Question about Mitsubishi XD221U 3D Projector
Automatically shuts off
When turning the projector on it automatically shuts down...any ideas...new bulb?
5 Suggested Answers
SOURCE: projector automatically shuts off immediately after turning it on
If your comfortable w/surface mount troubleshooting and soldering, download the service manual from elsewhere online. Part of the troubleshooting tree for this type of problem is to check the surface mount fuses on the underside on the Main PWB (schematic page 1/8). On mine, the 12V surface mount fuse, F3004 (2.3A) was open (quadrant C1 on the schematic). Replaced it, reassembled the projector (3 interlocks don't 'cha know) and it came up just fine.
Doug
Posted on Dec 10, 2007
  • 6 Answers
SOURCE: Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Posted on Apr 01, 2009
projdoc
  • 2237 Answers
SOURCE: Projector suddenly shut down
you need to reset the lamp timer. turn it on, and press and hold the left arrow, right arrow, and power button until it resets.
Posted on Aug 04, 2009
mastertech48
  • 149 Answers
SOURCE: Mistub XD450. Bulb relatively new. Projector
Does the projector work normally when sitting right-side up? If yes, something could be interfering when the unit is inverted. The symptom you describe initially sounds like a defective fan (some fans put out a computer pulse telling the main board it's running--they have 3 wires, red, black, yellow(signal)). If the board doesn't get signals from all required components, it's programmed to shut down to protect itself.
Posted on Sep 08, 2009
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
Projector shuts down every 30 seconds. is this a bulb issue or other internal issue?
it can be one of two things
1 The Bulb need to be replaced, (do not buy from Sony, buy it from amazon for about 70.00
2 check your filter make sure you are getting enough ventilation.
Tony
Jun 16, 2012 | Sony VPL PX30 Multimedia Projector
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
I have a Sanyo PLC-EX20 projector which shuts down after five minutes, what could cause this?
There are 2 possible causes.
The first may be due to overheating. Most projectors have a "air filter" that can be removed and cleaned. If it gets clogged with dust over time, the projector can't breathe and shuts down.
The second cause may be your lamps life hour clock. Most projectors keep track of the amount of time that their bulbs have been active. Once a preset # of hours has passed the projector will limit functionality until a new bulb has been installed AND the lamp life clock reset. Most projectors do not automatically reset the lamp life clock after a new bulb is inserted.
There should be instructions on how to reset the lamp clock in your users manual, and info on cleaning the air filter. Unfortunately I went to the Sanyo website and was unsuccessful in locating a PDF of the user manual for you.
Mar 04, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
Dell 1800mp projectors turns on for a few seconds then turns off and lamp light stays solid orange...what's the problem. New bulb?
Hello
If the Lamp light and power lights are blinking orange, the lamp driver has failed, and the projector will automatically shut down. Unplug the power cord from AC mains wall socket, wait for three minutes and replug and see whether it helos you. If not, contact Dell service center.
OK.
Nov 19, 2010 | Dell 1800MP Projector
Projector will only stay on for a couple of minutes then shuts off automatically. the LED turns from green to red
Make sure the venting for the cooling fan is clear and that it is activating. The only time I have seen this in a projector is when it overheats. If it reaches a certain temperature and doesn't sense the cooling fan being on it shuts down to protect the bulb and protect against fire hazard.
Oct 28, 2010 | Toshiba TDP-T90 Multimedia Projector
LCD shutting off automatically
Hi there
Check if your blowerfan that cools the lamp - sits in front of Projector is running.
Nov 06, 2007 | BenQ PB2140 Multimedia Projector
Mitsubishi XD221U 3D Projector Logo
51 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
