Question about Home
Storage drawer wheels - Home
How do I put my bed together, there was no instruction manual?
Yaletown Black Queen 6-drawer Platform Storage Bed Manual
www.fixya.com > Prepac > Beds > Prepac Yaletown Black Queen...
Owners Manual & User Guide forPrepac Yaletown Black Queen 6-drawer Platform Storage Bed - Bed%20frame%2013302541%20Assembly%20Guide.pdf ...
Yaletown Black Queen 6-drawer Platform Storage Bed ...
www.fixya.com/.../p9574513-prepac_yaletown_black_queen_6_drawer...
Recent Prepac Yaletown Black Queen 6-drawer Platform Storage Bed questions, problems & answers. ... Assembly instructions for the Acme canopy bed.
Nov 19, 2015 | Prepac Yaletown Black Queen 6-drawer...
How do I open the storage drawer without damaging it? Has become jammed by the contents.
if their is enough of a gap in the drawer , that allows you to see the object blocking it, then try using a spatula to push down on the item and move it back as I suspect that it is stuck on a small protrusion at the top of the drawer.
Nov 22, 2014 | Rangemaster Classic 110 (Dual Fuel) Dual...
I want to reinstall a oven storage drawer on a electric LG oven
I don't think you need to remove a slide rail. They should slide out by hand and then set drawer back into it. usually have to tile drawer up some to start.
Nov 06, 2013 | Kitchen Ranges
The storage drawer is off track (seems to have dropped down). It is not easily removed from the track and the manual does not show how to remove it. Any suggestions are appreciated.
In some cases I have had to pull the oven completely out and either access it from the back or lay the oven down on its back to see where the problem is at, but in most cases it is usually a simple fix once you can get to where the actual track is located.
Hope this helps. Make sure once it is back that you inspect the track and the wheels on the drawer t make sure no metal was bent, if it was and you cant bend back most local appliance suppliers have the parts you would need to repair it.
Oct 13, 2013 | Whirlpool Gold GFE461LVB 30" Freestanding...
Need to replace front of storage drawer
Instead of replacing the door of the storage drawer, can you please use some chemicals which will remove the bad stains. Make sure you use chemicals which will not affect the steel. Lots of chemicals available in the market to remove bad stains for steel.
Thanks.
Mar 31, 2012 | Refrigerators
Where is the cigarette lighter fuse on 1998 corolla
Those answers are wrong! It's behind the little storage compartment to the left of the steering wheel. You can pop that little flip-drawer out and there it is. (Lighter fuse is three down all the way to the right.)
Mar 31, 2012 | 1998 Toyota Corolla
Where is the tire lock kept on the 2002 RX 300
If you are referring to the mag wheel puzzle lock, storage is an optional location. The RX300 has a number of storage pockets, so check the spare tire area and tool kit, then the rear storage side pockets, glove box, console sliding drawer at bottom of console and your map pockets on the doors. If the puzzle key is missing , go to the dealership. They will have a matching master set and can order a replacement after identifying yours.
Nov 01, 2009 | 2002 Lexus RX 300
Whirlpool electrice stove storage drawer
There is a screw in the bottom of the two back corners that holds the drawer glide in place. Remove the glide and then you'll be able put it back the way it belongs.
Nov 22, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Jammed storage drawer
svineyardWelcome to fixya.
I'm Huuum and happy to assist you,
You said, Y inherited a GE Spectra XL44 in the home I recently bought so you don't know much about it. There is a pan stuck in the storage drawer and You can only open the drawer about an inch and a half before it jams.
You need two people.
One strong person to slide the range forward, so he can tilt the range far enough back, that you can access the drawer from the bottom and the pan will fall back inside the drawer as you pull the drawer forward and out enough for you to reach the pan and turn it around or what ever you need to do to get it out!
Bravo, I want to hear that you succeed!
Be careful not to hurt your self.
Bless You Huuum.
Please do not forget to leave a rating when you are done.!!!!!!!!
Aug 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Home Logo
213 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
