Question about Husqvarna 967 00 36-01 - RZ5426 54" 26HP Kohler Zero Turn Lawn Mower
Mower starts rolling backwards when in neutral
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I was mowing on a
There is a pin or a bolt that either broke or came out of the linkage...
Follow the linkage and see if there are two pieces unhooked that seem like they should be together...look also for a place that the paint is worn off but there is no pin or bolt...
Kinda hard to direct you from here but I'm sure that something came apart while you were rolling backwards...
heatman101
Posted on Aug 07, 2011
kevin_getz
  • 1031 Answers
SOURCE: husqvarna riding mower will not go forward or backward just stays in neutral
You either have a linkage problem or an internal problem in the transaxle.
Posted on May 15, 2012
  • 6468 Answers
SOURCE: HYDROSTATIC TRANSMISSION NOT WORKING ON NEW MOWER
there is a rod on the rear of the mower that is pulled back and lock into place this is there to push the mower around when not running it just lift the lever up and it should pull in then your ready to go
Posted on Sep 05, 2012
How do I unlock the rear wheels, I got a Poulan Riding Mower from a late Uncle. It won't roll forward or backwards
Kevin, if it is in neutral or if it is hydro-stat, you have pulled the pins in the back to unlock the axles. the brakes may be locked up. the last two mowers i got for some reason the brakes were locked up on them both. hope this helps.
Dec 16, 2016 | Poulan Garden
Craftsman lt1000 rider 42 in deck is stuck in gear and wont go into neutral. so i cant get it started.
this happens when lawnmower is cut off in gear try this mash clutch and shake mower forward and backwards while trying to shift into neutral
Sep 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Car wont roll forward or back even in neutral
I assume it's a manual transmission.
If the car will not roll backward or forward in neutral (with or without the clutch engaged) the transmission is most likely locked in two gears at the same time.
This may happen if gear selectors are excessively worn. If you are able to examine the gear selection levers external to the gearbox, ensure they are in the 'neutral' (no gear selected) position when the gear lever is in Neutral. If not in correct position, you may be able to manually reset the levers to correct neutral position and thereby unlock the gearbox.
In any case, if it's happened once, it will happen again, so get the gearbox and gear selection mechanism checked for wear or breakage.
Jul 31, 2009 | 1997 Subaru Legacy
My poulan riding lawnmower will not roll. The
Hi..my name is Keith..and it sounds like the neutral rod on the back of the mower needs to come out further to fully disengage the transmission so you can roll it..it should have an adjusting nut on the rod..and i would turn the nut in a couple of turns until the lawn mower will roll..i hope this will help..if not please write me back
Jul 12, 2009 | Garden
Murray Riding Lawn Mower won't start or move
The Drive Belt keeps coming off as soon as I engage the mower I replaced the Drive Pulley and put on a new belt but it still comes off. Any Ideas.
Jun 12, 2009 | Garden
Mower will run will not go foreward or backward
With transmission in neutral...start the engine and move the speed lever to highest speed and move it back to brake position, then shift the transmission into gear and move speed lever, this will fix the problem.
Apr 26, 2009 | Garden
Won't go backwards when in reverse my son says
poss. transmission issue or problem with rear brakes if drum operated. does it roll frontwards?
Nov 15, 2008 | 1991 Subaru Legacy
Husqvarna 967 00 36-01 - RZ5426 54" 26HP Kohler Zero Turn Lawn Mower Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
