Question about Doberman Security Pool Alert SE-0114
Doesn't work sometimes
Sometimes the red light is on and sometimes it's off, why?
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
If my akai flatscreen 32in tv is moved or if the power goes out sometimes I plug it back in and the red light doesn't come on. Other times is when I'm watching it and I turn it off it goes from...
bad joint remove back panel with tv off check for any bad joints on power board also caused by thermal fault with tv on use a heat source over boards till tv shuts down then check suspect board
Dec 23, 2012 | Televison & Video
1998 dodge Dakota Ok so I just got this truck and when I got it the abs light and brake light were on plus the speedo doesn't work sometimes I replaced the rear speed sense on the diff but the lights...
If the red brake light and the ABS light are both lit up on the dashboard, do NOT drive the vehicle. It indicates a major malfuntion with the brake system. The red light indicates low brake fluid or the parking brake engaged. The yellow ABS without the red light, indicates a problem the computer found and it disables the ABS system while still having conventional brakes. Since both are lit, it needs the brake system repaired. What you replaced on the rear diff was probably the rear ABS sensor. The vehicle speed sensor for the speedometer should be located on the rear of your transfer case if you have 4WD, or on the rear of the trans if you have 2WD.
Oct 11, 2012 | Cars & Trucks
The red security light comes on in my buick century 2000 and sometimes it starts and sometimes it doesn't! it may take 5 minutes to start or sometimes an hour!1! please can i disconnect a fuse or
If it is an aftermarket system you should be able to disconnect it.
You may have to look for extra wires attached to the fuse box to find the source of power.
Factory systems usually have the word security in the cluster.
Aug 28, 2012 | 2000 Buick Century
Onn mini travel mouse not working
i have no red light n my mouse is not working
Jan 05, 2012 | Televison & Video
Nexxtech external USB hard drive stopped working. Light comes on but drive does not seem to activate and produces no response in the laptop.
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
a cnet rview
Pros: Lots of space, very low price, doesn't require outside power
Cons: Sometimes stops working, no firewire (but still a quick transfer speed)
Summary: This doesn't require outside power, but sometimes you need to hook it up to 2 USB ports. The USB cable has 2 heads. Sucks when I only have 3 USB ports on my laptop.
Also sometimes it spontaneously stops communicating with the computer. I don
Oct 04, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
Booted up my computer this am and the red light remains on and it does not appear that the system recognizes the external drive. The red light remains steady...I don't thhink the drive is running. How...
it is a known issue that these particular drives sometimes don't get recognized by the Operating System, after coming out of Sleep, Stand By, or Hibernation.
Simply try to disconnect and reconnect the drive again in the USB port, if this doesn't work then, Disconnect it from the USB and connect it to the Firewire. if this doesn't work then, Restart the computer.
It should solve the problem.
May 21, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
When my Motorola H720 is plugged in, the red light is flashing quickly, what could be wrong with this? It does not seem to turn on either....problems?
Red light flashes when I try to charge it and nothing all other times. Doesn't turn on, doesn't work. I pretty sure the problem is that it is a piece of junk.
Mar 17, 2011 | Motorola Mobility H720 89382N Bluetooth...
Heater doesn,t work. Controls on dash sometimes light up & sometimes doesn,t. All of my fuses are good. It seems to act up mostly in the morning. Sometimes if I turn my head lights on my gauges quit...
Morning Charlie,
If it were me, I would check the wires coming & going to & from engine. Maybe something is crossed. That's what it sounds like, anyways.
Oct 08, 2010 | 1996 Jeep Cherokee
Doberman Security Pool Alert SE-0114 Logo
53 people viewed this question
Top Doberman Security Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Doberman Security Boating Expert? Answer questions, earn points and help others
