan 13, 2009 | Motorola Mobility RAZR V3i Cellular Phone
    V3i card formating
    no solution... need a 512kb sdmini card... that is the MAX supported size.. i have the same thing on mine... i had a 512 card tho and it formats fine and works. the 2gb card wont even be recognized by the phone..nevermind format. i can also format it on my pc but that does no good
    good luck
    512 sd cards are 5 bucks on ebay now ! get one
    or two
    Nov 04, 2007 | Motorola Mobility RAZR V3i Cellular Phone
    Denied access to MMC to motorola cell via usb
    Try to reformat the memory card with a Laptop or PC then try put it in. Or use the formatting tools on that phone to format the memory.
    Aug 04, 2007 | Motorola Mobility E398 Cellular Phone
    Motorola Mobility RAZR V3 Logo
    24 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
